20 Most Recent Amana 30" Self Cleaning Electric Range Stove W/ Oven Freestanding Black & Gray Questions & Answers
Hi Sally:
I'm sure they would like to know.
Could you post this message as a comment on your original request? That way they'll be sure to see it.
Thanks.
Amana 30" Self... | Answered on Oct 23, 2015
Your display is actually reading "SAB". This is an indication of a mode of operation rather than an error code. The following link explains:
http://www.fixya.com/support/r3608491-sabb_or_sab_explanation_kitchen_ranges
Sabbath Mode is a feature that allows the consumer to disable certain features of the range in order to honor the sabbath. Usually this disables the oven, but allows the consumer to still use the surface burners. You cannot defeat it by unplugging the range or turning off the breaker either. You will either have to wait 72 hours for the mode to clear, or figure out how to turn it off.
Somewhere in the owner/operator's manual is a section that refers to "Sabbath Mode". Since all ranges differ in features and operator, you need to refer to the operation section of your owner's manual to find out how to shut the feature off.
If the model number you listed this question under is correct, you need to press and hold the CLOCK button for 3 seconds to clear the Sabbath Mode. "Sab" will flash for about 5 seconds, then return to normal display.
Amana 30" Self... | Answered on Oct 22, 2015
Hi Sally, let me try to help you. The category I am seeing is Amana 30" self-cleaning range. You are having clock setting issues. I need to know the model number to be able to research the issue and get back to you. Please add the model number with a comment on this question. Don't enter a new one as this will confuse others. I will get back to you as quick as I can with either an answer or to let you know what I can or can't find out on the issue.
How to locate and install a turn signal flasher fuse and 92' izusu rodeo
Amana 30" Self... | Answered on Jan 13, 2015
Try turning off power to stove for a few minutes then re try
Amana 30" Self... | Answered on Jul 16, 2014
Remove the back panel could be in there or under the oven door is another removable panel could be under the oven. Good hunting.
Amana 30" Self... | Answered on May 25, 2014
Generally behind the back panel, some models use a fusible link rather than a glass/wire fuse, un less you know what it looks like you will need a multimeter to check for continuity till you locate it.
Amana 30" Self... | Answered on May 24, 2014
Could be the fuse in the back turn off the power and trace the wiring with a multimeter, when you stop getting continuity there is the fuse.
Good luck Ray
Amana 30" Self... | Answered on May 11, 2014
There is this white stuff sold for glass-top stoves. I presume it is good old iron cleaner, a very mild cleaner/polish. Also consider toothpaste.
Amana 30" Self... | Answered on Dec 02, 2013
The F4 error means that the oven temperature sensor is giving an open signal. Probably the oven temperature sensor needs to be replaced. However, sometimes, the wiring harness between the sensor and the control unit has a fault or the control unit (computer) is bad.
I hope this helps.
Amana 30" Self... | Answered on Mar 16, 2013
Request the wiring diagram directly from Amana.
Amana Cooktops | Answered on Dec 17, 2017
You will only need the make and model of the cooktop to order the ignitor. Open the bottom drawer below the oven to find the data plate with model & serial #'s on the front of the oven.
Amana Cooktops | Answered on Mar 19, 2015
Amana 30" Self Cleaning Electric Range Stove W/ Oven Freestanding Black & Gray Logo
38 questions posted
Top Amana Cooktops Experts
Paul Carew
Ismael Rodriguez...
Are you an Amana Cooktop Expert? Answer questions, earn points and help others
View Most Popular
Amana Cooktops
  • Amana Cooktops
Most Popular Question
5ab mean clock
  • Cooktops
