20 Most Recent Summit SPWD1470C 24 Inch Washer Dryer Combo with 13.5 lbs. Wash Capa Questions & Answers
summit washers are prone to board failures i would say that is where the fault lies . thermafuse fuse means it has been overheating. means it can damage other parts. thermostat would thing that has just worn out thermostat can go if the unit overheats. under line is an electrical fault. but like i've said it is a common fault with this make and others. the main boards can only handle around 50c in temp after that they start to over heat and cause problems. the faults started when they moved the main board from the bottom to the middle.
Summit SPWD1470C... | Answered on Oct 25, 2013
I could not find a manual for your SPW2201SS, but I did find a manual for a SPW2200SS. (Look for clogged hoses, in and out!) Sadly it only lists three 'error codes' on Page 27 and they include: E10 E21 E31 Summit SPWD2201SS Washer download instruction manual pdf
Summit Washing... | Answered on Oct 28, 2018
E02 After starting or during the functions of filtering or/and heating, the water flow sensors do not detect water flow.
The 2 stopper caps have not been removed from inside the spa. ... Remove the filter set from inside the spa and push the filter or heat button.
Washing Machines | Answered Yesterday
This is the first time I have heard of a washer under the Grundig label - hopefully they aren't as complex and over-engineered as their original products.
Possible causes of no water in tub...
Failed water inlet solenoid valve.
Wiring fault.
Programmer.
Failed tub water level switch or blocked tube to the switch (if your washer uses a pressure switch to control level.
Door switch or wiring.
Washing Machines | Answered 3 days ago
Does it make a sound while you set it to drain?
If yes I'd check for a blockage within the drain system
That error is a drain error and it could be something in the line that you cannot see when you looked at and cleaned the filter. Any articles of clothing that may be at the inlet of the pump could cause it, You are going to have to lay the unit down if it is a top loader, in order to see the hoses and check them. It could also be the pump has failed.
DON'T LOOK ON FIXYA WE DO NOT HAVE PARTS
Washing Machines | Answered on May 27, 2020
YOU CALL THE LOCAL SERVICE PEOPLE WITHOUT PROPER TESTING TOOLS AND KNOWLEDGE SHOULD USE THEM
Washing Machines | Answered on May 26, 2020
ASK GOOGLE OR THE MANUFACTURER TECH SUPPORT
restart it, run a short cycle, check the drainage horse for clogs.
Washing Machines | Answered on May 25, 2020
Dwd-L142KC has a direct drive motor. A very common fault on this machine is that the drum shaft seal fails, letting water into the bearings which then starts to rust and then develope severe play between the drum and the tub. As the stator is mounted onto the tub and the rotor is mounted onto the drum shaft the rotor can then, due to the worn bearing, move too far away from the stator. Because the sensor that detects the actual speed of the motor is mounted onto the stator assembly, the control PCB then no longer gets the feedback signal from the sensor hence the motor not running correct. You'll most probably see the motor only moving in short bursts, a the missing feedback prevents it from accelerating further. A bearing and seal repair will in this case resolve this problem. It did on my machine. If the shaft is heavily worn below the shaft seal, this will need sorted in order to prevent the new seal from getting damaged or wearing out to soon
Washing Machines | Answered on May 24, 2020
Summit SPWD1470C 24 Inch Washer Dryer Combo with 13.5 lbs. Wash Capa Logo
2 questions posted
Top Summit Washing Machines Experts
ray gallant
Dai Boyce
Dai Boyce
 Russ Hill
Russ Hill
Are you a Summit Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Summit Washing Machines
Most Popular Question
summit washer dryer combo quit drying
  • Washing Machines
