20 Most Recent Equator ED 620/W 110V Dryer - White Questions & Answers
2answers
How do I get into the dryer to replace the drum belt?
May I suggest you type "SearsPartsDirect" into your computer search engine, and then type in the model number found on the tag somewhere on the machine. If they list it, you should find pictures of the machine. To get to the dryer drive belt, you have to take the whole machine apart. God bless your efforts.
10/3/2017 9:27:52 PM • Equator ED 620/W... • Answered on Oct 03, 2017
Equator Advanced Appliances EW 835 18-lb Washing Machine. How do you shut off memory on an EW835
Yes just disconnect it from the mains supply and leave it overnight. It will lose its stored memory. Or from Model EW-824 Manual Press this button to select once of the four positions, then select the additional options for your favorite washing cycles, then press Start/Pause button to run this program, and this program will be memorized. If you want to run the memorized program later, press this button to select one of them, then press Start/Pause button. Turn the dial to align "OFF" to cancel the memory operation https://www.google.com/search?q=Equator+835+clear+memory Manual for model 835 at memory page https://www.manualslib.com/manual/2389625/Equator-Super-Washer.html?page=17&term=memory&selected=1#manual Press this button to select one of the four memory settings. Then select the your favorite Memory button wash cycles. Then press START/PAUSE button to run this program, and this program will be memorized. If you want to run the memorized program later, press this button to select desired program and then press START/PAUSE button ..
2/14/2024 7:57:26 PM • Equator Washing... • Answered on Feb 14, 2024
On the EQUATOR 4400N how do you replace the main motor
Do not pull the connector appart by the wires! screenshot 2024-02-04 at 12.29.19-undefined-undefined-0.png
2/4/2024 12:30:26 PM • Equator Washing... • Answered on Feb 04, 2024
How do I reset my Equator Super Combo washer Dryer EZ4000?
To reset your Equator Super Combo washer dryer EZ4000, you can try the following steps: 1. Unplug the unit from the power source and wait for a few minutes. 2. Plug the unit back in. 3. Press and hold the "Start/Pause" button for about 5 seconds to reset the machine. This should reset the washer dryer and clear any error codes that may be causing the issue. Regarding the door interlock switch, you can try finding a replacement locally by contacting appliance repair shops or stores that specialize in appliance parts. You can also search online for retailers or websites that sell spare parts for Equator appliances. Provide them with the make and model of your washer dryer to ensure you get the correct part. If the above steps do not resolve the issue with your washer dryer, it may be best to contact Equator Appliances directly or consult a professional appliance repair technician for further assistance. They will be able to provide you with more specific guidance and help you troubleshoot the problem effectively.
5/25/2023 5:29:27 AM • Equator Washing... • Answered on May 25, 2023
Equator Super Combo Washer/Dryer Unit Model 4400. Does anyone know how to repair/replace the display and/or heating element please?
This is a brand I have never heard of and it appears to be sold under different names. Likely made in China or somewhere similar. The best way to contact companies is by phone. Element, no details on how. It would be a matter of taking it apart and finding it. https://www.google.com/search?q=Equator+Super+Combo+4400+replace+heating+element Display not much help either https://www.google.com/search?q=equator+super+combo+4400+replace+heating+display+unit Look at the ONE star reviews!! https://www.walmart.ca/en/ip/Equator-Super-Combo-EZ-4400-CV-Washer-dryer-width-23-5-in-depth-22-in-height-33-5-in-front-loading-13-lbs-1200-rpm-white/PRD43BPX7L923KW Here is the phone number though :>D Equator Appliances Team Hi Dorrie, I am so sorry to hear that you are having issues with the motor on your combo washer dryer. What you described is not normal at all and we want to make this issue right for you asap. Please call us directly at 800-490-8018 so we can help you with the issue you are facing. Thanks ..
7/31/2022 8:56:16 PM • Equator Washing... • Answered on Jul 31, 2022
Equator Super Combo washer dryer Display won't turn on but works fine. Why is it doing this?
