Those are symptoms of the mix refrigeration system being undercharged. You will need a refrigeration technician to add refrigerant.
In Taylor soft serve machines when the left side hopper (standing in front of the machine) is icing up and the right side hopper is not cold enough, the problem is low refrigerant in that system. It takes R134A.
Soft Serve Parts C713
Hello Terry Fraser,
Black & Decker Frozen Dessert Maker model IC5 CAT NO 35 / 09
The one site that continually pops up (but requires FREE TRIAL)..
is the top URL hyperlinked below "manuals on line"
I tried the D+D online site... but their newer arctic twister keeps getting in the way.
Alternatively "Sears" while pretty pricy for parts & service does have really extensive libraries on appliances big and small...
Once upon a time when I was probing cyberspace for their ""Space Saver"" toaster information.. I figured out who the SOLD their design to... and got my success there...
Sorry I only found the IC200 this morning... but the top URL below does look promising (free trial)... I'm saving my free trial for MY own antique appliances.
Good luck with your quest!
http://kitchen.manualsonline.com/support/black-decker/frozen-dessert-maker/looking-for-a-black--decker-glacier-ice-cream-mak-5391808
membership site
http://kitchen.manualsonline.com/manuals/mfg/hotpoint/dishwasher.htmlMagimix Ice Cream Maker 11048 Le Glacier 1 5 White
a few potential causes and solutions you can explore:
Low Mix Level:
Problem: The MIX OUT light is on, indicating that the mix level is low.
Remedy: Add more mix to the mix hopper and return the machine to AUTO mode.
Power Switch Position:
Problem: The power switch might be in the OFF position.
Remedy: Ensure that the power switch is set to ON and select AUTO mode.
Machine Not in AUTO Mode:
Problem: The machine might not be in AUTO mode.
Remedy: Select AUTO mode and allow the machine to cycle off before drawing product.
Beater Motor Reset:
Problem: The beater motor might be out of reset, and the BEATER OVERLOAD message is displayed.
Remedy: Turn the machine off, press the reset button, and restart it in AUTO mode.
Freeze-Up or Blockage:
Problem: There could be a freeze-up in the mix inlet hole or an issue with the feed tube.
Remedy: Call an authorized service technician to address the issu
If the left side of your Taylor 754-27 ice cream machine is freezing in the tub but not in the barrel, there could be a few potential issues to consider. Here are some possible causes and troubleshooting steps:
1. Insufficient refrigerant flow: Check if the refrigerant flow is restricted or inadequate, which can prevent proper freezing in the barrel. Ensure that the refrigerant lines and valves are clear and not blocked or clogged. You may need to clean or replace any filters or strainers in the refrigerant system.
2. Temperature control malfunction: Verify that the temperature control settings are correct for the barrel freezing process. The control thermostat may be faulty and need replacement. Check the temperature sensor and wiring connections to ensure they are in good condition.
3. Insulation problems: Examine the insulation surrounding the barrel to ensure it is intact and properly insulating. Insufficient insulation can lead to the barrel not freezing as expected. If the insulation is damaged, replace it with appropriate insulation materials.
4. Barrel motor or drive system issues: If the barrel is not rotating properly, it may result in inadequate freezing. Check the motor and drive components responsible for rotating the barrel. Look for any signs of wear or damage and ensure they are functioning correctly. Lubricate the drive system if necessary.
5. Refrigeration system malfunction: A problem with the compressor, condenser, or evaporator can impact the freezing process. Inspect these components for any signs of malfunction, such as unusual noises, leaks, or inadequate cooling. If any issues are found, it is advisable to contact a professional refrigeration technician for repair or servicing.
6. Improper assembly or installation: Double-check the gaskets, seals, and o-rings that were replaced during maintenance. Ensure they are properly installed and creating a tight seal. Any gaps or leaks in these components can affect freezing performance.
If you have attempted these troubleshooting steps and the issue persists, it is recommended to contact a professional technician who specializes in Taylor ice cream machines. They will have the expertise to diagnose and repair the specific problem with your equipment.
Might help
Standby Mode deactivates the beater and keep the ice cream cold. When you come off Standby, the ice cream warms a little and the beater starts. You can be in standby Mode as long as you like, It keep the ice cream mix in peak condition. There will be a short delay in serving the next customer.
Standby (US and Canada Only) During long no-sale periods it becomes necessary to warm product in the freezing cylinder to approximately 35°F to 40°F (1.7°C to 4.4°C) to prevent overbeating and product breakdown. When the STANDBY button is pressed, the light comes on, indicating the cylinder temperature retention system (CTR) has been activated. In the Standby mode, the Wash, Pump, and Auto functions are automatically canceled. The Mix Ref function is automatically locked in to maintain the mix in the cabinet. To resume normal operation, press the AUTO button. When the machine cycles off, product in the freezing cylinder will be at serving viscosity.
Manual
https://www.taylor-company.com/assets/pdfs/downloadables/8752_8756_8757op0.pdf
Under normal operating conditions, the C712 will enter freezer lock when the temperature of the barrels or hoppers have been above 41 degrees for too long. It requires you to do a cleaning cycle. You will have to empty the machine of product, rinse it out, remove the freezer door, and shut the machine off. once the machine is off you will see a 5 minute timer and 4 temperature readings. That timer wont start unless all 4 temperature reading are above 60 degrees F. once the timer reaches zero, the machine will unlock and your brush cycle timer will reset to 00. The brush cycle timer is underneath your main display. Your main display should now show "Power Switch Off--- Unit Cleaned" and you can now reassemble your machine and can use it.Some causes: Low product with a lid off. During a cleaning cycle, the barrels take longer to come up to temperature than the hoppers. Its entirely possible to thoroughly and properly clean the machine without satisfying the temperature requirements. The machine doesn't register the cleaning cycle and you reassemble the machine. The machine doesn't know you cleaned the machine so it was still keeping track of how long the temperatures were above 41 degrees and as soon you try to put it in auto or standby, it goes into a freezer locked condition.One of the probes may be failing. You can check this by going into "Current Conditions" in your managers menu. You'll see the 4 temperature readings and if one of them is a lot higher or lower than the actual temperature of the product that could be an indicator of a failing temperature probe.www.softserveparts.com
https://www.taylorfreezers.com > contact-us
Taylor Freezers of California - Los Angeles - Headquarters Hours of Operation: 8am - 4:30pm, Monday - Friday 6825 E. Washington Blvd. Commerce, ...
Something on the left side has broken or become disconnected. The churn motor is very powerful. You need a service call out.This shows the inside and the size of the motorhttps://www.bid-on-equipment.com/restaurant-equipment/concession/ice-cream-machines/336917~taylor-794-33-ice-cream-machine.htmhttps://www.google.com/search?q=Taylor+794..
