20 Most Recent Whirlpool Gold Resource Saver GGE390LX 30" Freestanding Electric Double Oven Range with 5 Radiant Elements, 4.2 cu. ft. Lower Oven, TimeSavor Plus True Convection, Accubake, SteamClean Option, Hidden Bake Element and 2.5 cu. ft. Upper Oven Questions & Answers
Error message E6 F2
From investigation, I would open the control panel (make sure the power is turned off first!) Look for a ribbon cable that goes to the Touch Pad and Control pad module. It should be able to be removed from the control board. Pull out the ribbon cable, and put the ribbon cable back into the connector. Be careful with the cable as they can be broken easily. Once you have everything back together, turn the power back on and test the pad. If it still doesn't work, the control board may be bad.
11/7/2013 4:11:35 AM • Whirlpool Gold... • Answered on Nov 07, 2013
2answers
Whirlpool BFG1F3030S3N0V Hot water heater. I need the burner assembly please.
You can't mix and match gas appliance parts, it is too dangerous. Also all repairs have to be done by a gas certified technician. It looks like there are no parts available, time for a new one, or contact Whirlpool direct for advice. https://www.google.com/search?q=BFG1F3030S3N0V+parts ..
8/18/2022 5:12:19 AM • Whirlpool Water... • Answered on Aug 18, 2022
How can I find a Whirlpool Model # ND50T122-403 Flammable Vapor Sensor For my Water Heater?
Try National energy they are on line .
6/30/2022 4:28:49 PM • Whirlpool Water... • Answered on Jun 30, 2022
4answers
Troubleshooting whirlpool ee2h50rd045v water heater
1) Copy following links for whirlpool energy smart resources:http://waterheatertimer.org/pdf/Energy-Smart-troubleshooting-guide.pdfhttp://waterheatertimer.org/Whirlpool-Energy-Smart-electric.html2) Control box is probably bad.There are 2 types of control boxes for older-style energy smart water heaters.You will need model number and serial number from label on side of tank to order from Whirlpool.3) This older-type energy smart water heater is probably discontinued by AO-Smith, American, State, Craftmaster, Reliance water heater group that makes Whirlpool and Kenmore water heaters.New generation energy smart offers interface with home automation and/or non-existent smart grid.Older energy smart only offered potential interface with non-existent smart grid. If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
6/29/2022 5:43:48 AM • Whirlpool Water... • Answered on Jun 29, 2022
3answers
I discovered Whirlpool hot water heater was displaying E02 error code. Followed directions in manual to possibly correct problem, but E02 code continued to be displayed. What is the remedy for this?
Error E02 indicates that the water temperature exceeded high limit. Switch off the house circuit breakers dedicated to the water heater and then press the reset button located behind the control panel on the water heater. Switch house circuit breakers back on. If error persists, call a service engineer. good luck
6/22/2022 6:23:44 AM • Whirlpool Water... • Answered on Jun 22, 2022
My whirlpool smart water heater has been getting cooler for the last year. I now have the temp setting as high as it will go and soon will have no hot water. Is this a bad thermostat?
If it is like the one below the most likely reason is that the top element has failed and the bottom element is buried in limescale. If it is older than 10 years, it needs draining and servicing with new sacrificial anode. If it is older than 15 years it needs replacing. I replaced mine at 21 years as it just started to leak. The top element had failed 10 years earlier and there was 12" of scale on the bottom.
Whirlpool Energy Smart electric water heater
http://waterheatertimer.org > Whirlpool-Energy-Smart-...
These 208V-240V electric water heaters can be installed by homeowner without loss of 6 year or 10 year warranty. They do not have built-in timers, wifi, ...
5/14/2022 4:09:02 PM • Whirlpool Water... • Answered on May 14, 2022
Model # E3Z50RD055CV size 50 gallon whirlpool self cleaner water heater serial # 0051123062 Has lifetime warranty. Need 800 number so it can be replaced
They have a 6 or 9 year warranty according to this. http://www.whirlpoolwaterheaters.com/media/93187/psss1013-standardelectric.pdf companies that say 'Lifetime Warranty', are usually a company like Reliance, who will warranty for lifetime, but what they do it replace when it leaks and then put the price up to cover over the period of the guarantee. $600 price, 6 year warranty, your bill goes up $100 a year on top of what your were paying before. Clever marketing. Bad reviews https://www.consumeraffairs.com/homeowners/whirlpool_water_heaters.html CONTACT US BY PHONE Contact Whirlpool® Residential Technical Support at 1-833-747-0686 Here is the Warranty check, and it doesn't like your serial number! I tried dropping a zero and a 1. http://www.whirlpoolwaterheaters.com/owner-center/need-more-help/ Let me know how you get on please. ..
