20 Most Recent
HP ScanJet IIcx Flatbed Scanner Questions & Answers
I have a dell lap top computer that uses vista. I
No it can't be done because HP does no more produce drivers Vista nor W7 for this unit .
Here are a few hints :
Make sure driver XP ( yes , XP ) is correctly installed . Then , go to http://download.cnet.com/FreeKapture/3000-2094_4-10673689.html and install FreeKapture , it's free .
Load FreeKapture , clic on Scan and select WIA Hewlett-Packard . Scanner works fine in this mode . If you choose HP PrecisionScan Pro , program will hang .
In any case , no slides or negatives scans possible but the rest works .
If you have the W XP install disc , you could install a virtual version of W XP on your HDD ( http://downloads.vmware.com/d/info/desktop_downloads/vmware_player/3_0 ) You could also partition your HDD ( http://www.partitionwizard.com/free-partition-manager.html ) and install W XP on the new one . Otherwise , you will have to buy a new scanner , what you probably already have .
Regards .
I'm looking for a Windows 7 compatible driver for
Not compatible or not working well with windows 7?
(making a program work with windows 7)
Maybe, It doesn't work because the driver/application you installed is
for other versions of operating system. I am also using windows 7 like
you so don't you worry, You can still use your old installer/driver from
other versions of operating systems. Just remember that before
installing any program in a windows 7 Operating System Computer, Use
"troubleshoot compatibility". Right Click the Icon of your program
installer/application first, then choose "troubleshoot compatibility". This will
allow you to choose on what type operating system your program will run.
Just reply back if it still doesn't work.:D rate and vote for me:))
How to increase scanning speed in hp scanjet g2410
Install the drivers for it from the HP website. Other software for it should be there as well. As to scanning speed, setting it to scan at lower resolutions can speed scanning. Scanning for color is slower than scanning for Black and White, FYI.
What is meant by PDF in used in scanning?
If you are asking about the "SCAN TO PDF" button, it allows the scanner to create a Portable Document Format (PDF) file. PDF files are files that can be viewed with the free Adobe Reader software. The PDF format files are easy to store on your computer and easy to share. PDF files can have many pages. Image files, like JPG, can only hold one page per file.
If you use PDF files, make sure you only get the reader software from Adobe.com.
Adobe Reader Download Free PDF viewer for Windows Mac OS Android
