20 Most Recent
Sharp Actius AV18 Notebook Questions & Answers
Hello - exactly how
Can you locate the physical switch for the wireless on the laptop? If so, turn it off for 5 seconds and then turn it back on. If that doesn't work you may need to reinstall the wireless driver.
When try to boot up it says operating system not
This error comes when your harddrive is not detected properly or some os system files are missing.
For that when you power up the computer press F1 or F2 or "del" key to enter in bios then make sure your harddrive is recognized in bios if not then make sure SATA is disable then save settings .Then check.
If still same then you need windows disk or recovery disk to repair your windows missing files.
Let me know if you need further assistance.
Thanks for using FixYa.
Sharp Actius AV18 does not recognize added 512MB
I assume the laptop had originally 256Mb RAM and you put 512Mb RAM in a the spare memory slot and you expected to see 768Mb of memory, is this correct?
Try removing the 256Mb memory module and insert the 512Mb memory module and see if the laptop boots up with 512Mb of RAM. If it doesn't boot up then the RAM is either incompatible or faulty.
Try using RAM modules from the same manufacturer.
My bros e627 when he plugs it in to charge it sais
Check power adapter’s DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
PCI simply communication controller
Go to the Sharp WEB site to download the Windows XP or Vista driver for the device you require. If you have problems identifying the driver you require, send an e-mail to their support.
Use this link to get to Sharp support.
http://www.sharpusa.com/products/support/0,2309,,00.html
My pc-av18
I am assuming F2 takes you into the bios, sometimes the password can be dissabled in the notebook system settings menu, but try 'oooo' or 'ooooo'.
MY COMPUTER WONT WORK
ur computer may be infectedby some virus .. format the system parttion using some linux live cd parttion tools and try to reinstall the requird os
Adapter plug,for battery which is on the back is loose how do i fix it
Do you mean the socket on the laptop where the plug from the adaptor plugs into? If that is damaged it can be replaced by a repair shop and sometimes by a skilled user. The repair typically involves a fairly in depth disassembly of the laptop so the user would need to have fairly decent mechanical aptitude, a good assortment of small screwdrivers and experience handling electronics. If the laptop is still in warranty I would strongly recommend sending it to the manufacturer for repair. It may not be a warranty repair; however, if anyone else takes it apart you will void your warranty on anything else that may go wrong in the future.
Sharp HT-SB140 Sound Bar Internal PSU died
The Sharp HT-SB140 Sound Bar's internal PSU provides a DC output voltage of 19 volts. So you would need an external power supply that can provide a regulated DC voltage of 19V with the same or higher current rating as the original power supply.
When replacing the internal power supply with an external one, it is essential to ensure that the polarity of the output connector matches the polarity of the soundbar's internal PSU. The PW390-070 EF25 MF 1945 part number indicates that the power supply has a center-positive barrel connector. Therefore, you need to make sure that the replacement external PSU also has a center-positive connector.
It is also essential to make sure that the external power supply you choose can provide the same or higher power rating as the original internal PSU to ensure proper operation of the soundbar.
My Sharp xe-a506 register will not power on. Checked the power source and nothing.
If your Sharp XE-A506 register will not power on, there are a few possible reasons why this may be happening. First, check the power cord and ensure that it is securely plugged into both the register and a working outlet. If the cord is damaged or not properly connected, it may be preventing the register from receiving power.
If the power cord is in good condition and properly connected, the problem may be with the register itself. Try unplugging the register, waiting a few minutes, and then plugging it back in. This can sometimes reset the register and allow it to power on.
If the register still does not power on, there may be a problem with the register's internal power supply. In this case, it is best to contact Sharp customer support for assistance. They should be able to provide you with further guidance and help you troubleshoot the issue.
