20 Most Recent Simpson Westinghouse Dryer Mesh Lint Filter Questions & Answers
Simpson SWT1034 cycle won't end.
12/31/2023 10:14:59 AM • Simpson Washing... • Answered on Dec 31, 2023
My Simpson eziset 550 beeps as normal when I push any of the buttons but none of the display lights are working. There are no mechanical noises of it starting. the water is not flowing in
Faulty power switch or main control board: According to
, if none of the display lights are working and there are no mechanical noises, it's possible that either the power switch or the main control board is faulty and needs to be replaced. You may need a test meter and fault finding to determine which one is the problem.
Dead electronic controller: If there is absolutely no power at all on the control panel, the electronic controller may be dead, as suggested by
. You can try opening the top cover on the panel to see if there is any visible damage or loose connections.
Lid switch not closed: If the 3 water temp lights and the 5 beeps every 4 minutes are on, it means the lid switch is not closed, according to
. You can try closing the lid properly and see if it solves the problem.
10/16/2023 5:43:12 PM • Simpson Washing... • Answered on Oct 16, 2023
2answers
Simpson 4kg Ezi dryer. I changed the capacitor, but the motor is not working.
Im sorry I assume it was a dryer issue your having? but some of these same checks will work on a washer. Fist off I would check for bad fuse usually located along the drum lining. or in the panel board itself. test motor for bad centrifigal swtich? also a bad door switch or thermal fuse will stop it from operating at times also. there are several things to check, also check belt on tensioner it may have come off and in turn shut off belt switch? see my pics beltswitcht 5-undefined-undefined-0_2.jpg fuses dryercyclingfuse-undefined-undefined-1_4.jpg beltswitcht-undefined-undefined-2.jpg testdryerdoorswitch-undefined-undefined-3_0.jpg doorswitch test -undefined-undefined-4_0.jpg testmotorbeltswitch-undefined-undefined-5_0.jpg
7/22/2023 8:06:25 PM • Simpson Washing... • Answered on Jul 22, 2023
Simpson Aquarius 824. Washes fine but doesn't spin.
It could be power problems or the circuit breaker.The load in the washing machine is not balanced or there are too many clothes inside it.The wrong kind of detergent is being used.
7/16/2023 8:46:49 AM • Simpson Washing... • Answered on Jul 16, 2023
Simpson Aquarius 824 washing machine washes, drains but won't spin.
If your Simpson Aquarius 824 washing machine is not spinning, there are a few potential causes for this issue:
  1. Lid switch or door lock: The washing machine may have a safety feature that prevents it from spinning if the lid or door is not properly closed or the lid switch/door lock mechanism is faulty. Check if the lid or door is securely closed and ensure that the switch or lock mechanism is functioning correctly.
  2. Drive belt: The drive belt that connects the motor to the drum may be worn out or broken. If the belt is loose, damaged, or slipping, it can prevent the drum from spinning. Inspect the drive belt and replace it if necessary. Refer to the user manual or contact Simpson customer support for guidance on how to access and replace the drive belt on your specific model.
  3. Motor or motor control board: A malfunctioning motor or motor control board can also prevent the drum from spinning. If the motor is not receiving the proper signals or power, it may not engage and rotate the drum. In this case, professional repair or replacement of the motor or control board may be required. It's recommended to contact Simpson customer support or a qualified appliance repair technician to diagnose and resolve the issue.
  4. Other issues: There could be other potential causes for the problem, such as a faulty capacitor, wiring issue, or control module problem. These issues typically require professional diagnosis and repair.
It's advisable to refer to the user manual or contact Simpson customer support for specific troubleshooting steps and guidance tailored to your washing machine model. They will be able to provide more detailed assistance and advise on the best course of action for repairing your machine.
7/16/2023 2:57:39 AM • Simpson Washing... • Answered on Jul 16, 2023
My Simpson Esprit 600 washing machine won't start or even fill with water? The hoses are connected and power cord is plugged in but no go ?? Any ideas??
First check the breaker, as no power means nothing happens. If it switched on and had some lights or noises, the diagnosis for not filling would be the water inlet valve that had failed.
