20 Most Recent
Rheem 81V52D Water Heaters FOR 220 VOLTS Questions & Answers
Water heater is not heating water, but it is getting electricity (81V52D C)
I would start by checking the circuit breaker and the reset button if the heater has one just to get the easy possibilities out of the way. Next check the ground wire to may sure the ground wire is firmly connected. Electronics need a complete circuit in order to work. It is always possible that the wires have become corroded or broken. Please test the wiring to insure that all wires are unbroken. Please see the link below for more specific information.http://waterheatertimer.org/Test-electricity-to-water-heater.html
Rheem 42VP50FW won't light? Ignitor lights though
The three most common reasons for this happening to you are 1) a defective gas valve, 2) a rusty thermopile, and/or 3) the automatic shut-off not working as it should.
So, the most common reason for many people having this problem stems from having a gas valve that is not working as it should. When your gas control valve is faulty, it will mean that your burner is not going to be igniting as it should-or at all.
Something that worked for me one time was to turn the Temp all the way down then all the way to Max a couple of times..gradually.
Why it worked I don't know. Got a couple more years out of it though. Good luck!
Best to you.
I have a Rheem RRNL-B030JK08E heat and A/C Unit IM LOOKING FOR THE BURNER COVER PLATE
The burner cover plate for your Rheem RRNL-B030JK08E unit can be obtained from an authorized Rheem dealer or distributor. You can visit the Rheem website to locate a dealer or distributor in your area. Alternatively, you can contact Rheem customer service for assistance in obtaining the burner cover plate. Be sure to have the model and serial number of your unit available when contacting Rheem customer service.
I have a Rheem RHIN-CHL25P The error code 160 keeps coming on. Do you know what the problem is? This is a new unit.
this from Rheem error codes
Error Code 60
FAULT = Hot Water Temperature Abnormality
- Press the Power button to clear the Error Code. If Error happens again:
- Ensure water heater inlet and outlets are open and water is supplied to the water heater.
- If Error happens again:
- Check the pump operation.
- If it doesn't work, ensure wiring connections to pump.
- If even supply power to pump and doesn't run it, replace the pump.
- Verify recirculation loop length is within specification. Air purge is not enough.
- Too much restriction on recirculation loop.
- Return loops are clogged.
- Check the recirculation loop condition.
Rheem furnace error code 68 fix?
From what I'm seeing this means that there is a bad part within your furnace and it needs to be replaced. It might be the thermostat. You might need to reach out to a local HVAC company to diagnose the issue in person.
Thank you.
Rheem Failed Ignition lockout
the gas valve can be replaced, but you will have to pay for installation. this is not a DIY. You can throw money and parts at it. Personally I've replaced my water heater at the first sign of problems. Are they inexpensive no If you furnish model number I can look further.
My new Rheem 27 tankless hot water system is not hot
if system is new call whomever installed it and it repaired under warranty. there are several reasons unit is not producing hot water. First thing I would check is temp setting. Again call for service under warranty.
