20 Most Recent Camco Copper And Zinc Standard Hwd Water Heater Screw-in Fold Back Element Questions & Answers
No.
Fold-back elements are low-watt-density, so element does not burn out as easily since heating is spread across more surface area. But recovery remains 16 gallon per hour.
20 amp breaker and 12 gauge wire: max 3800 watts
30 amp breaker and 10 gauge wire: max 5800 watt.
4500 watt element heats 20 gallons per hour.
http://waterheatertimer.org/How-to-replace-water-heater-element.html
http://waterheatertimer.org/Increase-amount-of-hot-water.html
Instead of changing elements: Set thermostats higher so more cold is added to hot water, and then you have more hot water available inside tank.
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Camco Copper And... | Answered on Jan 05, 2014
here mate try this it worked for me.
Press left key
Scroll till page 15
Code will say 000 - should be 1000
Press right key once change first digit to 1
Press right key again
Will be on C1 in top right hand corner
Scroll through C pages till A1
Two A1 pages looking for one that says de..utch
Click right key once and change to d.. English
Water Heaters | Answered on Jan 04, 2021
The red LED may be indicating that the temperature control has failed.
Water Heaters | Answered on Jan 02, 2021
Contact Titan to request the information.
Water Heaters | Answered on Dec 16, 2020
Jennifer, the instructions posted by Rheems on the heater are wrong. You must first rotate the dial clockwise, use force (in our our case) to get the pilot to its position. The folks at Rheems are nuts not to check their instructions before printing them and plastering them on their hot water tanks. Disgraceful, period.
Water Heaters | Answered on Nov 28, 2020
I have taken pictures and produced a wiring diagram for this model
Water Heaters | Answered on Nov 09, 2020
when cycling to start check ignitor see if it glows if no check voltage to it if yes replace ignitor
Water Heaters | Answered on Nov 01, 2020
look for display or control board if no buttons then cant adjust
Water Heaters | Answered on Oct 22, 2020
Automatic battery chargers have complex circuitry that is difficult to test especially when designed and built in a compact package and repairs are best entrusted to someone geared to such work which is outside the scope of general electronics.
On the plus side, as long as the intelligent circuitry is protected against mains borne surges and spikes the automatic charger is somewhat self-protecting against over stress and will tend not to even attempt to charge a defective battery, a sulphated or overly discharged battery.
I suggest you first check the battery or batteries to ensure they are healthy and have some charge so the charger can "see" them before condemning the charger and also check the connections to the battery that must be virtually perfect...
Water Heaters | Answered on Oct 05, 2020
Depends on the problem you have .if you are unable to fix it the option of calling a plumber is there .
Water Heaters | Answered on Sep 07, 2020
When the noise occurs when there is no hot water being used, it's likely there is a vacuum that's siphoning water away from the unit and causing loud noise and vibration. ... Another common problem that can create noise in tankless water heaters is a dirty flow sensor which controls how much gas is sent to the unit.
https://www.youtube.com/watch?v=Fsb8Wx9PRvY
Water Heaters | Answered on Jun 24, 2020
NO HOT WATER
  1. If the tester indicates there is power to the terminals and the water in the geyser is cold, then the element is faulty. ( ...
  2. If the tester indicates there is no power to the terminals and the water is cold, then the thermostat is faulty.
https://www.youtube.com/watch?v=qCXmyhEY_k4
Water Heaters | Answered on May 06, 2020
Maybe. Knowing what it is that is generating error code E34 would be good start. Need manufacturer and model number.
Water Heaters | Answered on Mar 02, 2020
depends on the RV & the heater. I have seen some heaters that work on both options.
Water Heaters | Answered on Jan 11, 2020
DOWNLOAD LINK
http://www.dl4all.com/aka/tag/osaka+gas+fan+heater+user+manual.html
OR
http://www.osakagas.co.jp/indexe.html
Water Heaters | Answered on Jan 10, 2020
Camco Copper And Zinc Standard Hwd Water Heater Screw-in Fold Back Element Logo
1 questions posted
Top Camco Water Heaters Experts
Paul Carew
Marvin
Marvin
Are you a Camco Water Heater Expert? Answer questions, earn points and help others
View Most Popular
Camco Water Heaters
  • Camco Water Heaters
Most Popular Question
hot water recover time
  • Water Heaters
