20 Most Recent LG 6871ER1023Q Main Pwb pcb Assembly Questions & Answers
Replace the water inlet valve. It is an electronic tap and yours is leaking.
LG Washing... | Answered on Jun 12, 2020
I would have it repaired. PCBoards don't fail, components that are replaceable, fail.
LG Washing... | Answered on Jun 11, 2020
If your Samsung Washing Machine is displaying a SE/5E error code, it means that your washer is having draining issues
LG Washing... | Answered on Jun 05, 2020
Try this first before replacing any parts or disassembling your LG washer:
- Unplug the washing machine for 1 minute.
- Plug the washing machine back into power.
- Restart the wash cycle.
- The washing machine may now have cleared the PE error code, if not see below...thestoreguide
LG Washing... | Answered on Jun 02, 2020
If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. ... 1 Check the washing machine's spin cycle. If the spin cycle works, the motor is operating and the belt is not broken
https://www.hometips.com/repair-fix/washing-machine-agitate-spin.html
LG Washing... | Answered on May 29, 2020
If the wash, rinse and spin function lights all flash at the same time, this would indicate a possible blockage in your filter or waste / drain pipe.
https://www.indesitservice.co.uk/washing-machine-repair/troubleshooting
LG Washing... | Answered on May 23, 2020
How to reset the washing machine:
  1. Press POWER to turn the washer off.
  2. Unplug the washer from the power outlet or turn the circuit breaker to the unit off.
  3. With the power disabled, press and hold the START/PAUSE button for 5 seconds.
  4. Plug the washer back in, or turn the circuit breaker back on.
https://www.lg.com/us/support/help-library/le-error-code-CT00000305-1337701712239
Download manual
https://servlib.com/lg/washing-machine/wd-10485tp.html
LG Washing... | Answered on May 14, 2020
On some LG front loaders there are two water pumps. One is the normal water pump to remove the water down the drain. The other is a recirculating pump that pumps the water back to the top of the clothes near the front top of the interior. Sounds like this is the model you have. The part is inexpensive about $25-30. Fairly easy to replace. Doubtful you have a plugged line, but possible. Pretty common for a pump rotor to go out. Motor runs, but nothing happens. Personally I would replace the drain pump at the same time, since they are next to each other and both can go out. Try howto videos on repairclinic.com, appliancepartspros.com or youtube. You can find the OEM part numbers on repairclinic and then search eBay for better prices(sometimes).
LG Washing... | Answered on May 12, 2020
no fixing known by us buy a new unit in stainless steel
LG Washing... | Answered on May 09, 2020
Write your answer... [THIS COULD INDICATE A PROBLEM IN THE DRAIN PUMP WHICH TAKES WATER BACK TO THE MACHINE CONTROL]
LG Washing... | Answered on May 07, 2020
maybe the inlet filter is clogged
LG Washing... | Answered on Apr 30, 2020
LG 6871ER1023Q Main Pwb pcb Assembly Logo
1 questions posted
Top LG Washing Machines Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
LG Washing Machines
  • LG Washing Machines
Most Popular Question
get part discontinued
  • Washing Machines
