20 Most Recent Euro-Pro Ninja Nj600 1000 Watt Xl Professional Blender Questions & Answers
The plastic container is cloudy and there seams to be a slight odor, it's a little over one year old we used 5 days a week for smoothies.
Plastic will get cloudy given the fact that you will crush seeds from all the fruits you put in it and they will act like a very fine sandaper when you make your smoothies.
3/31/2016 9:00:34 PM • Euro-Pro Ninja... • Answered on Mar 31, 2016
Why won't the blender start? the on/off light keeps blinking
my Ninja blender wont turn on, power button keeps blinking red ...
https://answers.yahoo.com/question/index?qid...
Dec 11, 2011 - I know I"m not supposed to drown myself in the toilet yet the don't build in a head protector. The blinking light won't go off. It worked last night ...
Ninja Blender Red Light Is Flashing ' Appliance Repair ...
appliancerepairquestions.com/question/ninja-blender-red-light-is-flashing/
Mar 29, 2015 - My new Ninja Blender has a power button that is flashing red. ... and the top of the blender is on and secure but the light keeps blinking / flashing. ... How do I set the oven off from demo mode asked by Anonymous, 2 months ago ....Whirlpool MDU1955XTSS2 won't turn on asked by Anonymous, 4 months ...
cuisinart blender red light flashing but Questions & Answers ...
www.fixya.com > Forum > Tags
12/26/2015 10:46:32 PM • Euro-Pro Ninja... • Answered on Dec 26, 2015
Power light is blinking and the blender will not work
Align the arrows on lid and handle, and latch it down before you put the pitcher on the base and spinning it to lock it in.
11/8/2014 3:06:00 AM • Euro-Pro Ninja... • Answered on Nov 08, 2014
The power light on the Ninja Blender flashes and will not turn on.
Make sure the pitcher lid is assembled properly aligning the arrow on the lid with the arrow on the handle. Press down firmly on the handle until you hear a slight click to ensure it is fully engaged. The Ninja will not run if the lid is not assembled correctly & the handle is not fully engaged.
9/28/2014 2:37:51 PM • Euro-Pro Ninja... • Answered on Sep 28, 2014
0answers
Blender doesn't turn on Ultex model 08333? Help!
Question edited for a touch more clarity, add some punctuation and fix typo, 'cantor' to 'center'. Question moved from Garden Category to Blenders. The unit doesn't exist https://www.google.com/search?q=ultex+model+08333 check power at the wall socket. Check the mains wire for breaks. If it is a Food Processor type unit, remove bowl and blade and push a pen tip into the safety interlock and try switching on. Ah, you spelled it wrong, it is and UltRex with an ' r '. It looks very old, $7 at auction. https://www.google.com/search?q=ultrex+model+08333 ...
2/2/2023 11:40:51 PM • Blenders • Answered 2 hours ago
Farberware cordless blender will not charge. Tried different outlets. Haven't even had it 2 months
It is possible that the charger for your Farberware blender is not functioning correctly. I suggest contacting Farberware for a replacement charger or repair instructions, as this is likely to be the best way to resolve the issue.
1/29/2023 11:14:53 PM • Blenders • Answered on Jan 29, 2023
Ronson on stick blender 8342 motor coupler
If you need a replacement motor coupler for your Ronson 8342 stick blender, there are a few options you can try:
  1. Check with the manufacturer: Contact Ronson customer support and inquire about the availability of a replacement motor coupler for your specific model of stick blender. They may be able to provide you with a replacement part or direct you to a authorized distributor.
  2. Check online retailers: Look for online retailers that sell parts for small appliances, such as Amazon or eBay. You may be able to find a replacement motor coupler for your Ronson stick blender.
  3. Check with local appliance repair shops: Local appliance repair shops may carry the replacement parts you need or have the contacts to help you find them.
