20 Most Recent HPHEWLETTPACKARD Refurbished HP XW8200 XEON 2.8GHZ 1GB DDR2 400 250GB SATA CD NVS280 XP PRO HPHEWLET... (C52468999BFM2) PC Desktop Questions & Answers
buy it and istall it. simple
HPHEWLETTPACKARD... | Answered on Aug 28, 2012
Seems LSI has several versions of that board on their site. The following link will take you to the base model, click on the "Support and Downloads" tab to pick the right OS for your board.
http://www.lsi.com/storage_home/products_home/internal_raid/megaraid_scsi/megaraid_scsi_3201/
Hope that works for you. Good luck.
HPHEWLETTPACKARD... | Answered on Oct 31, 2010
Do the card is compatible with your HP?
HPHEWLETTPACKARD... | Answered on Oct 12, 2010
what about the cable connection is it one?
HPHEWLETTPACKARD... | Answered on Jun 18, 2009
You probably do need a driver.
The drivers are available from this page of the HP Support website.
HPHEWLETTPACKARD... | Answered on Jun 02, 2008
you can recover lost files from computer with Asoftech Data Recovery program. here's the good guide
http://www.youtube.com/watch?v=vZDCrKzNl6w
HP Computers &... | Answered Yesterday
ever read the manual
https://support.hp.com/us-en/product/hp-laserjet-pro-mfp-m130-series/9365370/model/9365371/manuals
page 128
er/12 states this.
quote
The imaging drum is incompatible with the printer, possibly due to a missing or damaged memory chip. Replace the imaging drum.
If it is the system hardware password, you cannot get into it.
If it is the windows password, you can but this is a public forum and it is not allowed to explain how. Take it to a computer repair shop.
HP Computers &... | Answered on Sep 09, 2020
Larry Ng writes
Jun 19, 2020
Must we beg you what PC? NOR what OS this is.
failure to boot has vast causes.
Do you want them all, ?
Take the PC to any shop get it fixed.
clear to causes.
1: HDD bad, no bad HDD on earth can boot your OS, is that clear? We test this HDD first.
2: A Corrupted unstated OS. endless ways, reload it and cured.
There are more, but I want to keep it simple.
HP Computers &... | Answered on Aug 18, 2020
11years old 2009, and all need service that old ok?
here are the top fails on this PC, this old, (lots)
all batteries are no good now, even shorted. dead PC.
CCFL back lamp dies next. VGA port works CCFL not.
and packed up in lint, never seen on ever not.
overheating is caused by zero service done.
cleaning is must. ( and also extends the life of ANY PC)
all vents cleaned and all fan blades.
and this RAD photo below.
if not TOO bad even "can-o-air" sold at walfart works.
I call that back blasting all vents.
I use shop air to blast mine out, (via paint reg to 20psi)
HP Computers &... | Answered on Jul 23, 2020
If this issue started with a motherboard error that appeared to be a faulty CMOS battery and then it started incorrectly detecting your memory and now is asking for a password it could be a faulty motherboard. If you are 110% you or anyone else has set a password on that laptop then I would say your motherboard needs to be replaced. It is a difficult process to reset admin passwords on most laptops due to a security chip that will prevent the trick of removing the battery from working. In all honestly if no one has set a password and the motherboard THINKS someone has then even if you reset the password you will still have issues. There is a small chance your CPU or RAM could be defective. But, again going back to it saying you have a password set that was never set. It just yells faulty motherboard unless someone has set a password without you knowing.
HP Computers &... | Answered on May 28, 2020
If you've got working Wi-Fi but your wired ethernet connection is not working, the first thing to do is turn off the Wi-Fi. Believe it or not, this might tell you that the ethernet is working. ... Right-click on the icon, go to Open Network and Internet Settings, then the Wi-Fi tab, and toggle off.
This Error 1702 problem can occur if all the following conditions are true:
  • You originally installed Office from a network administrative installation.
  • The network administrative installation is no longer available to you.
  • You are trying to use an Office CD-ROM when you are prompted by the Windows Installer for an Office source location.
  • You click Cancel when you are prompted to insert the CD.
Because the files in an administrative installation are uncompressed, and the files on an Office CD-ROM are compressed, the Windows Installer cannot resolve the differences between the two source types. The resolution to this problem depends on whether you can obtain access to a network administrative installation. Use the following methods, as appropriate to your situation.
If the original administrative installation from which you installed Office is not available, you can use a different administrative installation for the Office source file location. To do this, follow these steps:
  1. Click Start and then click Run.
  2. In the Open box, type a command line similar to the following, and then click
    OK new network path\Setup.exe /fvm package name.msi
    where new network path is the full path to the alternative network administrative installation, and
    package name is the name of the Windows Installer .msi package on the root of this administrative installation (for example, Proplus.msi).
  3. Click OK when the update is finished.
HP Computers &... | Answered on May 24, 2020
https://www.youtube.com/watch?v=1_ssncypf_I
Factory reset the laptop! That will clean up the system and it will run as new.
HPHEWLETTPACKARD Refurbished HP XW8200 XEON 2.8GHZ 1GB DDR2 400 250GB SATA CD NVS280 XP PRO HPHEWLET... (C52468999BFM2) PC Desktop Logo
Popular Tags
6 questions posted
Top HP Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • HP Computers & Internet
Most Popular Question
buy used
  • Computers & Internet