5/5/2023 7:52:02 PM • Simpson Washing... • Answered on May 05, 2023
Simpson existed 9.9 kg has a SP code flashing
3/28/2023 7:47:37 AM • Simpson Washing... • Answered on Mar 28, 2023
Service manuals for topload washing machine. Simpson enduro 801. Model 22s801?
The Simpson website may have a user manual. You could also try contacting Simpson customer service for help in obtaining a service manual.
3/15/2023 9:15:51 AM • Simpson Washing... • Answered on Mar 15, 2023
Simpson EZISet 950 not spinning (model no 22S950)
It could be many things. It the load is large and heavy, the machine electronics won't allow fast spin if the load is not even and even the slightest wobble will stop higher spin speeds. Here are a few things you can try. Split the load into two or three and then do rinse and spin. Other possibilities are a slipping belt due to the weight, or the speed processor on the motor.
3/7/2023 6:07:31 PM • Simpson Washing... • Answered on Mar 07, 2023
We have a Simpson aquaplus 713. We only use cold water, but that takes a very long time to fill even for a small load. Any suggestions?
Chech the screens by removing the fill hoses for build up of debris. They should be inside the fill assembly on the machine.
3/2/2023 12:27:17 AM • Simpson Washing... • Answered on Mar 02, 2023
I have a Simpson 1043 10kg top loader, it is displaying e90 intermittently before the spin cycle, e90 is supposed to be a communication error, any ideas?
If your Simpson 1043 10kg top loader is displaying an E90 error code intermittently before the spin cycle, it typically indicates a communication error between the control board and another component in the machine. Here are a few steps you can take to troubleshoot the issue:
  1. Check for loose connections: Make sure all connections between the control board and other components, such as the motor and the door lock, are secure and not loose or corroded.
  2. Inspect the wiring harness: Check the wiring harness that runs between the control board and other components for any signs of damage or wear. Replace the wiring harness if necessary.
  3. Perform a reset: Try resetting the machine by turning it off at the power source for a few minutes, then turning it back on. This can sometimes clear up communication errors.
  4. Check the control board: If the above steps do not resolve the issue, it's possible that there is a problem with the control board itself. A qualified technician can test the control board to determine if it needs to be repaired or replaced.
It's important to address any issues with your washing machine promptly to prevent further damage or more costly repairs down the line. If you are unsure about any of the steps involved in troubleshooting the E90 error code on your Simpson 1043 top loader, it's best to contact a qualified appliance repair technician for assistance.
2/26/2023 10:13:30 AM • Simpson Washing... • Answered on Feb 26, 2023
2answers
My Simpson Esprit 650 is shorting out the power on the final spin
The motor that allows your washer to run or the pump for your washing machine has quit working.
2/17/2023 3:25:29 AM • Simpson Washing... • Answered on Feb 17, 2023
My Simpson eziset 5.5 model number swt5541 just stopped after it filled with water but if k open the lid and turn the knob the orange led will stay on
t's possible that the control board or the lid switch on your washing machine has failed. These are common causes of this type of issue. Another possibility is a blockage in the pump or a clogged hose. I recommend contacting a qualified appliance repair technician to diagnose and fix the problem. T
2/5/2023 5:46:22 PM • Simpson Washing... • Answered on Feb 05, 2023
How to stop the agitator from turning as I try to unscrew it
To stop the agitator from turning as you try to unscrew it on a Simpson Enduro 801 washing machine, you will need to first unplug the machine from the wall outlet. This will ensure that the motor is not running and the agitator is not turning. Next, you can try using a pair of pliers or a wrench to hold the agitator in place while you unscrew it. Simply grip the agitator firmly and apply enough pressure to keep it from turning as you loosen the screws. If the agitator is still turning or you are having trouble keeping it in place, you may need to apply additional leverage. One way to do this is to use a piece of wood or other flat object to act as a lever against the side of the agitator. This will help to keep the agitator from turning as you loosen the screws.
1/2/2023 10:45:36 PM • Simpson Washing... • Answered on Jan 02, 2023
Simpson Westinghouse Dryer Mesh Lint Filter Logo
6 questions posted
Top Simpson Washing Machines Experts
vince
Are you a Simpson Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Simpson Washing Machines
Most Popular Question
simpson aquarius 824 washing machine
  • Washing Machines
