20 Most Recent Samsung WA5451ANW 4.7 Cu. Ft. White Top-Load ENERGY STAR Washer Questions & Answers
hum not good
sounds like something has fused and blown the mains
you need to look too a control board error for this ...
its a job for a tech,... for sure..
Samsung... | Answered on Mar 05, 2015
Possible that the cut off to the Inlet valve has failed which means that the controller unit is a suspect. Also if the inlet valve is staying ON even when the power is cut off , then it is a case of inlet valve failure.
Samsung... | Answered on Dec 31, 2012
Go to www.allerrors.com for an explanation.
Samsung Washing... | Answered 3 hours ago
Owner's manual, troubleshooting see what it means, No manual try https://www.manualslib.com or google details and code to see what it means.
Samsung Washing... | Answered on Jun 29, 2020
  1. Power off, and then power on the washing machine.
  2. Hold down Temp. and Delay End+ simultaneously for 3 seconds to enter Calibration mode. ...
  3. Press and hold Start/Pause (Hold to Start) to run the Calibration cycle. ...
  4. When the cycle is complete, "0" appears on the display and the washing machine will turn off automatically.
Samsung Washing... | Answered on Jun 14, 2020
After 5 Seconds on gargle .....
When the 3E error appears on the display, the washing stops. The process does not resume until the fault code's eliminating. This code corresponds to a tacho sensor error - a weak or missing signal.
The washer can show the 3E error when:
  • Excessive loading of the drum with laundry;
  • Jamming of foreign objects between the drum and the tank;
  • The temporary malfunction in the control module;
  • The failure of the hall sensor;
  • Vibration sensor failure;
  • The weakening of the drive belt;
  • Reduced engine power, which is possible due to worn brushes or broken windings;
  • Malfunction of the control module.
Samsung Washing... | Answered on Jun 11, 2020
If your Samsung washer is in the middle of a drain cycle and the 5E error code shows on your washers display, it means that the water is not properly draining out of the washer. Something may be clogged, jammed, or blocked and thus preventing water from draining out of the washer.
https://removeandreplace.com/2016/11/03/samsung-washer-displays-error-code-5e-message-how-to-clear-error/
Samsung Washing... | Answered on May 21, 2020
Hello, have you checked the filter in the front to see if it may be clogged ? or You may have a board problem or possibly a bad pump motor. I suggest an appliance repair guy, if your savvy with a trouble shoot go for it ! Hopes this helps !
Samsung Washing... | Answered on May 07, 2020
WASHER WILL NOT START:
Power
If your washing machine won't start, begin by looking at the power source. First of all, is the washing machine plugged in? If it is, has it tripped a circuit breaker or blown a fuse? Check and reset the breaker (orreplace the fuse) if necessary.
Lid Switch
The main control for the washing machine is the switch inside the lid. If this has stopped working for some reason, your washing machine won't start. It's not especially difficult to troubleshoot this on a washing machine. You might have to open the top to access the switch. With the power on, depress the switch and listen for a click. If you don't hear one,the switch MAY BE BADand will need to be replaced.Confirm defectiveness with a multi meter checking for continuity OHMS. An open circuit reflects a bad switch..
If the switch works but the washing machine still won't start, check to see if your washing machine has a special fuse for the lid switch. It will usually be inside the control panel. If it's blown, you'll need to replace it before the washing machine will start.
Door Interlock
The problem could be with the door interlock. If the lights come on but the machine won't start, this might well be the cause. This could either be down to the wiring that runs to the door interlock, or the door catch not activating the interlock itself.
Timer Knob
Some models of washing machine use a mechanical timer knob and won't run until the water in the machine has filled to the selected level. If the knob doesn't line up properly with the graphics on the control panel, you can try to troubleshoot the washing machine problem by advancing the timer a little. When you've done this, pull it out a little way and see if the washing machine will start properly.
Push start switchmay need to be tested with a multi meter for continuity OHMS should show a closed circuit when pushed in or turned on.
The start switchon some top load washers is often part of the timer and is activated by pulling out on the timer knob. Although not normally available as a separate part, the switch can be tested for continuity with a multi-meter. You will need to remove power from the appliance and then locate the correct timer contacts as noted on the wiring diagram. On some electronic controlled models, the start switch is a momentary contact type switch located on the control console. You can test this switch for continuity with a multi-meter when the push button is held in
Overheating
If you've run several loads, one after another, without any problem but suddenly find your washing machine refuses to start, overheating could be the cause. The simple way to discover whether this is the problem is to give the machine ample time to cool down, say for a couple of hours, and then try it again. If it works fine, overheating has been the problem and you may have a motor with bad windings.
By the way my advice is freecuzGod is good!
All washing machines use a motor that is responsible for spinning and agitating during the cleaning cycle. Many top load brands use a reversing motor which means the motor spins in one direction for agitating and another for spinning and draining. If the motor does not start, but makes a humming or buzzing noise then it may be defective. To verify if the motor is at fault, remove the drive and /or pump belts and then try to start the motor again. On direct drive models, you will have to disengage the pump and the direct drive coupling to the transmission. If the motor starts, then the problem is with the transmission or the pump and can be further diagnosed by reconnecting each one individually. If the motor does not start or continues to hum or buzz, then it will need to be replaced
Lastly CONTROL BOARD
If the control board does not provide the proper voltage to the drive motor, fill valve, drain motor or door lock then the washer may not start. The main control board on most washers is complicated and difficult to diagnose without proper test equipment and procedures. You can visually inspect the control for signs of electrical arcing or burned or damaged components on the board. You should use caution when replacing a control board as sometimes the burned components are caused by external component failures.
https://www.repairclinic.com/RepairHelp/Washing-Machine-Repair-Help
http://www.partselect.com/Repair/Washer/Will-Not-Start/
Samsung Washing... | Answered on Apr 29, 2020
Your washing machine is flashing a fault code. As per the technical sheet, the fault code is E42. This code implies the door lock or control board is faulty. To confirm this you need to run specific tests for each. Disconnect the power and try to open the door, if it opens, the control board is the problem. If the door remains closed and you are unable to open it, the door lock is defective. In your particular case based on the symptoms, the issue could be the control board. You may need to replace it for it to work. This is an easy component to replace and can be done by you. You first need to remove the top of the washer to reach the screws which hold the control panel and board in position.
A washing machine making a loud noise when spinning means a part has become worn out or loose. ... If the loud noise only happens when the washer is in spin mode, this can be a sign that the main tub bearing is worn out. To fix your washer yourself, you may need to find your Washing Machine Service Repair manual..https://removeandreplace.com/2015/07/27/washing-machine-making-noise-during-the-spin-cycle-how-to-fix/
Samsung Washing... | Answered on Apr 17, 2020
Samsung WA5451ANW 4.7 Cu. Ft. White Top-Load ENERGY STAR Washer Logo
9 questions posted
Top Samsung Washing Machines Experts
Eric Rotmil
Eric Rotmil
Marvin
Marvin
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Washing Machines
Most Popular Question
samsung top load washer wa5451anw will
  • Washing Machines
