20 Most Recent
Maytag MER7662WQ - 30"Self-Cleaning Freestanding Electric Range Questions & Answers
Need a wiring diagram
Most appliances have a wiring diagram inside them. (I know washers, dryers, and fridges do). Have you checked to see if there is one? Usually they are printed on green paper and folded up. Obviously for an oven, they'd have to be away from the heat source. Maybe near the control panel on the back, or if there is a storage drawer on the bottom of the stove, it might be in there, or taped to the back of the drawer.
New Maytag MGC7430 gas cooktop leaks gas when lit
First it could be leaking from the control knob when it is on . There could be a leak at the base off the burner letting out gas or on the burner line . You need to get back on to your installer or where you purchased the cook top . This basic gas fitting leak detection .
The electronic lighter will not quit clicking.
Hello, Thank You for using FixYa. I will be helping you today. Did you clean the cook top or spill something? If the switches get wet they will click untill it drys out. If not then one of the switches failed and would need to be replaced. Its the switch that sits on the burner valve.
Thank You and please ACCEPT my answer and Rate my answer if it was helpful..
My electric igniter keeps sparking
Hello, Did you clean the cooktop recently? Sometimes water or cleaner can get into the spark switch causing it to spark untill it dries out. The same if a boiling pot spills. If none of those happened one of the burner switches is bad.