It would be best to include a model number as there are various models of this. That aside, it is possible that the communication cable between the display panel and the electronics has dislodged. That is item 7 in the attached manual: file:///C:/Users/Donald/AppData/Local/Temp/4000.pdf
11/3/2021 4:11:50 PM • Equator Washing... • Answered on Nov 03, 2021
Equator EZ3600 cee- door will not unlock after spin cycle ends, waited 2 to 3 minutes
If you can see water in the tub, the machine is not draining the water out, and preventing the door from opening, It could also be a faulty door interlock switch. I hope this helps?
9/10/2019 6:50:47 PM • Equator Washing... • Answered on Sep 10, 2019
My Equator Advanced Appliances EZ 4000EZ Super Combo Washer Dryer will not spin or agitate. Error Code 5 appears on the display and I have have replaced motor 3 times. what should I do?
the problem is that you are installing what may not be faulty get a service technician out to check the problem as it could be a program board or other sensor that is faulty and you are replacing the symptom and not fixing the fault
8/10/2017 6:34:03 AM • Equator Washing... • Answered on Aug 10, 2017
Hi, my equator EZ 3710
No spin, or lite spin try these: bare in mind that many times there is no spin it can be due to a clogged water pump so check it for debris and or broken propeller. Other items to check Using a multi meter check for continuity the door switch, which when bad may not allow agitation or spin. Bare in mind the lid switch assembly can fail either mechanically or electrically. Check the clutch, brake assembly and transmission, one way to check for slipping is to get under the machine after a spin cycle ( this is if u get a lil spin but not much leaving clothes still wet) mix in a spray bottle a lil water and some dish detergent, then spray it on the clutch assembly ( the metal round pc. Connected to the tranny) if it sizzles and steams up then u know its bad and slipping. Another way to check clutch if u get no spin at all? Is to take it out and use ur hand to try and turn the inner spring assembly pushing it around the inside? If its very easy, it BAD should be hard to push by hand. Or try the hand test: If no hammering sound has ever been heard out of this machine, one of the unofficial tests we professional appliantologists will do in the field is called the Hand Test. WARNING:This test is not sanctioned by Whirlpool Corporation; it involves bypassing safety equipment and then putting your hand on and near rotating machinery which could result in injury, dismemberment, disfigurement, disembowelment, mangling, hideous screaming, and a ****** *****. Proceed at your own risk! Have a nice day. - put the timer on a spin cycle and open the lid- grab the inner basket with maybe 30% to 40% of your hand strength with your left hand - turn on the machine and bypass the lid switch by depressing the lid switch with a key until the machine begins to spin - if the clutch is engaging properly, the basket should immediately begin to spin and slip through your hand - if it takes very little force to stop the tub from spinning, the clutch needs to be replaced. Next check the motor coupler which engages the tub and tranny to the motor. ( if its bad u usually get no wash or spin or very little of either) Next if belt driven check for a loose, worn or broken belt. And on some models there is no clutch but rather what is called a splutch. And a MODE shifter. These can go bad and effect the spin cycle. On some front load models u may need to check the STATOR assembly. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed. Sometimes a no spin machine can be due to a plugged waterpump hose or obstructed water pump propeller. Check these by eye and hand. And in some models check with a meter for continuity and voltage. next step is toremove the cabinetand jumper the lid switch harness (tan to gray). Put the unit in spin and watch the shiny metal clutch disc that is on top of the transmission where the shaft comes out. If the machine starts and runs in spin, check to see if the disc is spinning. If it is, then the problem isnot in the gearcase- look for trouble in theclutch,basket driveor the tub drive block If, on the other hand, the disc is NOT spinning, check for a problem withthe motor drive coupleror one of its retainers. This washer doesn't have a belt. Instead, the motor is directly coupled to the gearcase by a drive coupler; that's why it's called a direct drive washer. Read more:Diagnosing and Repairing Spin and Agitate Problems in a Whirlpool / Kenmore Direct Drive Washer http://fixitnow.com/wp/2010/07/07/diagnosing-and-repairing-spin-and-agitate-problems-in-a-whirlpool-kenmore-direct-drive-washer/#ixzz3XW7eZwiN By the way my advice is free cuz God is good! Diagnosing and Repairing Spin and Agitate Problems in Whirlpool Kenmore... 