20 Most Recent
Westinghouse WWBD2400HW 24 Inch Built-In Dishwasher Questions & Answers
Dishwaser will not empty the soap, does not matter if it is the cubes or crystals
Run it empy one time and see if it does the same thing. If it does then there is a water distribution issue. The spray bar is not getting enough water through it. If it does not work right when empty you should inspect the spray bars for plugged holes and then check the sump and pump area for debris. If the machine works when it is empty, check to see if you are loading it in a manner that obstructs the soap dispensor.
Water stays in dishwasher
It is a common fault that the drain fails to work in
most machines in a period of time and is the most problematic fault in a
washing machine. In all occasions it is important that your observation is most
important and so is vital to the identification /rectification and solution. If
you have noticed that water has leaked then as the drain hose pump/valve and
fittings are located on the underside of the machine it is important that you
look for possible leaks here. In some cases the drain hose would be clogged at
the drain end to outlet of the house and so there will be back flushing
resulting in overflow to the outside. Also the drain pump/valve can be clogged.
Now remove the drain hose clamps and remove the drain pump/valve, clean the
drain pump/valve, use back flushing to clear off all dirt. Now test using power
to see if this works and can be simulated. When refitting, the hose must be tightened
properly. If the pump/valve does not work even with power then it must be
replaced. If there is intermittent power
to the drain valve/pump then the program controller unit is a suspect.
How to fix h19 code popped upon Westinghouse dishwasher, please?
H19 is an error code indicating that the water draining has reached a certain threshold and has not been cleared properly. To fix this issue, you'll need to check the drain hose and ensure it is connected properly and not clogged. You should also check the drain pump to make sure that it is operating correctly and that it is not blocked. If these steps do not resolve the issue, it may be necessary to call a technician for further assistance.
Westinghouse dishwasher F5 error
google westinghouse dishwasher wsf6608x error codes f5
F5 signals an error in the water supply line, which may mean that the tap is not open far enough or that there is an error in water pressure
Westinghouse Dishwasher F5 Error - Water Level Fault
Westinghouse SB907 Top Draw Clips Replacement
Probably too late for you now :( I found this site.
http://spares.alliedappliance.com.au/
If you happen to have yours fixed, I would love instructions on how to reattach my top drawer to the clips! Can't find an image anywhere and just can't figure it out. sigh.
Westinghouse SB907 Dishwasher
ON the the control pannel it might show a symbol of a lock. You will need to hold that key or sometime Keys for 3 to 5 seconds to release the control lock.
