20 Most Recent Neff T1323 Electric Cooktop Questions & Answers
Possible that the main heating element is faulty. It is possible that the wires have shorted or due to insects if there was failure of the insulation of the wires leading to shorting of the lead lines.
Disconnect the main lines and use a multimeter to check and confirm the short of the heating element or wires.
Take all precaution for safety in testing live circuit.
Neff T1323... | Answered on Aug 18, 2011
when cutting the worktop to fit this in make the hole 10mm smaller than the hob
Neff T1323... | Answered on Aug 11, 2011
I think that I would get an electrician if it isn't a straight forward plug
Neff T1323... | Answered on Jun 10, 2011
Touch on/off pad for 6 seconds til key symbol goes out.
Neff T1323... | Answered on Sep 05, 2010
I have a T172 model which also has a dual circuit hotplate.
In the control area you should find a dual circuit control pad - this has two concentric circles on it. With the hob switched on, pressing this button will chnage the mode of the dual circuit hot plate bewteen:
1. Just the inner part
2. Both the inner and outer together.
When the hob is switched off using the Standby control pad, it remembers which mode was selected and will therefore work the same next time it is switched on. However, it is worth noteing that when the mains power to the hob is interuppted, either by an isolator switch/breaker, or a power cut, the hob defaults back to just the inner ring mode.
Neff T1323... | Answered on Oct 03, 2009
Visit http://www.bshcustomerservice.com/
And enter your model number to download a PDF instrustion manual.
Neff T1323... | Answered on Jun 25, 2009
The details of how to wire the T1213 hob are printed on the base of the hob next to the terminal compartment. For a single cable installation, Neutral is connected to terminals 4 & 5 which should already be linked with a copper link. Terminals 1,2 & 3 should be linked together using the links supplied (hidden in the side of the terminal compartment) and Live is connected to any one of 1,2 or 3. The Earth goes to the terminal beside the cable clamp.
Neff T1323... | Answered on Jun 13, 2009
Neff T1323 Electric Cooktop Logo
21 questions posted
Top Neff Cooktops Experts
Lee Hodgson
Lee Hodgson
Paul Carew
Andrew Taylor
Andrew Taylor
Are you a Neff Cooktop Expert? Answer questions, earn points and help others
View Most Popular
Neff Cooktops
  • Neff Cooktops
Most Popular Question
neff t1 d20 dual circuit hotplate but
  • Cooktops