9959184-wkaz2joxiaagz3w0xil1scpn-1-0.jpg 9959184-wkaz2joxiaagz3w0xil1scpn-1-2.jpg 9959184-wkaz2joxiaagz3w0xil1scpn-1-5.jpg 9959184-wkaz2joxiaagz3w0xil1scpn-1-9.jpg 9959184-wkaz2joxiaagz3w0xil1scpn-1-14.jpg 9959184-wkaz2joxiaagz3w0xil1scpn-1-20.jpg 9959184-wkaz2joxiaagz3w0xil1scpn-1-27.jpg 9959184-wkaz2joxiaagz3w0xil1scpn-1-35.jpg
2/2/2016 8:32:22 PM • Equator Washing... • Answered on Feb 02, 2016
Equator EZ 3612CEE machine when spins drum has a very loud sound plus vibrations is very strong. What is the problem? Can it be fix
sounds like counter balance rods or counter weights? LOUD NOISES IN washing MACHINE; LOT OF THINGS TO CHECK, THE BELT LOOSE OR WORN, THE CLUTCH, THE TRANNY, THE BEARINGS BOTH TUB SEAL AND BEARING, THE REAR DRUM BEARING, the balance or counter weights. THE DRIVE PULLEY- If the washer is making a loud noise the drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it. THE TRANSMISSION, THE MOTOR COUPLER, THE MOTOR DRIVE BEARINGS, THE DRIVE MOTOR- If the washer is making a loud noise the drive motor bearings may have worn out. Washer motors are normally almost silent when they run. If the motor is run without a belt hooked up to it and it's loud it will have to be replaced. The drive coupling connects the motor to the transmission and consists of two plastic drive forks with a rubber coupling between them. One of the drive forks is attached to the drive motor shaft and the other is attached to the transmission input shaft. As the motor shaft rotates, the rubber coupling between the drive forks absorbs the torque to prevent the forks from breaking. Normal use will create wear on the coupling and eventually the drive forks may slip and cause a vibrating noise. If the transmission seizes or if the spin basket cannot turn freely, then the coupling may fail and again you may experience a vibrating noise. Most models will require you to remove the cabinet to access the drive coupler. Disconnect power from the appliance before attempting any repairs. A worn drive block will usually have a pounding sound, like hammering metal, during spin when it first starts. If there is enough interlocking tab left on the drive block, you'll see it finally engage at top speed with an empty basket. In a transmission lock up the holes get enlarged in the rubber isolator and the studs break off the motor and transmission couplers. This is usually caused by the abrupt motor reversal between the agitate and pump out functions. If you hear a loud bang every time the motor reverses, the coupler is getting loose. An obvious sign of a failed coupler is a pile of black rubber shavings under the washer. If the motor runs and the agitate and spin functions don't work, the studs may have broken off the coupler (old coupler design) or the coupler may have broken at the shaft (new design) and you need a new coupler kit. The coupler can also just crack around its center hole allowing it to slip on the motor or transmission shaft hampering those functions. If the washer is making a loud noise the drain pump might be going bad or might have something caught in it. Remove the drain pump from the washer and inspect it carefully. Look for anything that might be caught in it, a piece of wire, plastic, etc. If nothing is wrong with the pump, but it's still noisy it will have to be replaced. Front load washers often use a self contained electric drain pump and the motor may be worn or damaged and require the complete pump to be replaced. Remove any foreign objects or replace the worn or damaged pump, thencarefully tighten the hose clamps and check for leaks before installing the cabinet or front panel. All front-load washing machines have shock absorbers that are used to dampen the tub movement in the spin cycle. The shock absorbers or struts are attached to the