It's worth noting that finding replacement parts for old appliances can be difficult and that's why it's always better to check with the manufacturer first. Also, you might want to have the model and serial number of your stick blender when reaching out to the manufacturer or other suppliers, as it will help them to identify the correct parts for your specific unit.
1/14/2023 4:00:34 PM • Blenders • Answered on Jan 14, 2023
2answers
Replace oster kitchen center base drive part
I'am the guy who posted the comment I found out how to do this.
There are 2 possible solutions the 2nd is not pretty, hope the first works for you it didn't for me.
1- The motor must be lock up, by placing a thin screwdriver through the holes in the base into the fan down into the motor,holding the screwdriver, remove the square drive from the top.The part you are trying to remove actually is screwed into a gear in the gear box, you will need a spanner wrench,(sometimes a strong pair of long nose pliers will work, engage the spanner holes,hold the screwdriver ,and try to unsrew it, you may need someone to hold the screwdriver,because it takes a lot of force to loosen it.These are regular threads,and unscew counter clockwise.
2- if #1 doesn't work-this will- but its not so pretty.The motor assembly attached to the gear box will have to be removed,it will come out as one piece
Remove the bottom plate,unplug the white wire from the speed control,and the blue- white wire from the board,also you will have to remove one of the brushes with the white -blk lead.
Now you will have to actually break off of the top plastic(bakelite)by whatever means you dream up (I actually used a small wood chisel to score a line, and crack it) once its cracked, it breaks apart easily.Once thats done turn it over and remove the four screws holding the gear box to the housing you will now be able to remove the gear-box motor assembly.
Remove the 3 screws from the top of the gear box pry the box open,remove the gear with the piece that needs to be replaced,now you need to get the piece unscrewed from the gear.I did this by locking the nurled end into a vise, and very carefully grabing the gear teeth with large channel locks(if you think of a better way thats great)it work for me,but I was very concerned about the gear teeth,you can't slip.
Try the new piece to make sure it sets all the way down to the bottom of the gear(it must or your head will be to high ,and won't lock down)if all is well,make sure everything is greased,and start re-assembly, the new coupler ,and the square drive will be the last 2 pieces assembled from the top, once again locking the motor with a small screwdriver.
12/13/2022 12:22:39 AM • Blenders • Answered on Dec 13, 2022
5answers
Why is my ninja blender not spinning ? I've had it for a while an used it many times how can I fix it?
Sounds like the gear is stripped inside
11/17/2022 2:19:47 AM • Blenders • Answered on Nov 17, 2022
Please my silver crest blender produces light sparkles when blending. Any help ?
It is probably due to a bad connection in the motor. You will need to take it apart and check the connections.
11/5/2022 12:55:54 PM • Blenders • Answered on Nov 05, 2022
2answers
Ninja Blender 1100 starts then stops almost immediately, is there a way to fix this?
It Could Be a Number of Things.. It's most likely that the electrical Wire Could Have a Shortage, If it cuts off again Try gently Wiggling the Electrical Wire in a Number of Directions If it cuts on and off while your fidgeting with it, you've found your Problem! A quick fix would be to Adjust the wire In the position it would cut on the strongest, wrap the cord with Tape to Keep the wire in that Position, this will Prevent it from shorting again. Either that or you simply put too much product in the Blender with an inadequate amount of liquid.
10/16/2022 6:43:20 PM • Blenders • Answered on Oct 16, 2022
How to open the blender case?
Google make model disassembly. all question s need 'make model (what it is)'.
9/4/2022 7:49:07 PM • Blenders • Answered on Sep 04, 2022
Euro-Pro Ninja Nj600 1000 Watt Xl Professional Blender Logo
Popular Tags
5 questions posted
Top Euro-Pro Blenders Experts
Tom Chichester
ADMIN Andrew
ADMIN Andrew
Kolbrun...
Are you an Euro-Pro Blender Expert? Answer questions, earn points and help others
View Most Popular
Euro-Pro Blenders
  • Euro-Pro Blenders
Most Popular Question
plastic container cloudy seams slight
  • Blenders