10/11/2021 11:50:03 PM • Whirlpool Water... • Answered on Oct 11, 2021
2answers
2answers
Model ee3j50rd045v whirlpool electric water heater
The only Whirlpool electric heater I know with control board is Energy Smart electric:
Open following link to identify product and download sample manual:
First of all, the water heater is always full of water.
When you turn on hot water tap, hot leaves top of tank, and new cold water immediately enters bottom of tank through the dip tube. The tank never has air pockets as these would damage tank as explosive steam would fill that pocket ... remember they used to run locomotives with steam power.
So the tank is always full of water, and you know that since no air comes out of the hot water faucet.
http://waterheatertimer.org/How-it-works.html
You did not say if this is new heater, or if heater was working correctly and stopped functioning.
What you describe does not sound normal.
I suggest calling Whirlpool at 1-877-817-6750.
You need to have serial number and model number from label on side of tank so product can be fully identified by Whirlpool.
If control board is bad, they will know and will sell you new board.
Installation is easy, and wires are color coded.
Replacement comes with instructions.
Add a comment with your experience so others with same-similar problem can benefit.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
10/18/2020 2:26:12 PM • Whirlpool Water... • Answered on Oct 18, 2020
My whirlpool gas water heater model N50T61-403 has gone out. I have tried restarting it 3 times per the manufacturers instructions. Any idea what the problem is.
My first suspect is the thermocouple has failed (they should be changed periodically, every 5-7 years as they do fail). Without the signal from the thermocouple, the gas valve can not open and start the ignition process.
1/18/2020 6:24:26 AM • Whirlpool Water... • Answered on Jan 18, 2020
Whirlpool Gas Water heater N50T61-403 Senor failure error
Whirlpool sold the AO Smith brand flue damper, and the atmospheric models ... both models have different honeywell gas controls... Error codes, service manuals and troubleshoot appear following link: http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#honeywell There is no specific service manual available for the flue damper series in 2019
11/10/2019 12:24:34 AM • Whirlpool Water... • Answered on Nov 10, 2019
Whirlpool water heater flash code 6 and burner doesn't come on but pilot is on.
6 flashes is typically found with power vented and flue damper type heaters ... whirlpool never sold a power vent, but they did sell the AO Smith brand flue damper series heater. The following manual suggest the problem is either gas supply or pilot assembly. http://waterheatertimer.org/pdf/Power-damper-troubleshoot-parts-manual.pdf More resources on following link: http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#honeywell
11/4/2019 6:47:47 PM • Whirlpool Water... • Answered on Nov 04, 2019
How do you get a 5 yr. old Whirlpool hot water heater lit?
it is a WATER HEATER. you do not need to heat HOT water. Gas or electric? Electric = turn power on Gas = instructions are on gas valve or in your manual. does not light = verify a spark at burner when you push button (can be hard to see, turn off lights), verify gas valves are on and another appliance has gas, call for service.
9/5/2019 3:25:34 PM • Whirlpool Water... • Answered on Sep 05, 2019
Replacing sensor on whirlpool water heater
Water heaters only have a top and bottom thermostats which seldom go bad. Heating elements wear out most often. If you are running out of hot water too quickly kill the power drain the tank and remove bottom heating element using a special large socket. Visual inspection should tell you if it is melted. If it is ok check the top heating element. If the heater was on and the tank not full the top element will go first. Elements never operate at the same time
3/21/2019 10:21:37 PM • Whirlpool Water... • Answered on Mar 21, 2019
How can I unlock the digital thermometer control so that I can change the setting. I have a energy smart Whirlpool water heater
CONTROL PANEL LOCK - Holding this button for more than 3 seconds switches the lock mode on or off. When the User Module is locked, a symbol and "Lock" text will be visible on the display. No model posted, so used the following energy smart http://www.whirlpoolwaterheaters.com/media/123507/318686.pdf
3/4/2019 6:52:40 PM • Whirlpool Water... • Answered on Mar 04, 2019
Whirlpool Gold Resource Saver GGE390LX 30" Freestanding Electric Double Oven Range with 5 Radiant Elements, 4.2 cu. ft. Lower Oven, TimeSavor Plus True Convection, Accubake, SteamClean Option, Hidden Bake Element and 2.5 cu. ft. Upper Oven Logo
7 questions posted
Top Whirlpool Water Heaters Experts
Paul Carew
Are you a Whirlpool Water Heater Expert? Answer questions, earn points and help others
View Most Popular
  • Whirlpool Water Heaters
Most Popular Question
error message e6 f2
  • Water Heaters
