20 Most Recent
Panasonic JU 257 (JU257A827P) Internal Floppy Drive Questions & Answers
Disk drive not reading disks.
Light
Turn the computer off.
Disconnect the ribbon-cable from the motherboard.
Flip it end-for-end.
Reconnect it.
Turn the computer on.
The light should normally be OFF, until you access the media.
Il computer non riconosce il
The device is "natively" supported by Windows XP.
It is not recognized, then it is "dead", and must be replaced.
It doesn't works
Does it work, if you install the disk-drive into a computer?
If not, then the drive is "dead", and needs to be replaced.
Panasonic JU- 257A686
The operating system you are using is pretty old....DOS uses commands that are typed without graphic user interface. It is probable that the drive is dysfuntional because of age/fatigue. You need to use newer technology. You can insert the same disc in a drive that is in a windows environment e.g Winows 95, 98 or XP. This disc will definitely be more expensive than your old dos-run drive, but am sure you will have a lot less stress. better still when you get this copy all your information on the system and use a better newer storage device like a flash drive, CD/DVD.....they are much better in terms of capacity and functionality.
Best
Download
ok ive not seen one of these in a long time most floppy drives do not need drivers i gus with this one there are jumper set up at the back
try setting it to slave mode
settings should be described underneth
Floppy disc driver
You need to find system informaton and drives in the bios. You have to tell the computer what kind of drive you have. When you are at the right place you will see a drop down menu choosing your drive type. Newer computers do not support floppies and have memory card readers instead. If this is the case you will have to get a USB floppy drive.
