20 Most Recent LG WM3470HWA Front Load Washer WM3470HWA Questions & Answers
2answers
LG washing machine shuts off randomly, why?
only suggestion, next time it happens, unplug like you've done and then hold in power button for 15 seconds to see if that resets it.
1/3/2023 3:27:52 AM • LG WM3470HWA... • Answered on Jan 03, 2023
Why won't the our LG washer start unless it is unplugged an replugged in?
it appears that maybe the diagnostic computer isnt working as it should in the washer you can contact LG by phone to have them service the washer
11/2/2016 11:15:32 PM • LG WM3470HWA... • Answered on Nov 02, 2016
Replaced water pump and cannot remember order of hot/cold hoses
Here is the help you've been waiting for. Download this link. LG WM3470HWA Owner Manual Connecting The Water Lines
10/16/2015 10:32:55 AM • LG WM3470HWA... • Answered on Oct 16, 2015
Inconsistent leaking coming the back of the washer.
The inlet water valve for the cold water has three connections to it. There are a total of 5 hoses that put water in the machine. These are on the cold water side. Check them for leaks, cracks and tight connections.
7/25/2015 2:13:50 AM • LG WM3470HWA... • Answered on Jul 25, 2015
0answers
0answers
LG Washer gushing water out of the lint trap in bottom left corner
Get a flashlight and check the fittings. Yes there is a gasket.
2/15/2014 3:28:26 AM • LG WM3470HWA... • Answered on Feb 15, 2014
0answers
Machine doesnt start. the wash and spin indicator lights blink alternating
first try unplugging and waiting a minute and then plug in and see if that resets it. if it does not try unplugging, wait a minute, hold power button in for 15 secs and then plug back in and see if that resets it. and finally, try the second one and continue to hold power button in while plugging back in. all are different ways of resetting some washer models. one might work for you and cannot hurt to try. good luck
11/20/2022 7:26:11 PM • LG WM Washing... • Answered on Nov 20, 2022
2answers
LG Fuzzy Logic 8.2 kg top louder WF-8071TTP
This dE error or fault code to indicate that the door is not latching properly. Check the lid or door operation to be sure it's not binding and that the door alignment is correct. Also, check the door/lid hinges to be sure they're not binding. Finally, make sure the door catch is in place and not broken. You may need to replace the door hook/catch or the door lock assembly.
10/29/2018 1:31:58 PM • LG WM Washing... • Answered on Oct 29, 2018
LG error code
its best to get an engineer to the problem as it could be anything at all or just an alignment problem eric
12/27/2017 6:08:54 PM • LG WM Washing... • Answered on Dec 27, 2017
Indesit WM12X the wash program starts then freezes (The dial doesn't turn)
Sounds like the dial timer is defective, I am not affiliated with this site, https://www.repairclinic.com/Video
4/25/2017 4:31:21 AM • LG WM Washing... • Answered on Apr 25, 2017
LG washing machine Model No: WTH9556 manual
http://www.lg.com/au/support/support-product/lg-WT-H9556
3/29/2017 4:12:09 AM • LG WM Washing... • Answered on Mar 29, 2017
Why is my lg wd 1049c frnt loader washing machine leaking from the lh top cnr between the top drawer panel and the main body panel every time the machine fills, i have checked the powder drawer and th
Remove the screws that attach the top panel at the back of the machine, slide the top backwards and remove the top panel. Run the machine as per normal, but be careful as the electrics will now be exposed, you will be able to see where the water is leaking from and be able to repair/replace defective part.
8/15/2016 1:24:03 PM • LG WM Washing... • Answered on Aug 15, 2016
LG WM3470HWA Front Load Washer WM3470HWA Logo
13 questions posted
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
WM LG
  • WM LG
Most Popular Question
lg washing machine shuts off randomly
  • Washing Machines
