20 Most Recent Bounty Hunter Land Star Digital Metal Detector with Ground Trac Re-Tune - LSTAR w/FREE UPS Questions & Answers
have you contacted the tesoro dealer in prescot arizona they are working on mine come to find out i had a wire inside that was broken please keep me posted ok best regards and happy findings mike
Bounty Hunter... | Answered on Nov 11, 2009
IT COULD be a few things:
1) check all connections.
2) You may just live in an area w/ lots of electric/magnetic interference, this is not rare...have you tried bring it somewhere a distance away from your home?
3) These machines DO NOT operate correctly on any batteries other then alkalines...if u use even a Heavy Duty battery, you will get the same chatter, slightly or non detecting results...U MUST USE ALKALINES, my reccomendation is only duracell or the bunny rabbit that doesnt stop alkalines.
Bounty Hunter... | Answered on Nov 02, 2009
Call Fisher metal detectors, go to their website...they are together after a recent merge w/ Bounty Hunter.
Bounty Hunter... | Answered on Jul 08, 2009
Request the manual from Oggi.
Optics | Answered on Nov 20, 2020
ask GOOGLE WE DON'T HAVE THEM
Optics | Answered on Nov 14, 2020
Request from the manufacturer/distributor
It's just half a binocular, or a hand held telescope that uses prisms to reduce the physical size.
A monocular is a modified refracting telescope used to magnify the images of distant objects by passing light through a series of lenses and usually prisms, the application of prisms resulting in a lightweight, compact telescope.
Monocular - Wikipedia
Optics | Answered on Nov 10, 2020
Optronics is the maker. Contact details as on this page
https://www.shootingtimes.com/editorial/optics_buckridge_0729/100534
For more information, contact Optronics Inc., Dept. ST, 401 S. 41st St., Muskogee, OK 74403; (800) 364-5483; www.optronics.com.
Yes, you will need a license to operate as a gunsmith in the United States. However, you won't need a gunsmithing license. As far as I know, no US state requires that gunsmiths have a state-issued license. This means you also won't need to undergo any training or take part in any type of apprenticeship in order to become a gunsmith. You'll become a gunsmith the moment you start claiming to be one.
If you are wondering that type of license gunsmiths need, that'd be a Federal Firearms License (FFL). This type of license is a basic requirement for any business that plans on working with firearms within the United States. To get one, you'll need to fulfill some basic requirements, including going through an interview and an inspection of your future workplace. It's generally not hard to get an FFL.
But again, since this is a general license and not something made for gunsmiths, you won't have to prove yourself a competent gunsmith to get one. You'll just have to show that you understand the basics of gun safety and meet their requirements.
If you'd like to become a gunsmith, this guide can help you get started.
Optics | Answered on Oct 12, 2020
It was made after 1966. If you see on the barrel and if it says Stratford Ct it was made 1970-1980. The current manufacturer does not keep records of the older models.
Optics | Answered on Oct 06, 2020
I this you can find it on https://scopefacts.com/best-rifle-scope-for-deer-hunting/
Optics | Answered on Oct 05, 2020
1. For AHD10, HDA10, HDA30, NVRH5, NVR IH8, NVR IC8 Series:
  • Go to DVR/NVR Main Menu (You may need to log in after this step)
  • Click on Advanced Tab
  • Maintain Tab will appear by default
  • On this screen locate the Load Default option and click on it.
  • Select "All" to factory reset all your DVR/NVR Settings and click on Save (You may need to log in to this step)
  • Your system may restart after this step (Older systems do not restart)
2. For THD Series DVR:
  • Right-click anywhere on the screen and the drop-down menu will appear
  • Click on Main Menu (You may need to log in after this step)
  • Go to Maintenance option
  • Click on Default Sub-tab. On this screen, click on Factory Defaults to restore all parameters to default settings
  • Your system will restart after this step
3. For XHD Series DVR:
  • Right-click anywhere on the screen and the quick launch bar will appear at the bottom of the screen.
  • Select All to factory reset all your DVR Settings and click OK
4. For WNVR Series
  • Go to Maintain Tab
  • Select Factory Default Sub-tab on the left menu
  • On this screen, Select All to factory reset all your NVR Settings and click on Apply
Optics | Answered on Sep 21, 2020
Don't "unscrew" the binoculars. there are no user servicable parts inside. the collimnation adj screws are beneath the rubber boot just under where your index fingers rest when looking through the bino's. use a jewelers screwdriver to tease the boot up and stick a small nut or something in. then put the binos on a stable surface and play with the screws a bit while watching the images. you can get them pretty close this way.
Optics | Answered on Sep 15, 2020
If you still need this, I have it saved as a series of nine (9) .JPG "scans".
Optics | Answered on Aug 27, 2020
Get a new air rifle with more power?
Optics | Answered on Aug 09, 2020
You have not stated the make of this telescope, but from your description, it appears you have an astronomical telescope (for star-gazing). These scopes generally omit the correction lens in the optical path that inverts the image for terrestrial use. This is because light-gathering power is more important than orientation - after all, there is no 'up or down' in space.
It may be possible to obtain an additional correction lens - check with the manufacturer or seller. If this was not pointed out when you made the purchase, you may be entitled to a refund. Otherwise, just enjoy the Heavens.
Optics | Answered on Jul 20, 2020
Hello, Tanvi -
1. Your question landed in the Fixya category for optics. "Optics" has to do with sight. I doubt that is the correct category for the question.
2. Please explain what "weavers" you are asking about and where (what country.) Are you referring the issue of suicides in the cloth weaving industry in India?
Note: Fixya.com receives questions from people worldwide. Those of us who volunteer to answer on Fixya are not mind readers and cannot guess what is meant by a question without more details.
3. You can add more information regarding your question by choosing Comment and typing added details.
Best wishes.
Optics | Answered on Jun 11, 2020
Bounty Hunter Land Star Digital Metal Detector with Ground Trac Re-Tune - LSTAR w/FREE UPS Logo
7 questions posted
Top Bounty Hunter Optics Experts
Marvin
Marvin
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Bounty Hunter Optic Expert? Answer questions, earn points and help others
View Most Popular
  • Bounty Hunter Optics
Most Popular Question
will not detect
  • Optics
