20 Most Recent
American Range AF-35/40 Gas Fryer Floor Model with Full Pot 35-50 lb. Capacity Questions & Answers
I have american range deep frying AF35/50..what is the suitable temperature to set for frying??
Recommended Frying Temperatures The actual temperatures and times used for frying will depend on the type of equipment used, the throughput and oil recovery rate, the size of the pieces being fried, the nature and condition of the frying fat or oil and upon local taste. However, the following temperatures and times are offered as a guide. Frozen foods may take up to a minute longer than the times indicated. Items Suggested Temperatures Approximate Time °C °F (minutes) Potato Chips, straight through 188 370 4-5 Potato Chips, blanching 166 330 4-6 Potato Chips, Browning 191 375 2-3 Potato Chips, frozen, blanched 180 355 4-5 Fish (battered pieces) 188 370 3-5 Prawns and Scampi (battered) 177 350 3-5 Meat cutlets 177 350 3-6 Chicken Pieces 171 340 6-12 Sausages 177 350 1-2 Fruit Fritters 177 350 2-4 Vegetables 177 350 2-4 Onion Rings 177 350 2-4 Doughnuts 188 370 1-2 Choux paste 182 360 1-2
FRYER DOES NOT STAY HOT ENOUGH
You probably will not like my solution.
Either get a fryer with more BTUs or put less in it. You might be able to partially pre-cook the tater tots and or fry's then you only will only need a few minutes to fry them and your heat should hold. If the heat holds they should no longer be greasy (Oily) when finished.
WISH TO KNOW BTU"S FOR MODEL AF-45 ????
Good Luck! there is not enough information to answer this question however FYI: A Brand New American Range Deep Fat Fryer Model AF-40 can be obtained with 90,000 BTU's Nat or LP gas
Help flames front of fryer
Hi there.
Try to check and clean if needed the fire tubes, soot may have build up inside blocking the flame path. Soot build up on fire tubes and burners are caused primarily by low gas pressure, assuming that the orifice size are correct with respect to the type of gas used.
Regards.
