20 Most Recent
Tricity Bendix Cooker Main Oven Thermostat Switch For Dsie502gr currys Questions & Answers
Hi there, I have a
You know, I think the best thing to do would be to replace the dishwasher. It is ten years old and a new one would be more energy efficient and you would save money in the long run.
Water is not draining
First, Is any water draining? If yes, look for restrictions or siphoning back into the machine. Hair and paper are common restrictions on the anti-siphon/overflow device. It's' on the sink top. Remove the cap, take a long nose pliers to remove the inner top plastic piece. Remove the junk - hair, paper, etc. Put a inverted cup and run the drain cycle. Move junk and water will come out. Re- assemble. Also check for kinks in the drain hose(s). Also clean out the filter and screen in the dishwasher. Watch out for broken glass. If new garbage disposer, make sure the knock out plug was remove -- should see water enter from the dishwasher. If you don't have an anti-siphon device, get one. Otherwise drain water will back into the dishwasher.
