20 Most Recent Samsung WF520ABP - 5.0 cu. ft. Steam Washer Questions & Answers
The 5E error mean:
Pump won’t empty - not draining
As usual with these error codes for not draining the first thing to do is check the pump filter but, on Samsung washing machines, the drain pump itself is often faulty. You can find how to fix this problem on youtube, just text it "Samsung washing machine 5E error".
Samsung WF520ABP... | Answered on May 16, 2017
The 4E code indicates a water supply problem, most commonly a blocked or kinked hose.
Samsung Washing... | Answered on Jul 26, 2020
The cycle timer behind the control panel may have become "out of sorts" and will have to be replaced. This is a frequent cause of washer malfunction.
Samsung Washing... | Answered on Jul 25, 2020
Go to www.allerrors.com for an explanation.
Samsung Washing... | Answered on Jul 16, 2020
Owner's manual, troubleshooting see what it means, No manual try https://www.manualslib.com or google details and code to see what it means.
Samsung Washing... | Answered on Jun 29, 2020
  1. Power off, and then power on the washing machine.
  2. Hold down Temp. and Delay End+ simultaneously for 3 seconds to enter Calibration mode. ...
  3. Press and hold Start/Pause (Hold to Start) to run the Calibration cycle. ...
  4. When the cycle is complete, "0" appears on the display and the washing machine will turn off automatically.
Samsung Washing... | Answered on Jun 14, 2020
After 5 Seconds on gargle .....
When the 3E error appears on the display, the washing stops. The process does not resume until the fault code's eliminating. This code corresponds to a tacho sensor error - a weak or missing signal.
The washer can show the 3E error when:
  • Excessive loading of the drum with laundry;
  • Jamming of foreign objects between the drum and the tank;
  • The temporary malfunction in the control module;
  • The failure of the hall sensor;
  • Vibration sensor failure;
  • The weakening of the drive belt;
  • Reduced engine power, which is possible due to worn brushes or broken windings;
  • Malfunction of the control module.
Samsung Washing... | Answered on Jun 11, 2020
If your Samsung washer is in the middle of a drain cycle and the 5E error code shows on your washers display, it means that the water is not properly draining out of the washer. Something may be clogged, jammed, or blocked and thus preventing water from draining out of the washer.
https://removeandreplace.com/2016/11/03/samsung-washer-displays-error-code-5e-message-how-to-clear-error/
Samsung Washing... | Answered on May 21, 2020
Samsung WF520ABP - 5.0 cu. ft. Steam Washer Logo
5 questions posted
Top Samsung Washing Machines Experts
Eric Rotmil
Eric Rotmil
Marvin
Marvin
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Washing Machines
Most Popular Question
samsung front loader stopping error
  • Washing Machines
