20 Most Recent HP Pavilion a450n PC Desktop Questions & Answers
Please contact the reseller that sold you the computer
HP Pavilion... • Answered on Oct 06, 2016
Next time you put the password, make sure the box is checked that says "save password" or it will ask every time.
HP Pavilion... • Answered on Sep 18, 2016
change the video card or check the cable.
HP Pavilion... • Answered on Sep 16, 2014
i) usually an computer enter's into power saving mode if computer monitor is not receiving any singals from the computer tower, so it has nothing do withur computer monitor(computer monitor is working fine), there is some problem withur computer tower.
ii) now try  removing all the physical connections going to computer tower(back side), wall socket  and replace them ....., (to avoid loose connections)
   now see whether ur computer is turning on and working properly so that your computer monitor receive singals ....
  let me know what is happening
Thanking you
M. Sridhar
HP Pavilion... • Answered on Aug 29, 2014
Make sure that the connections are tight. and plugged into wall. If this wont turn it on monitor may be bad. try different cable and/or monitor.
HP Pavilion... • Answered on Aug 26, 2014
You should search Google for Norton Removal Tool and run it or you can also download Revo Uninstaller to do the same. Also you may already be infected so make sure the system is cleaned up. Online virus removalWindows8Blog
HP Pavilion... • Answered on Feb 05, 2014
A dead battery should not slow you down. Sometimes it might stop the machine booting, but if it gets that far it should run normally apart from the time...
HP Pavilion... • Answered on Feb 04, 2014
If you are looking for an operating manual, use this link (as of 5/5/2013):http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_GX8250_EN_215.PDF
HP Pavilion... • Answered on May 06, 2013
unplug and wait a min. or so, plug in, try again. if that fails, reboot, try a system restore/recovery. If that fails, boot to safe mode with networking, download MALWAREBYTES freeware at : http://www.filehippo.com/download_malwarebytes_anti_malware/ Run a FULL SCAN, DELETE ALL RESULTS, REBOOT. For further assistance respond to this post.
HP Pavilion... • Answered on Dec 24, 2012
It may be because of an y virus or trogans in your pc. Just format your c drive and reload the operating system. And before accessing other drives and internet install any antivirus softwares and update it immediately when connected to net.
HP Pavilion... • Answered on Oct 08, 2012
Test your PSU power supply unit or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle of restarting or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive power and data cables IDE SATA
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty make sure all leads that are attached to your dvd\cd floppy drives have secure connections and are not faulty or just replace them they could be faulty computers need power and data to travel through every working device to continue its cycle and have an end so any faulty leads will end up with a computer error even something as small as a faulty electrical or fan lead can cause you problems
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail
check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
also check the Cmos battery and computer RAM modules make sure they are securely seated with no dust built up or in the sockets on some motherboards cmos batteries are soldered in check you CPU central processing unit make sure its securely seated and has thermal paste it might be getting to hot the thermal paste will help disperse the heat Thermal compound is a sticky paste that is placed directly onto the CPU. Allowing for a more direct heat transfer between the CPU and HEAT SINK and preventing air gaps from forming between the CPU and heat sink. hope this helps
HP Pavilion... • Answered on Jul 31, 2012
Any monitor will do unless you are trying to get one with the built in speakers that you have. Just make sure the monitor has the same type of connection that you currently have (VGA, DVI, HDMI, etc).
HP Pavilion... • Answered on Apr 26, 2012
Hi,AGP graphics cards are no longer available in most stores. Your best option would be to browse classified ads in your area to find a used AGP card. If this is not possible in your area you could also find AGP cards on-line at web sites like www.ebay.com These on-line items can be paid for by credit card or Paypal in most cases and will often include packaging and shipping to your location.Best wishes,Graemevm
HP Pavilion... • Answered on Jan 10, 2012
1st check the power if power iz ok u hv 2 install the windows
HP Pavilion... • Answered on Sep 01, 2011
Hi wjbrummel,
I see that you are experiencing issue with your HP desktop.
I saw on your post that you mentioned you tried troubleshooting the issues and see that you basically did everything possibl;e to see if the machine still works, yes it has power but the main thing is it show that the Motherboard is not responding at all in you case.
I would suggest removing the CMOS battery from inside the machine hold it in between your fingers then touch the side of the battery onto a Metal thing for only 2 seconds then place it back in the motherboard. then try powering the machine back in again to see if this does not help then most probably the motherboard just gave way and may need replacing.
I hope this clears the issue.
Have a nice day,
mvincentc
HP Pavilion... • Answered on Jun 25, 2011
If I've got the right unit, you have an AGP 8x slot which means you can get an AGP 8x graphics card. The selection of the AGP cards is not what it used to be so you make have to upgrade your PSU, depending on whats avalable. If I'm also got the right unit, it came with Nvidia GeForce FX5200 graphics and, I'm guessing that is intigrated. If the fan is a problem for you, you can get "spped fan" here:
http://www.almico.com/speedfan.php
This will allow you to adjust your fan speeds.
As far as a Graphics card goes:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161318
Something like this would work for you, it requires a 300w power supply, others are available. The thing I like about the Radeon HD cards is that your can get the graphics and they have built in sound as well. If it doesn't come with the DVI adaptor, you can order one.
HP Pavilion... • Answered on Jun 20, 2011
HP Pavilion a450n PC Desktop Logo
90 questions posted
Top HP Computers & Internet Experts
Michael Thomas
Michael Thomas
Davit Mamyan
Davit Mamyan
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Pavilion HP
  • Pavilion HP
Most Popular Question
hp tower turns off itself after minute
  • Computers & Internet
