20 Most Recent
Neff B1641 Single circotherm super Stainless Steel Electric Oven Questions & Answers
NEFF CIRCOFIRM OVEN HAS DIED?
the chid lock is activated!! how did you manage to do that accidentally??? the instruction manual tells you how to disable it from memory it is turning the oven mode selector switch 3 times beetween the light position and off quickly.
Neff U1422 oven grill tripping RCD
The grill element has an internal short and needs replacing. Sometimes you can see it as a slight bulging of the element. This happens just before it blows a hole. It may also have been physically damaged when something was put in there after a few Sherries. :>D Sounds like your RCD is adequately sensitive.
1/2/2024 7:05:55 PM •
Neff Ovens
Answered
on Jan 02, 2024
Neff Steam Oven error code E5123.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwiwgLHn8vL-AhURAzQIHRE9BqIQFnoECBsQAQ&url=https%3A%2F%2Fwww.fixya.com%2Fsupport%2Ft29925510-neff_steam_over_error_code_e5123&usg=AOvVaw1yI-sjEM1vvRntCUJzF6u2
5/13/2023 6:13:47 PM •
Neff Ovens
Answered
on May 13, 2023
Neff T18FD36X0/01 display flickering,not staying on.
If the display on your Neff T18FD36X0/01 appliance is flickering and not staying on, there could be a problem with the control board or the display module itself. Here are some steps you can take to troubleshoot the issue:
- Check the power supply: Make sure that the appliance is getting power by checking the outlet and the power cord. You can also try plugging in another appliance to see if the outlet is working properly.
- Check the control board: If the power supply is fine, the next step is to check the control board. Turn off the power to the appliance and remove the control panel cover to access the control board. Look for any loose wires, damaged connectors or burnt components. If you find any issues, you may need to replace the control board.
- Check the display module: If the control board is fine, the issue may be with the display module itself. Remove the control panel cover and locate the display module. Check the connections and make sure they are secure. If the connections are fine, the display module may need to be replaced.
- Call a professional: If you are not comfortable troubleshooting or repairing the appliance yourself, it is best to call a professional technician. They will be able to diagnose the issue and recommend the best course of action.
Remember to always turn off the power to the appliance before attempting any repairs or troubleshooting. Safety should be your top priority.
2/26/2023 2:10:59 PM •
Neff Ovens
Answered
on Feb 26, 2023
