20 Most Recent Taco 006-B4 1/40 HP Bronze Circulator Pump Questions & Answers
Is the control that operates the pump located in the storage tank? If so the pump not be pumping. A few factors might be needed to solve the issue.
Taco 006-B4 1/40... | Answered on Mar 11, 2015
There should be a calibrated adjustment knob on the thermostat.
Water Heaters | Answered Yesterday
Depends on the problem you have .if you are unable to fix it the option of calling a plumber is there .
Water Heaters | Answered on Sep 07, 2020
POSSIBLY AIR HAMMER YOU MIGHT NEED A PLUMBER TO ADD A RELIEF VALVE IN SYSTEM
Water Heaters | Answered on Aug 22, 2020
When the noise occurs when there is no hot water being used, it's likely there is a vacuum that's siphoning water away from the unit and causing loud noise and vibration. ... Another common problem that can create noise in tankless water heaters is a dirty flow sensor which controls how much gas is sent to the unit.
https://www.youtube.com/watch?v=Fsb8Wx9PRvY
Water Heaters | Answered on Jun 24, 2020
NO HOT WATER
  1. If the tester indicates there is power to the terminals and the water in the geyser is cold, then the element is faulty. ( ...
  2. If the tester indicates there is no power to the terminals and the water is cold, then the thermostat is faulty.
https://www.youtube.com/watch?v=qCXmyhEY_k4
Water Heaters | Answered on May 06, 2020
Maybe. Knowing what it is that is generating error code E34 would be good start. Need manufacturer and model number.
Water Heaters | Answered on Mar 02, 2020
depends on the RV & the heater. I have seen some heaters that work on both options.
Water Heaters | Answered on Jan 11, 2020
DOWNLOAD LINK
http://www.dl4all.com/aka/tag/osaka+gas+fan+heater+user+manual.html
OR
http://www.osakagas.co.jp/indexe.html
Water Heaters | Answered on Jan 10, 2020
Check the power? If you have power, the thermostat or element have failed
Water Heaters | Answered on Dec 21, 2019
untitled-undefined-undefined-0.png at the upper part of the heating element.. press that to reset.
Water Heaters | Answered on Dec 05, 2019
CONTACT OSAKA DEALER WE DO NOT RECOMMEND DIY FIXING THINGS THAT CAN GO BOOM IN YOUR FACE
Water Heaters | Answered on Dec 03, 2019
Hi Marty-
I found this link regarding your Paloma Tankless Water Heaters. There is a section on Troubleshooting FAQs. If you need additional technical support, there is a 1-866 number to call at the bottom of the link.
http://besttanklesswater.com/owners/homeowner+trouble.html
Hope this helps.
Water Heaters | Answered on Nov 27, 2019
Type of gas control valve is not known.
Brand of water heater is not known.
FV event can mean that air intake is clogged, gas control valve has gone bad, or FV system has tripped, or TCO has tripped ... or all of above.
Clean air intake, download manual from manufacturer and read troubleshoot section, call manufacturer.
Copy following links for troubleshoot resources
http://waterheatertimer.org/How-to-repair-Rheem-FVIR.html
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
http://www.thetankatwaterheaterrescue.com/forums/forum3/
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Water Heaters | Answered on Nov 19, 2019
Error codes for both types of honeywell gas control valves appear on following link...
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#honeywell
Whirlpool no longer sells water heaters ... but in the past, they sold the AO Smith brand flue damper and atmospheric heaters ... both use different Honeywell gas controls.
Water Heaters | Answered on Nov 10, 2019
Taco 006-B4 1/40 HP Bronze Circulator Pump Logo
1 questions posted
Top Taco Water Heaters Experts
Paul Carew
Marvin
Marvin
Are you a Taco Water Heater Expert? Answer questions, earn points and help others
View Most Popular
Taco Water Heaters
  • Taco Water Heaters
Most Popular Question
hot water not staying hot
  • Water Heaters
