20 Most Recent Sony VAIO VGN-FS660 Notebook Questions & Answers
you should be able to do a system restore to before you removed it.
Sony VAIO... | Answered on Jan 03, 2013
AT boot the screen doesn't come on? If it's hot, remove all media, CD's DVD's USB, etc, turn it off , unplug, remove battery, let it cool off and replace battery, plug in, reboot. Is there any change?
Sony VAIO... | Answered on Nov 03, 2012
Have you got the latest direct x installed
Open the run command from your start menu
Type cmd in to the search window
Type in 'dxdiag' and it will be at the bottom of the first page of the system tab
Sony VAIO... | Answered on Oct 08, 2012
it is a simple problem with your keyboard.can you clean your keyboard using vaccum cleaner? try cleaning it.this issue will be solved.
Sony VAIO... | Answered on Apr 07, 2012
Possible power cable fault, hard to tell really, especially if you ran the laptop battery flat, but it may be a flat cmos (bios) motherboard battery, also check that the hibernate switch where you close your laptop lid is not stuck down as this will dissable power up.
Sony VAIO... | Answered on Feb 11, 2010
I would check the volume level and make sure the microphone is not on mute. If the settings are fine, then you should update your audio driver. Search on google for you laptop model and audio driver. Install the proper driver and reboot.
Sony VAIO... | Answered on Oct 16, 2020
Do you the Windows user suffer Error Code 0xc0000185 on your PC or laptop.
Well, this is a blue screen of a ***** error note telling me that your boot configuration info is missing (Error Code 0xc0000185)
This BSOD error code issues with a note - The Boot Configuration Data for your PC is missing some required information.
Causes of Error Code 0xc0000185:-
1. Suffer a cable attachment joining to your system and the hard drive.
2. Defective or missing boot files.
3. The disk drive gets damaged.
4. Wrong disk drive.
Solutions of Error Code 0xc0000185:-
1: Do sure that Wire is Correctly Connected [Only for PC]
2: Automated Repair
3: Check Hard Disk for Errors
4: Repair your System to Fix Error 0xc0000185
Full Solution - Error Code 0xc0000185
Sony VAIO... | Answered on Aug 13, 2020
www.driverguide.com use the 2 drivers free install per day freature. it will help you for sure
Sony VAIO... | Answered on Jan 23, 2019
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Sony VAIO... | Answered on Nov 30, 2018
hi, you mean it doesn't give you any option to adjust? (adjustments options are disabled?). have locate under power option menu?
thanks
This can be a faulty inverter or a faulty CCFL lamp. Pleaseclick on this link and follow my instructions to identify the fault andpossible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Check this Sony's website:
Original Drivers Package
Sony VAIO... | Answered on Oct 09, 2018
Try to:
Open Computer by clicking the Start button and then clicking Computer.
Navigate to the folder or drive that used to contain the video file, right click it and then click Restore previous versions. https://8ballpool.onl/ https://googlehangouts.ooo/ https://omegle.onl/
Sony VAIO... | Answered on Sep 30, 2018
If you only erased it, you can simply use the keyboard shortcut CTRL+Z, if the deletion was permanent, there is nothing you can do.
Sony VAIO... | Answered on Aug 11, 2018
A lot of anti viruses cant find or get rid of pups, which are potentially unwanted programs that sneak onto your computer, go to mybleepingcomputer.com and download and run adwcleaner, its free and gets the boogy men out.
Sony VAIO... | Answered on Jan 22, 2018
Hello -
Depending upon where (in your home?) you use your Sony Vaio laptop (via WiFi?) you may need a WiFi booster or extender. Or, you may find that moving your WiFi router to another location in your home will improve your connection without diminishing the connections for other laptops used in your home.
Perhaps the information here will prove instructive:
https://www.repeaterstore.com/pages/wifi-booster-repeater-extender-differences
Note: If the router needs to be moved in your home, you will probably need a technician for your Internet provider to come to your home to relocate it and connect it properly.
Sony VAIO... | Answered on Dec 28, 2017
Sony VAIO VGN-FS660 Notebook Logo
15 questions posted
Top Sony Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Michael Thomas
Michael Thomas
Muntejaya Ginting
Muntejaya Ginting
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
VAIO Sony
  • VAIO Sony
Most Popular Question
not start
  • Computers & Internet