base frame and to the outer tub and you will need to remove the front panel or the rear panel to access them. When shock absorbers weaken or become damaged, the machine will often make a loud banging sound during the spin cycle and if the symptom is not corrected, can lead to damage of other components. Inspect the shocks for signs of broken attachments, leaked fluids or a weakened dampening action and replace both shocks if worn. Remove power from the appliance before attempting this repair. Some models of top-load washers use tub dampening straps to cushion the movement of the tub during the spin cycle. There are four straps attached to the top of the tub and to each corner of the cabinet Also There are four suspension rods that suspend the tub and allow the tub to free float. If the suspension rods are noisy, there will be a squeaking noise during wash. You can fix this by putting bearing (lithium base) grease in the cup that each rod rests in. If it continues to squeal replace all four rods the cups come with the rods, replace them as well. If your washer has a loud banging noise during spin the balance weight may be loose. This weight is to counter act the weight of the motor so you will find the weight directly behind the motor. Sometimes simply tightening the bolts will fix your issue but if the bolts are stripped out get some bolts slightly longer than the original bolt to allow you to put a locking nut on the bottom side of the mounting plate. If the weight is broken replace it. Another noise issue can arise from a worn SNUBBER RING on some washers that have a snubber like some Maytags, if u notice tiny pc's of white/grey shavings on the floor or around the bottom washer area? A sign of bad snubber. When removing to replace be careful as the spring underneath is pressure loaded. A very similiar sound can be produced when the belt is worn but the difference is that a snubber noise can be produced during the spin cycle or when the cycle has finished and the spin tub is coasting to a stop. A worn belt noise can only be produced while the motor is actively engaged in spinning the spin tub. If it is discovered that the belt is worn and the base has black, shredded belt residue then it may not necessary to clean it out (belt residue generally will not cause a problem with the snubber). It will be necessary however, to find the cause of the belt failure. Lastly Washer vibration can be caused by a broken counter balance spring. Ur washer may be equipped with one or more counter balance springs which help to absorb the natural movement of the spinning tub. If a counter balance spring fails the tub might lean in one direction more than another and it will shake and cause vibration. By the way my advice is free cuz God is good! GRINDING NOISES: The plastic drive is known as a splutch (splined clutch). One problem with these washers has been loosening of the nut that locks the pulley to the agitator input shaft. If it gets loose, the pulley drops and the teeth no longer have good contact with the teeth of the splutch basket drive gear in spin mode. The solution is application of blue locktite to the threads of the input shaft. There have also been a lot of failures of the actuator that operates the cam ring of the splutch which raises and lowers the basket drive gear. It is raised for agitate mode and lowered for spin. There is a spring between the basket drive gear and the gearcase housing that maintains pressure on the basket drive gear. There are cams on the cam ring that ride up and down on cams in the splutch cam (housing) as it is rotated by the actuator thus raising and lowering the basket drive gear. The gearcase has a planetary gear set in it. 25817870-wkaz2joxiaagz3w0xil1scpn-1-0.jpg 25817870-wkaz2joxiaagz3w0xil1scpn-1-2.jpg 25817870-wkaz2joxiaagz3w0xil1scpn-1-5.jpg 25817870-wkaz2joxiaagz3w0xil1scpn-1-9.jpg 25817870-wkaz2joxiaagz3w0xil1scpn-1-14.jpg 25817870-wkaz2joxiaagz3w0xil1scpn-1-20.jpg
2/2/2016 7:56:00 PM • Equator Washing... • Answered on Feb 02, 2016
Equator ED 620/W 110V Dryer - White Logo
1 questions posted
Top Equator Washing Machines Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you an Equator Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Equator Washing Machines
Most Popular Question
get into dryer replace drum belt
  • Washing Machines
