20 Most Recent Danby "DDW1899WP 18"" Portable Dishwasher with 6 Wash Cycles, Built-In Water Softener System, Energy Star Qualified in White" Questions & Answers
Why won't my portable dishwasher work?
Recommend check door closed and not blocked; sprayer not blocked, dispenser not clogged, door latch locking and latch sensor connected and conducting.
1/2/2015 10:32:45 AM • Danby "DDW1899WP... • Answered on Jan 02, 2015
I have a Danby countertop dishwasher, DDW611WLED it started leaking and I saw that the bottom seal was pretty much disintegrated. Can't find the bittom seal anywhere.
Don't Worry. Google is your friend... Google Search your Make & Model number & Add service manual, service manual.pdf download, ,service manual parts list, Schematic , or just parts List. Google will bring up a vast amount of information & most of it not what you are looking for BUT If you adhere your search specifically for the information you require, It Should bring up what you are looking for as well as Outlets & phone number you can call to check for such parts. Don't be afraid to Be a little cheeky over the telephone & Ask (if they can't help) if they can recommend an outlet that could help.. OH and have they got that particular number too ;)
3/15/2024 11:30:06 AM • Danby... • Answered on Mar 15, 2024
2answers
I installed a Danby DDW1804EBSS Dishwasher and it will fill up and drain properly but will never initiate the wash cycle.
try unpluging it for 10 minutes to hard reset.
4/15/2023 5:12:19 PM • Danby... • Answered on Apr 15, 2023
TURN OFF CHIMES ON DANBY PORTABLE DISHWASHER DDW1805EWP?
Please someone must have an answer for this. Does setting the start timer for an hour start time; silence the end-of-cycle beep?
3/1/2023 2:08:55 AM • Danby... • Answered on Mar 01, 2023
5answers
I have a Danby DDW621WDB portable dishwasher. It's stuck with the "glasses" light blinking and a beeping noise. It didn't pump out the water properly and there are no clogs in the hoses.
"You may need to tip the dishwasher forward, use a towel as water will get every where otherwise. "
This worked! My dishwaser was properly draining, but this time it stucked with the blinking glass light. Powering off/on, didn't work.
I tipped it forward and a little bit of water fell off of the bottom front panel. Pluged it back and it now works! Thanks!
12/16/2022 8:43:39 PM • Danby... • Answered on Dec 16, 2022
Dishwasher doesn't wash. Only fills and drains.
Wash pump went out. Drain pump still works.
Not enough water. Improper water fill.
10/3/2022 2:08:41 PM • Danby... • Answered on Oct 03, 2022
Danby 6 Place Setting Countertop Dishwasher won't turn on
Is the outlet controlled by a switch? Is the power button turned on? Is the door closed shut. If you've been running this dishwasher for a year means you know how to use it. I think a malfunction of some kind. Usually an error code will appear but no power.... No code
6/28/2022 8:44:35 AM • Danby... • Answered on Jun 28, 2022
2answers
DDW1809W-1 still acting up after I went back to normal dishwater soap
Turn off the mains power overnight. Run two cycles with no detergent. You can put lightly soiled items in and they should still come out reasonably clean.
6/20/2022 6:44:26 AM • Danby... • Answered on Jun 20, 2022
Hello, can you help me take apart the pieces to get to my leaking problem?
You can normally access through the base or from the back panel.
2/21/2022 10:25:26 PM • Danby... • Answered on Feb 21, 2022
Danby DDW1899WP Portable Dishwasher will no longer turn on
If it just has no water, then it would be a fairly safe bet it was the water inlet valve. If it is completely unresponsive, that points to either a power issue or a control board issue. You will need a Service Technician, and you may be better off with a new one depending on the age of it. The reviews put it at about 3 years old and $429. It is more of a freestanding machine that portable, it just has wheels. It looks useful. https://www.google.com/search?q=Danby+DDW1899WP+reviews
DDW1899WP-1 ' Danby 8 Place Setting Dishwasher ' EN ...
https://www.danby.com > products > kitchen-en-us > d... Description. Washing dishes has never been as much fun as it is with this versatile dishwasher by Danby. This attractive machine comes with a silverware basket, ... ....
1/7/2022 11:03:15 PM • Danby... • Answered on Jan 07, 2022
2answers
Danby DDW631WDB Dishwasher E4
Yes, it is an overfill situation. Check out the videos in the link. https://www.google.com/search?q=dishwasher+Danby+DDW631WDB+E4+error You are only just out of warranty https://storeca.danby.com/pages/danby-certified-product-warranty Are you registered here? https://www.danby.com/support/warranty-look-up/ ..
1/4/2022 8:53:44 AM • Danby... • Answered on Jan 04, 2022
2answers
I have a Danby dishwasher model #DDW1809W that will not fill with water
I would check the water solenoid firstly as the sensor detects water level and if the sensor thought the level was too high, it would command the outlet pump on until the level went down.
1/1/2022 8:36:40 PM • Danby... • Answered on Jan 01, 2022
My danby 18 in portable dishwasher stopped running. No power at all. smelled burning rubber for a couple of days before. is it the power cord?
we have no way of knowing as remote testing has not been developed yet
11/27/2021 8:20:46 PM • Danby... • Answered on Nov 27, 2021
2answers
How do I get door open on New Danby dishwasher
When the dishwasher is new, it’s harder to open. There is no button, just the handle. Pull hard and it will open.
6/10/2021 6:13:14 AM • Danby... • Answered on Jun 10, 2021
2answers
Trying to find out where to put the soap in my danby countertop dishwasher
It go’s in the soap dispenser located inside the door. Be sure to close it’s lid after adding detergent.
5/17/2020 3:04:09 AM • Danby... • Answered on May 17, 2020
2answers
My danby dishwasher door will not open
Perhaps it has an electric lock that locks the door whilst it is running to prevent you getting scalded by the hot water whilst it is running. If so, perhaps that latch is broken, or the control is broken, causing this. Try disconnecting the electricity and see if it will then open. God bless your efforts,
12/31/2019 5:10:15 PM • Danby... • Answered on Dec 31, 2019
My Danby dishwasher door wont open?
Hi there, is it in use? did it fail or get damaged in use? unplug it or flip the breaker for it for about a minute. Did the cycle complete? press and hold cancel/drain first to see if that helps. Good luck to you https://www.6ya.com/mr.mike
2/4/2019 8:48:44 AM • Danby... • Answered on Feb 04, 2019
Danby "DDW1899WP 18"" Portable Dishwasher with 6 Wash Cycles, Built-In Water Softener System, Energy Star Qualified in White" Logo
1 questions posted
Top Danby Dishwashers Experts
Mike Cairns
Mike Cairns
ADMIN Andrew
ADMIN Andrew
Are you a Danby Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
Danby Dishwashers
  • Danby Dishwashers
Most Popular Question
  • Dishwashers
