20 Most Recent HP Pavilion A520n (DW233A#ABA) PC Desktop Questions & Answers
go to microsoft and purchase the upgrade
HP Pavilion... • Answered on May 20, 2016
try a driver upgrading/downloading software
HP Pavilion... • Answered on May 10, 2014
Remove the recovery software it in safe mode. if safe mode have some issue in open then you need to install the OS again.
HP Pavilion... • Answered on Oct 05, 2013
For that open the cpu cabinet cover then reconnect RAM memory to motherboard.Reconnect ATX power connector to motherboard reconnect all connection to harddrive pull cmos cell from motherboard for 10 minutes then put it back then check. Also make sure motherboard is not ground with cabinet cover. Make sure smps is working fine. Pull the processor and it's fan then reconnect it then check. Let me know if you need further assistance. Thanks for using FixYa.
HP Pavilion... • Answered on Aug 19, 2011
On motherboard. Please, make sure all fans are connected into motherboard.Some fans can't plug in into the board at all. So, you can ignore those fans.When you go to Bios to check thermal condition, if a fan is not plug in, you can see 0 degree. 0 degree dosen't cause the shutdown problem. (That's why you can ignore)Then check which fans are causing problem, first. (If you did and found the problem, go next.)Replace fans AND clean those dust!If the problem remains, then replace its case to steel one. Well, usually a lifetime of CPU fan is pretty longer than others.Just in case, one more thing, if the thermal condition is OK, then the shutdown problem is caused by something ales!
HP Pavilion... • Answered on May 27, 2011
Below are some useful tips for making your PC's performance better.Please follow the below steps and fix your problem.
Eliminate Viruses and Spyware 1 . Run your antivirus program. There may be something slowing your computer that you can remove. It is a good idea to run your antivirus program every week.
2 . Remove spyware. Run a good spyware tool at least twice a month.
3 . Use a pop-up blocker, if you have one. Check your antivirus program.
Dispose of the Extras 1 . Delete your document files for anything you no longer need. Saved pictures, audio and video files in particular can slow your computer.
2 . Remove unwanted programs from the Control Panel area. Old toolbars or games the kids downloaded off the Internet are a good place to start.Look for software you no longer use, such as the old printer you threw out last year.
3 . Clean out your email. Old messages are a constant drain on your computer's resources. Go through every folder, deleting everything you do not need. Leave no mail! Finish by emptying the Deleted Items folder.
4 . Turn off unnecessary programs. Check your task bar for icons that show running programs. Disable anything you are not currently using.
Run Maintenance 1 . Run the Disk Cleanup tool located in your Control Panel. (Windows only. For other operating systems, please check the Resources section below.)This will remove temporary files, cookies and unnecessary components to speed up your computer.
2 . Defragment your computer. Defragging takes some time, but will speed your computer significantly. You can find the tool in your Control Panel.Run it monthly.
Hope the above information will be helpful to you. Thanks for using Fixya.
HP Pavilion... • Answered on Feb 03, 2011
The Green LED light flashing indicates a bad Power Supply. Weak voltage power rail.
http://h10025.www1.hp.com/ewfrf/wc/product?product=404643&lc=en&cc=us&dlc=en&submit.y=7&submit.x=7&lang=en&cc=us
Troubleshooting Power Supply Issues HP Pavilion A520n,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph06788&tmp_task=solveCategory&lc=en&dlc=en&cc=us&site=null&lang=en&key=null&product=404643#N207
Click on > Power Supply light is on or flashes
"If the LED is still flashing (it should not flash with all connectors removed), plug the power cable into a different power outlet that is known to be good. If the LED still flashes, the power supply should be replaced."
Cause?
The leading cause is the computer is dirty inside, to include the Power Supply
The next cause is that Electrolytic Capacitors have failed inside the Power Supply.
Solution is to replace the Power Supply.
The Power Supply used is the ATX form factor. The type of Power Supply used in over 80 percent of PC computers out there, and very readily available.
Size of the power supply case is approximately 6 inches Wide, 5-1/2 inches long (5.5), and 3-1/2 inches Tall. (3.5)
It is a 250, or 300 Watt generic unit, probably made by Bestec, Delta, or HiPro.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00072236&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&lang=en&product=404643
Scroll down to see the illustration and photo of the motherboard.
Power cables needed are;
A) 20-pin ATX main power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20
{ ATX power supply's today come with a 20 + 4-pin ATX main power cable.
The power cable can be used as a 20-pin, or a 24-pin.
Add the 4-pin connector to make it a 24-pin, or do not use it, and have a 20-pin }
B) Enough standard 4-pin Peripheral power cables for the IDE (PATA) harddive, {1}, and the optical drive/s.
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
Today's power supply's come with either at least 4, or 6 of these power cables.
C) One Floppy Drive power cable.
Won't be used for a Floppy Disk Drive on your computer. It's power for the Memory Card Reader.
http://www.playtool.com/pages/psuconnectors/connectors.html#floppy
All of the above power cables are typical when purchasing an ATX power supply today.
Need guidance in choosing a Power Supply, please state in a Comment.
Regards,
joecoolvette
HP Pavilion... • Answered on Nov 30, 2010
HI!
You can get it from the link below...
http://www.usedlaptops.com/
HP Pavilion... • Answered on Aug 18, 2010
unplug the power cable, and remove the bettery from the mother board, and the ram 2, wait for 5 minutes then try again...hope it will help
HP Pavilion... • Answered on May 11, 2010
ebay.com ;)
or you can try compusa.com
if that doesnt work just call 1-800-711-2884 HP tech support number and ask them ;)
HP Pavilion... • Answered on Apr 27, 2010
hello, I recommend running a computer drive defragment.
also run a spyware/malware check. your computer may be infected.
HP Pavilion... • Answered on Apr 14, 2010
Go to crucial.com and have them analyze your computer. They will tell you you can use 2gb, no matter what HP says, and it does work. I just went through the same thing. Saved me from buying a new computer because 1gb wasn't cutting it and I originally thought that was the max for a a520n. Not true. I do suggest going to HP and getting the Bios update from 2005 if you haven't already done that. My a250n runs great with 2gb ram, replacement 500 watt power supply, GeForce 6600gt GPU, and Audigy SE sound card. With optimized paging file and routine disk cleanup this thing still runs well enough to have a few years left in the old girl untill every new program requires dual or quad core 64bit technology and Windows 7 or above.
HP Pavilion... • Answered on Mar 17, 2010
open the iTunes player and in the HELP tab you will find RUN DIAGNOSTICS check only the CD/DVD drive tests and push NEXT button before that insert an recorded audio CD in your optical drive if you have problems with your optical drive , the run test will tell you.
HP Pavilion... • Answered on Feb 28, 2010
HP Pavilion A520n (DW233A#ABA) PC Desktop Logo
Popular Tags
46 questions posted
Top HP Computers & Internet Experts
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Pavilion HP
  • Pavilion HP
Most Popular Question
ethernet controller driver
  • Computers & Internet
