20 Most Recent HP Photosmart 2710 All-In-One InkJet Printer Questions & Answers
The most common reason for this is that the power input in the printer has a bad solder joint.
Wiggle the power connector at the back while the unit is powered up.
If it goes off, then that connector inside the printer just needs to be soldered back down.
The other possibility is that the power adapter itself is failing, which is really hard to test without another power adapter to test it with.
HP Photosmart... • Answered on Nov 23, 2018
is this a case of the dots are missing for a valid line, or do you mean a line feed is added at the end of a line, ie you get 3 lines of text occupying 4 lines of space , or 4 lines of text occupies 4 lines of space, but one line has no printed dots on it? to make it more obvious, what does a document with say text thats 3cm tall look like? as it sounds to me like contacts need cleaning.. *** note for info: do not rely on printouts from within a BROWSER as that may have unpredictable results. All text will be treated as a large block of PIXELS and Not TEXT. also Non Printer fonts could cause similar issues.
HP Photosmart... • Answered on Nov 09, 2017
Hi, every driver related problem can be solved by this software, take a look: Driver Update Software for XP Vista 7 8. enjoy
HP Photosmart... • Answered on Jan 04, 2015
Take a real close look at the entire paper path and be sure that there isn't a small piece of torn paper stuck in some obscure place.
HP Photosmart... • Answered on Aug 18, 2014
hi,
try this
> unplug the usb cable from the computer
> click on "start--> control panel--> printers and faxes"
> select the printer icon associated with your printer and delete it.
> now plug the usb cable to the printer
> wait for few minutes while all the drivers are installed.
thats it... now try to print... it should be resolved
thanks and regards
agnel
HP Photosmart... • Answered on Dec 03, 2013
see the following you will find all you need http://www.google.com.ly/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0CDEQFjAA&url=http%3A%2F%2Fh10025.www1.hp.com%2Fewfrf%2Fwc%2FmanualCategory%3Fdocument%3D%26product%3D420428%26lc%3Den&ei=qHtLUbmLNcTAPKGKgeAC&usg=AFQjCNEdS2cM8DQvUCgui3uNM5Ud3F9yzA
HP Photosmart... • Answered on Mar 21, 2013
Go to start menu, (left bottom corner), the control panel, find printers and double click. Find your printer, it should say (HP Photosmart, all-in-one) or something like that. Right click on the icon. Left click on printer preferences, Your printer pref. shoulde come up. At the top you should see something like (General, Layout, Advance). Click on Advance. Find maintence and click (it should be in the middle or close to the bottom somewhere. You should see (print test page, calibrate printer, clean printhead). Click clean printhead.This should do the trick.Good Luck.
HP Photosmart... • Answered on Dec 28, 2012
Does it need a new cartridge? Replace .
HP Photosmart... • Answered on Dec 11, 2012
HP Photosmart 2710 All-In-One InkJet Printer Logo
200 questions posted
efs_perpends
efs_perpends
k24674
View Most Popular
PhotoSmart HP
  • PhotoSmart HP
Most Popular Question
hp photosmart 2710 missing scanner
  • Office Equipment & Supplies
