20 Most Recent Sony VAIO FRV27 Notebook Questions & Answers
2answers
Dvd drive wont recognize disc
There are a number of possibllities for this problem:
1. Your drive may be dirty. Try to get a drive cleaner, run it then try again
2. The disc itself is faulty. Try using it on another computer's drive and see if you can read it
3. It is a region-specific DVD. Some movies can only be played on DVD's made for that region. Although you can change your DVD's region to be able to read that DVD, you will then not be able to read DVD's for your current region. The recommendation here is to buy a multi-region DVD player. You do not need to get the top of the line model as these players can be quite cheap.
NOTE: Please rate our help to keep this free service online.
1/20/2020 6:49:21 AM • Sony VAIO FRV27... • Answered on Jan 20, 2020
Sony vaio pcg-frv27 turns off after a while, I'm
Most likely overheating, check if it is getting hot as it shuts off, by hot I mean hard to touch the base.
If it is, you will need to remove the bottom cover and clean out the accumulation of any dust by the heatsink
3/26/2011 8:28:30 PM • Sony VAIO FRV27... • Answered on Mar 26, 2011
Power on brings the first screen
Before Vaio comes up, start pushing F1 or F8 or F11. If it lets you in to restore your comp, do it. That's the only way to fix this. You will lose all your files and info on your laptop though.
1/28/2010 3:41:34 AM • Sony VAIO FRV27... • Answered on Jan 28, 2010
Fn key
Try installing the "Sony Shared Library" and the "Sony Notebook Control Device Drive".
First install the Sony Shared Library, restart the Computer and then install the "Sony Notebook Control Device Driver" (restart the Computer again).
NOTE: Sony Shared Library is the system component which makes the download and installation of Drivers and Applications compatible with the Computer. While "Sony Notebook Control Device Drive" is utility which will enable the Function keys in the Computer.
Check this Link to download these Utilities.
http://esupport.sony.com/US/perl/swu-list.pl?mdl=PCGFRV27
The Sony Shared Library will be listed under "System Components - 1 file(s)" and Sony Notebook Control Device Driver will be under "Notebook Control and Utilities - 1 file(s)".
Good Luck!!!!!!!!!!!!!!
11/18/2009 8:27:26 AM • Sony VAIO FRV27... • Answered on Nov 18, 2009
Hi kbdesign, I tried to recover from the recovery
tap the F10 key while the Sony window is up which should take it into the recovery mode.
3/14/2009 5:04:43 PM • Sony VAIO FRV27... • Answered on Mar 14, 2009
Hi guys, I keep getting an error message that
Try rebooting and hitting the F8 repeatedly as soon as the boot sequence starts. When it comes up to an options screen select repair. From there you can let windows try to repair or select to install to the factory settings.
3/14/2009 4:47:51 PM • Sony VAIO FRV27... • Answered on Mar 14, 2009
3answers
Typing in a electronic medical record online. the
If you only erased it, you can simply use the keyboard shortcut CTRL+Z, if the deletion was permanent, there is nothing you can do.
12/22/2022 9:08:06 AM • Sony VAIO... • Answered on Dec 22, 2022
5answers
Code error 0xc0000185
Do you the Windows user suffer Error Code 0xc0000185 on your PC or laptop. Well, this is a blue screen of a ***** error note telling me that your boot configuration info is missing (Error Code 0xc0000185) This BSOD error code issues with a note - The Boot Configuration Data for your PC is missing some required information. Causes of Error Code 0xc0000185:- 1. Suffer a cable attachment joining to your system and the hard drive. 2. Defective or missing boot files. 3. The disk drive gets damaged. 4. Wrong disk drive. Solutions of Error Code 0xc0000185:- 1: Do sure that Wire is Correctly Connected [Only for PC] 2: Automated Repair 3: Check Hard Disk for Errors 4: Repair your System to Fix Error 0xc0000185 Full Solution - Error Code 0xc0000185 wgnanor-undefined-undefined-0_3.jpg
9/14/2022 11:53:07 AM • Sony VAIO... • Answered on Sep 14, 2022
Nao consigo instalar o drive de controle de massa no meu Sony Vaio PCG-792L. Como devo fazer
www.driverguide.com use the 2 drivers free install per day freature. it will help you for sure
1/23/2019 7:29:29 PM • Sony VAIO... • Answered on Jan 23, 2019
How can dennythedon3003 help - if only he spoke English
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
11/30/2018 6:39:57 PM • Sony VAIO... • Answered on Nov 30, 2018
hi, you mean it doesn't give you any option to adjust? (adjustments options are disabled?). have locate under power option menu? thanks
11/30/2018 6:38:47 PM • Sony VAIO... • Answered on Nov 30, 2018
Denythedon3003 fixya spam loser - guess what country he's from - maybe Tom can block him
This can be a faulty inverter or a faulty CCFL lamp. Pleaseclick on this link and follow my instructions to identify the fault andpossible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
11/30/2018 6:25:34 PM • Sony VAIO... • Answered on Nov 30, 2018
Pci modem drivers and audio drivers
Check this Sony's website: Original Drivers Package
10/9/2018 8:31:43 AM • Sony VAIO... • Answered on Oct 09, 2018
Lost video on svt131a11l
Try to:Open Computer by clicking the Start button and then clicking Computer.Navigate to the folder or drive that used to contain the video file, right click it and then click Restore previous versions. https://8ballpool.onl/ https://googlehangouts.ooo/ https://omegle.onl/
9/30/2018 12:52:58 AM • Sony VAIO... • Answered on Sep 30, 2018
0answers
2answers
System has slowed down and freezes regularly. it
A lot of anti viruses cant find or get rid of pups, which are potentially unwanted programs that sneak onto your computer, go to mybleepingcomputer.com and download and run adwcleaner, its free and gets the boogy men out.
1/22/2018 2:02:26 AM • Sony VAIO... • Answered on Jan 22, 2018
My laptop has limited internet access. I've called
Hello - Depending upon where (in your home?) you use your Sony Vaio laptop (via WiFi?) you may need a WiFi booster or extender. Or, you may find that moving your WiFi router to another location in your home will improve your connection without diminishing the connections for other laptops used in your home. Perhaps the information here will prove instructive: https://www.repeaterstore.com/pages/wifi-booster-repeater-extender-differences Note: If the router needs to be moved in your home, you will probably need a technician for your Internet provider to come to your home to relocate it and connect it properly.
12/28/2017 11:26:53 PM • Sony VAIO... • Answered on Dec 28, 2017
Sony VAIO FRV27 Notebook Logo
Popular Tags
9 questions posted
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
VAIO Sony
  • VAIO Sony
Most Popular Question
fn key
  • Computers & Internet
