20 Most Recent
Samsung RF217ACPN - 20 cu. ft. French Door Refrigerator Questions & Answers
Samsung french door freezer will not open
Aha!
The Samsung wants the password.... in French! No!
Sorry.... couldn't resist....
If it's iced up then that would hold it shut until it melts.
Icing up is usually caused by a bad seal!
9/18/2015 6:46:24 AM •
Samsung...
Answered
on Sep 18, 2015
Model RF217ACPN water in the vegetable bins and below bins
I am pretty sure you are having a defrost by CouponDropDown">drain blockage
problem. Most defrost every eight hours and over a period of time the
drain line that comes down from freezer into a cup like object top
middle and back of the fresh food section. If blocked by gunk or ice you
will see trails of liquid leaking down the rear wall of fresh food
compartment until it reaches the crisper drawers.This is not always the
same with every model as you may see frozen ice flowing down ther rear
wall of freezers on side by sides. Here is an example Click here=> Whirlpool Leak Photo taken by TechnicianBrian
He has been around a good bit and deserves credit for his
contributions. Here is another way to make this look more si mple in
clip below. TechnicianBrian.com And in this photo are several parts listed in photo group #1 were it is most likely running down the wall=> MagicChef CTB1921AR fresh food section. If
you still have questions please ask and rate me if I was able to
explain this well enough. Every refrigerator is made different so these
are examples only. The key is to find if ice or just gunk has blocked
you defrost drain. Unplug and then remove the rear panel in back of
freezer. We need to see if the water is overflowing the condensate drain
tray or if the blockage is in the turn the drain leads down back of
your refrigerator. Much more on this page=> Leaking Refrigerators!
This is a common tip so I will be placing this post and add as we go
new ideas listed in Sea Breeze Tips Section. If you run into any
problems along the way of repair please let me know, Thanks, Sea Breeze
4/24/2015 3:14:28 PM •
Samsung...
Answered
on Apr 24, 2015
Samsung refrigerator wont cool down
JUST ROTATE YOUR THERMOSTAT TO THE MAXIMUM AND WATCH IF STARTS COOLING THEN ADJUST THE THERMOSTAT TO YOUR REQUIRED LEVEL LATER ON. iN CASE IT DOES NOT START COOLING CHECK THE COMPRESSOR WHETHER IT IS WORKING, IN CASE YES THEN THERE IS NO GAS IN IT
9/29/2014 9:16:45 AM •
Samsung...
Answered
on Sep 29, 2014
Glacier in back of fridge wall, caused by heater going bad, is this a lemon?
If the common in your house is grounded, as it should be in the older wiring systems it should work unless the refridgerator is only grounded through the ground lug. If that is the case AND you know the house is wired correctly throughout, ie no wires switched in any switch or outlet, you can ground the common at the fridge. BEWARE! If one outlet or switch is wired backwards and you do this you will get zapped when you touch the refridgerator.
6/18/2014 1:49:43 PM •
Samsung...
Answered
on Jun 18, 2014
Ice maker will not separate ice cubes
Check if your water filter is up to date, if not check if the ice maker has the option to choose the side of the ice cubes, if so, set it up to medium side.
11/15/2013 7:11:02 AM •
Samsung...
Answered
on Nov 15, 2013
Vegetable crisper is filling with water
You may have have your freezer drain stopped up and when it goes into defrost, it melts and the water spills over to the lower section being the crisper. This is a simple fix. You just need to find out where the water is coming from .
2/6/2013 8:14:48 PM •
Samsung...
Answered
on Feb 06, 2013
