20 Most Recent
Sony VAIO PCV-RX463DS PC Desktop Questions & Answers
Gateway 556ge 3 beeps no display
if you have graphic card remove it and clean with eraser and try it
if you dont have graphic card try cleaning the ram or replace it
11/14/2015 8:02:24 PM •
Sony VAIO...
Answered
on Nov 14, 2015
No sound
you need to download the proper device driver for your system, these are the things you need to do:
1. Know the model number of your desktop computer.
2. what operating system you use is it winxp, vista or win 7.
3. go to the web site of your system manufacturer, go to thier support and download section.
4. from the you will be asked for your system model or number.
5. what o.s. and from there you will find all the device driver for your system, just follow all the screen instructions when you will download this driver.
6. after you have downloaded it you will need to run and it will extract itself to a specific folder usually it is extracted to drive c:, open the folder where it is extracyed then run the setup
5/11/2010 3:26:06 AM •
Sony VAIO...
Answered
on May 11, 2010
Sony Vaio PCV RS-530G
I have a Sony vaio PCVRS 530G My problem is that the C drive has 13 Gb & D 80 Gb, how can I transfer from the D to the C drive. I'm always getting a message LOW MEMORY.
Thanks Luis V
2/21/2010 2:48:46 PM •
Sony VAIO...
Answered
on Feb 21, 2010
I would like to try to use my pcv-rx463ds with my
to be honest you would need to upgrade the the graphics /memory and processor as this is a very old spec computer , if you can repost your question with the included specs of your computer we might be able to give a better answer
11/12/2009 5:36:16 PM •
Sony VAIO...
Answered
on Nov 12, 2009
Cant load the os
your mobo might be broken.
Try to uptate or recover bios.
it can be done when changing jumpers on mobo.
read mobo book for excat settings
6/5/2009 5:09:11 PM •
Sony VAIO...
Answered
on Jun 05, 2009
PCV-RX463DS Sony Vaio Sound
- http://www.drivershq.com/Drivers/Sony/PCV-RX/PCV-RX463DS/9818/10169/10184/Drivers.aspx
- download the utility.
- tis should fix it.
2/19/2009 5:04:59 AM •
Sony VAIO...
Answered
on Feb 19, 2009
Sound card for sony viao
http://esupport.sony.com/US/perl/swu-list.pl?mdl=PCVRS712
It's probably included in the "motherboard", or chipset, download.
7/21/2008 8:43:12 PM •
Sony VAIO...
Answered
on Jul 21, 2008
Sony Vaio BX-BX61VN
Check the sony website the bx61vn is listed as a VGNBX61VN
http://www.sonystyle.com/webapp/wcs/stores/servlet/SYCustomerCare?storeId=10151&catalogId=10551&langId=-1
click on download drivers, click on select it, laptop/desktop/etc.
click on detect it.
3/13/2008 4:45:20 PM •
Sony VAIO...
Answered
on Mar 13, 2008
Video Decoder
if this has previously worked fine, then choices are:
1.) run "system restore" to an earlier date when you know it worked.
2.) re-install windows xp
10/5/2007 3:02:22 AM •
Sony VAIO...
Answered
on Oct 05, 2007
Code error 0xc0000185
Do you the Windows user suffer Error Code 0xc0000185 on your PC or laptop.
Well, this is a blue screen of a ***** error note telling me that your boot configuration info is missing (Error Code 0xc0000185)
This BSOD error code issues with a note - The Boot Configuration Data for your PC is missing some required information.
Causes of Error Code 0xc0000185:-
1. Suffer a cable attachment joining to your system and the hard drive.
2. Defective or missing boot files.
3. The disk drive gets damaged.
4. Wrong disk drive.
Solutions of Error Code 0xc0000185:-
1: Do sure that Wire is Correctly Connected [Only for PC]
2: Automated Repair
3: Check Hard Disk for Errors
4: Repair your System to Fix Error 0xc0000185
Full Solution -
9/14/2022 11:53:07 AM •
Sony VAIO...
Answered
on Sep 14, 2022
