20 Most Recent Amana Tandem 7300 Washer and Dryer Stack Assembly Kit 8572546 Questions & Answers
Will not advance to wash after selection beeps on wash. But does not go on
Pump blocked .down at front of machine water willcome out so be prepared with towels etc.clear blockage
1/18/2016 10:21:26 PM • Amana Tandem... • Answered on Jan 18, 2016
Dryer will not start it beeps three times
check for thermal fuse blown or bad door switch
4/11/2015 9:39:37 PM • Amana Tandem... • Answered on Apr 11, 2015
Is there a reset button
First, plug a fan or hair dryer into the plug to make sure it has power, if not, check to see if the GFI plug hasn tripped. All electrical plugs that are near water have to be on a dedicated electrical line that has a trip-breaker (GFI) built into the plug. Try unplugging the washer for several minutes to reset the electronics. Those are the only two quick fixes I can think of. If you have an electric dryer, it will have its own 220v plug and won't be affected like the washer. If the dryer is gas and is plugged into the same outlet, try unplugging the washer to reset first before you call a repairman for the washer. If you have homeowners insurance, they may cover the damage.
6/22/2014 4:55:12 PM • Amana Tandem... • Answered on Jun 22, 2014
Washer cycling on it's own...filling and forcing door open...sunami
Mine was doing the same thing. The solenoid is out and is letting water push by the valve in it. The solenoid is where the hot and cold water hoses hook up on the back of the washer. The part is super cheap and is very easy to replace. There are tons of videos on youtube. I used this video. Water Inlet Valve Replacement part 8182862 Duet HE3 Washer Repair
4/10/2014 3:39:18 PM • Amana Tandem... • Answered on Apr 10, 2014
Door will not unlock
there should be a reset button in front of the machine on the right side..hold until you hear a click from the door. or go to How-2 repair.com
3/31/2014 9:16:54 PM • Amana Tandem... • Answered on Mar 31, 2014
Water runs out of soap box during rinse cycle
Hi there, given this a lot of thought. I had same problem. Could be that you are in a hard water area. Soap is not dissolving properly and building up in the rubber tube between soap box and drum. How I resolved this. Turn off power remove top cover of washing machine and massage the rubber pipe between soap box and drum to soften and cause undissolved saoa to drop into drum. This should rectify problem. Also consider using every month some descaler powder called Descaler cheapest from Axxxxn best wishes.
2/26/2014 9:28:03 PM • Amana Tandem... • Answered on Feb 26, 2014
0answers
I HAVE AN AMANA TANDEM 7300 IT STARTS THEN STOPS AND BEGINS BEEPING DOOR WONT UNLOCK TO GET MY CLOTHES OUT WHAT DO I DO???
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Test a pressure switch: Click on : http://www.youtube.com/watch?v=HZZ2bDMspj8
Check this link to replace the inlet valve: http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
1/24/2013 5:19:48 AM • Amana Tandem... • Answered on Jan 24, 2013
Amana Tandem 7300 Washer and Dryer Stack Assembly Kit 8572546 Logo
43 questions posted
Top Amana Washing Machines Experts
Virgil Watts
ZJ Limited
ZJ Limited
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Amana Washing Machines
Most Popular Question
will not advance wash after selection
  • Washing Machines
