20 Most Recent Nostalgia Electrics RKP-630 Retro Kettle Popcorn Maker Questions & Answers
What kind of ice cream maker is it? I just bought a Nostalgia Electric Double Flavor Ice Cream Maker and it did the same exact thing. I poured the salty ice water out in some containers, set it aside to use it again, took everything apart, and started over from the begining. I put it all back together properly again, added the salty ice water once more, and turned it on. It worked! I hope it does the same for you. If not, I would see about getting it looked at somehow.
Good luck! :)
Nostalgia... | Answered on Jan 14, 2011
Contact the manufacturer and request a copy of the manual.
Ice Cream Makers | Answered on May 09, 2020
if you had used your initiative to try google, you could easily have found this:
SOLVED: Ice Maker Model JS-ZBJ need instructions - Fixya
www.fixya.com/support/t3954601-ice_maker_model_js_zbj_need_instructions
Jan 23, 2010 - Ice Maker Model JS-ZBJ need instructions I have an Ice Maker Model JS-ZBJ am looking for a manual or something to - Refrigerators question. I need a user manual for a Perfekt JS-ZBJ-A Ice Maker
Mar 26, 2018
SOLVED: Instruction manual for Perfekt JS-ZBJ-A
Jan 16, 2013
Ice maker js-zbj-A not making ice
Jul 5, 2012
Questions, Troubleshooting Help & Support Page 6
Jul 28, 2006
More results from www.fixya.com
i
f you don't bother to try, you just wait for someone to answer your question.
Ice Cream Makers | Answered on Mar 26, 2020
My friend bought this item last week at Target for the $99 sale price. The reviews were all horrible about the red light (add water) indicator going on after the first or several first ice cube runs and never going out. About 40 out of 60 reviewers had this problem. We experienced it right after the first run when the ice cube full light went on. We emptied it and the add water red light was on. I looked all over the web for a solution and only found one that suggested tilting the unit backwards for 45 degrees and that would magically reset the light. It did not after several angles, light taps and basic shaking. Since there was no alternative and everyone who returned it also got the exact same problem with the new replaced model - we decided to open it up and investigate.
The electronics diagram is on the back of the machine and tell you where the water indicator is. We took it out (an inch long black tube along the water pump and backflow valve) and dried it completely. The cycle still had the red light. We submerged it completely in water and the red light still went on saying that the unit needs water. We determined that this is the bad part and the water indicator is faulty. We cut it out and joined the two wires. IT ALL WORKS NOW FLAWLESSLY. You only have to shut the unit off when you leave since it will ocntinue to run if out of water. If you're looking for a quick mechanical fix and have a unit that works when you need it and you are around - this isthe fix.
Ice Cream Makers | Answered on Jan 25, 2020
In 1911, Frederick Taylor published The Principles of Scientific Management, in which he explains how productivity can be greatly improved by applying the scientific method. ... Scientifically select, train, and develop each worker rather than passively leaving them to train themselves.
Ice Cream Makers | Answered on Aug 18, 2019
Nostalgia Electrics RKP-630 Retro Kettle Popcorn Maker Logo
3 questions posted
Top Nostalgia Electrics Ice Cream Makers Experts
Marvin
Marvin
ray gallant
Tom Chichester
Are you a Nostalgia Electrics Ice Cream Maker Expert? Answer questions, earn points and help others
View Most Popular
  • Nostalgia Electrics Ice Cream Makers
Most Popular Question
need some parts rival beverage fountain
  • Ice Cream Makers
