20 Most Recent Sony DDS SDT-9000 DAT Tape Drive Questions & Answers
Did you load this driver? sxpdds_32_2600_102202_v1.0.0.2.zip http://sony.storagesupport.com/node/471
If so check the Windows Event Viewer System log for possible errors from the driver.
Sony DDS... | Answered on Jan 18, 2011
SONY SDT-9000 is needn't driver in Windows XP. or you can download driver in http://sony.storagesupport.com/product/17#drivers
Sony DDS... | Answered on Mar 06, 2009
I have usually found it is better to format the hard drive and reload the operating system.
Sony Computers &... | Answered on Sep 30, 2020
the problem has to be from the display inverter board. The display inverter board is responsible from bringing display on the screen. Now since is no longer display, then it mean it has become defective.Get a philips screw driver, disassemble the unit in order to get to the display screen. You will see a kind of flex or wire connected to the screen. The board where the wire/flex is coming from into the screen is the display inverter board. The board is rectangular in shape.Remove the board, take it to an electronics parts store within your vicinity for exact replacement and the unit should display again.
Sony Computers &... | Answered on Aug 24, 2020
https://www.sony.com/electronics/support/televisions-projectors/kf-60we610/articles/S1Q0084
https://translate.google.com
Le voyant de la lampe clignote
Si l'?cran s'assombrit, que la couleur semble inhabituelle ou que le t?moin LAMP ? l'avant du t?l?viseur clignote, il est temps de remplacer la lampe par une nouvelle (non fournie).
Utilisez uniquement un Sony XL-2100U ou XL-2100 de remplacement pour votre t?l?viseur. L'utilisation de toute autre lampe peut endommager votre t?l?viseur ? projection LCD. Contactez votre revendeur Sony pour une lampe de rechange.
Cliquez ici pour t?l?charger des instructions ?tape par ?tape pour remplacer la lampe de votre t?l?viseur.
Remarque: Avant de remplacer la lampe, mettez l'unit? principale hors tension. Attendez quelques minutes, puis d?branchez le cordon d'alimentation. (Le ventilateur de refroidissement continuera de souffler pendant environ deux minutes apr?s la mise hors tension.)
Assurez-vous de laisser la lampe refroidir compl?tement avant de la retirer. La surface de la lampe reste extr?mement chaude pendant au moins 30 minutes apr?s la mise hors tension.
Sony Computers &... | Answered on May 03, 2020
Did you blow compressed air into laptop?. It is possible that something got disconnected or dirt stucked in powrr button
Sony Computers &... | Answered on Apr 22, 2020
Hi
You can read more such errors and their solution from the given link. This blog will help to analyze the Lotus Notes problems and give you the easy approach to resolve them smartly. This will enhance your knowledge about IBM and the tips to fix them.
Read more:- http://www.nsfsecurityremover.com/blogs/lotus-notes-error-messages/
Thanks
hi there might be...first go to my computer, then locate the dvd drive, right click that and then properties, then click the hardware tab at top then in the list locate dvd drive then at bottom right click on properties then click dvd region and then you should be able to change it....hope that helped
Sony Computers &... | Answered on Apr 17, 2020
You'll need a decoder from a program like cyber dvd or win dvd. Nero also has one and sonic too. If the drive came with a dvd player program install it. You can also find them through windows media player at microsoft's website but they will cost a few bucks. Search the internet for dvd player software you may find one for free. I hope this helps you. If you are like me you might have a program in your pile of software cds'.
Sony Computers &... | Answered on Mar 24, 2020
In Windows, open My Computer/Computer and explore/open the disk from it's drive.
Sony Computers &... | Answered on Mar 23, 2020
Do you have sound in other applications?
You could try using VLC Media Player, instructions here:
https://www.thewindowsclub.com/play-blu-ray-on-windows-10
Sony Computers &... | Answered on Feb 12, 2020
Hello there... Sony seems a choosy brand so it looks like your disc is not recognized by it. Check also your disc for scratches or you just need to clean your disc first before you can use it. Try it. If this doesn't help, try inserting your disc to other CD-ROM. See if your disc is okay. Hope this helps...
Ai-ai :)
Sony Computers &... | Answered on Jan 20, 2020
The push-button activates a small motor that turns a small rubber belt/ band that opens the cassette door. Since it's not been used for 10 yrs, I would say these belts would have deteriorated and broken. you will need to replace them. the best bet is to open it up and check. if its the case, you should be able to source the belts on ebay.
Sony Computers &... | Answered on Dec 03, 2019
this is easy, that OUT OF range means
the PC sending video is sending and illegall higher resolution
than the projector supports (or even less, on this old junk)
the manual on that old projector is clear on that. max.
SONY VPL-EX4 2007, 13 years old now.
and back then projectors STINK !
your manual shows this, and stinks.
what stinks worse is no matrix of legal H./V resolutions shown in the manual. (shows only 1)
so set the PC to 1400 x 1050 and do not use others . ok.
and 60Hz, are you in USA? not stated country.
Sony Computers &... | Answered on Nov 28, 2019
no OS stated, W10?
the drivers for your camera/mic are wrong, reload them from SONY..com
Looks like you are having a bad LCD screen, This could be due to drop damage. Cracks can be so tiny and may not be visible immediately. I would take it to a technician and get a screen replacement.
Sony Computers &... | Answered on Nov 27, 2019
Sony DDS SDT-9000 DAT Tape Drive Logo
5 questions posted
Top Sony Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Michael Thomas
Michael Thomas
Muntejaya Ginting
Muntejaya Ginting
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
DDS Sony
  • DDS Sony
Most Popular Question
ibm xseries
  • Computers & Internet
