20 Most Recent
Westinghouse Range Stove Connector 5300604401 Wci Part Q000604401 Questions & Answers
How to fix h19 code popped upon Westinghouse dishwasher, please?
H19 is an error code indicating that the water draining has reached a certain threshold and has not been cleared properly. To fix this issue, you'll need to check the drain hose and ensure it is connected properly and not clogged. You should also check the drain pump to make sure that it is operating correctly and that it is not blocked. If these steps do not resolve the issue, it may be necessary to call a technician for further assistance.
Westinghouse dishwasher F5 error
google westinghouse dishwasher wsf6608x error codes f5
F5 signals an error in the water supply line, which may mean that the tap is not open far enough or that there is an error in water pressure
Westinghouse Dishwasher F5 Error - Water Level Fault
Westinghouse SB907 Top Draw Clips Replacement
Probably too late for you now :( I found this site.
http://spares.alliedappliance.com.au/
If you happen to have yours fixed, I would love instructions on how to reattach my top drawer to the clips! Can't find an image anywhere and just can't figure it out. sigh.
Westinghouse SB907 Dishwasher
ON the the control pannel it might show a symbol of a lock. You will need to hold that key or sometime Keys for 3 to 5 seconds to release the control lock.
Westinghouse Dishwasher 905,prewash light keeps
Gary Miller was closest. You can also try this:
After the outlet hose has drained, open the dishwasher door and blow hard into the outlet hose (try not to get any gunk in your mouth! I usually put my hand in between the hose and my mouth.
You will find a bit of resistance then it should clear. Remove the filter (the one you remove and clean after every wash) and see if there is any gunk in the sump. Remove what you can by drawing the water out as best you can and using a rag to remove the gunk. Close the door and see if it tries to fill. Let it fill for a while until there is some water in the sump. Do the blow through the outlet hose trick again to see if it has cleared.
If you ket the dishwasher drain via the outlet hose, any gunk in the hose will end up clogging it again.
