20 Most Recent HP Pavillion a818n Desktop PC (Refurb) Pentium 515(2.93Ghz) 512MB 160GB (PS453AAR) Questions & Answers
A warranty is a contract between the Buyer (You) and the Seller (Retailer, Wholesaler, or Manufacturer/Hewlett Packard?). If you don't have a copy of your warranty, then you'll have to contact (Via phone, mail, or website) Hewlett Packard or whomever your warranty is with, and with your model and serial number you should be able to find out the date you request.
Good luck.
HP Pavillion... • Answered on Nov 17, 2019
Step 1: 1 long, 1 short beep : System board problem 1 long, 2 short beeps: Display adapter problem (MDA, CGA) 1 long, 3 short beeps: Enhanced Graphics Adapter (EGA) 3 long beeps : keyboard card The beeps are post during post the very first work is done by the RAM , all the memory in the RAM is first transferred to the hard disk,and remains active untill turned off. WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Make sure that your RAM modules and Cmos battery are securely seated on some motherboards Cmos batteries are soldered in. Test all power and data leads that attach from Motherboard to your Hard Drive IDE SATA Make sure they have a secure dust free connections if its a flat 40 pin ide it will be the first to fail Check the graphics card is seated properly with no dust in the socket you might have to remove it to check for dust reinstall it. Restart your computer the found new hardware wizard should activate A computer needs power and data to travel through every working device and to its continue its cycle and to have and end to function. Make sure all leads that are attached to your drives dvd\cd and floppy drive have secure Make sure the connections and are not faulty or just replace them they could be faulty A computer needs all electric current and computer data to travel to and through every working device and have an end to work properly so any faulty leads will end up with a computer error. Also check the Keyboard for secure dust free connection ps2 and or usb. Click start control panel administrative tools computer management device manager scroll through devices if you see a yellow Question / Exclamation ? ! or a Red X a new driver will need to be installed / updated. Right click to update driver. If you computer came with a motherboard disk the drivers could be on it. Rather doing a driver hunt which can take hours http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html Windows XP/Vista/7/8 it might take some time being a freeware driver solution note: it will find all of your outdated drivers This is a free driver solutions. This will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point. Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated.
HP Pavillion... • Answered on Mar 03, 2013
The support page can be found HERE. Chose to download drivers and pick your operating system.
HP Pavillion... • Answered on Aug 26, 2010
With IE8 open, Go to Tools>Internet Options>Advanced Tab...at the bottom click the Reset button to restore IE to its original default settings. Should work.
Respect....
HP Pavillion... • Answered on Jul 23, 2010
Make sure you have also installed service pack 3. This should get you back online with IE.
Good Luck
C2S
HP Pavillion... • Answered on Jul 12, 2010
Open Device Manager from Control Panel and check there are no yellow exclamation marks on any drivers. If there are then you need a new driver.
You need to goto the manufacturers website, find their support section and there should be a list of drivers for your specific machine. Installing these should resolve your problem. I have a list of links to most manufacturers drivers on my website.
Hope this helps,
www.PuterCare.com
HP Pavillion... • Answered on Jul 07, 2010
Sounds like your photo program in configured wrong, The printer will draw it's setting from the default printer for the program and if you have the photo program set up to print in black and white then this is what the printer is going to do. Check the settings in your photo management software and see what they are
HP Pavillion... • Answered on Jun 20, 2010
reinstallt the operating system
HP Pavillion... • Answered on Jun 17, 2010
you have no sound driver on your system the best thing to do is by you reaching this website and download it free from there i have already process everything for you . you are to click on download alone and wait for the downloading completion then you can now follow the prompt in installing it .
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=228&lc=en&cc=us&dlc=en&sw_lang=&product=453536#N653
then download it for free and double click the downloaded software and follow the guide it prompt you . finish it thats all..but allow it to load itself dont utter anything in other to avoid corruption of file.
HP Pavillion... • Answered on May 20, 2010
Why would you want to re-install a program which broke your system? I would feel fortunate there was no other damage done and move on. Even when you think you have the whole program wiped out, they still leave clutter hanging around, so, use explorer to go through your computer and get rid of everything to do with that program, unless it it now shared with another program.
HP Pavillion... • Answered on Mar 21, 2010
Check your cable first.
You aren't getting a signal from your video output, so make sure the video card is seated on the motherboard.
If you have onboard video, then you may have other problems
HP Pavillion... • Answered on Mar 09, 2010
Link for ya... might ahve to go into safe mode.... this should walk you through it
http://windows.microsoft.com/en-US/windows-vista/Startup-Repair-frequently-asked-questions
Peace,
HP Pavillion... • Answered on Mar 07, 2010
that could be a few difrent things
first i would try cleaning the registry with something like registry mechanice
http://www.pctools.com/registry-mechanic/download/
or you can go for the gusto and reformat the system
the reboot problem is caused from a corupt registry
best of luck whatever you chose to do
HP Pavillion... • Answered on Feb 25, 2010
If u want to configure windows mail it is not possible till u get a PREMIUM ACCOUNT from yahoo i.e a paid account from yahoo
HP Pavillion... • Answered on Feb 04, 2010
what is the issue you're having?
HP Pavillion... • Answered on Jan 18, 2010
You should try to request help from Yahoo. It's possible that your user file got messed up or you're simply using the wrong password. Try asking them to send your password to your e-mail, (unless they ARE your e-mail account). In that case, contact them and see if they can reset your password or you may just have to create a new account.
HP Pavillion... • Answered on Aug 20, 2009
First thing is do you have a beep when the system boots? Sounds like you may have a BIOS issue I would start there........your RAM and processor are more than likely NOT the problem
HP Pavillion... • Answered on Jul 31, 2009
uninstall your quictime and itunes then install it back.tnx
HP Pavillion... • Answered on Jul 30, 2009
Computers & Internet Logo
39 questions posted
Top HP Computers & Internet Experts
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • HP Computers & Internet
Most Popular Question
am working computer running windows 7
  • Computers & Internet
