20 Most Recent Rinnai RL94i Tankless Water Heater Questions & Answers
Rinnai RL94i - Produces hot water for 3 minutes, then stops
I just had this exact problem. It kept getting worse until we had no water. Our Rinnai tankless hot water heater started the same way though, with hot water for a few minutes and then would shut off with an error code 10. We just had to shut the hot water off and then back on, wait a minute or so and we had hot water back for a few minutes. Our unit would come on with a loud vibrating noise and remain until it shut off with an error code 10 (air flow fault). The solution was to remove the blower fan and blow out the squirrel cage. Ours had moths in it. We also vacuumed out the fan housing. Be careful to mark any wires you disconnect and take pictures before removal. Our unit is now almost silent when it comes on and supplies endless hot water.
8/11/2016 10:11:44 AM • Rinnai RL94i... • Answered on Aug 11, 2016
Can you convert the tankless water heater model # RL94in from natural gas to propane?
Contact Rinna Some water heaters allows changeover by installing new chipboard or changing dip switches... some do not. Propane burns much hotter with higher pressure than natural gas Gene Water Heater Timers Save Money If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
2/15/2015 3:57:02 AM • Rinnai RL94i... • Answered on Feb 15, 2015
0answers
0answers
0answers
Rinnai Water Heater. It is not heating?
Ideas in this link, but gas heaters need professional repair by a gas registered technician. https://www.google.com/search?q=Rinnai+Water+Heater.+It+is+not+heating ..
11/27/2023 12:57:52 AM • Rinnai Water... • Answered on Nov 27, 2023
2answers
Rinnai r85 not firing up (but I have power to the controller) with no error codes
I could not find r85 model on rinnai website. There is a troubleshooting guide on rinnai website. 100000652-Troubleshooting TWH Diagnostic Codes.pdf (rinnai.us) It may help to find a solution.
10/14/2023 5:29:33 AM • Rinnai Water... • Answered on Oct 14, 2023
My Rinnai Tankless gas water
1/24/2023 10:22:11 PM • Rinnai Water... • Answered on Jan 24, 2023
Rinnai E110CN Condensing Natural Gas Boiler will not maintain Domestic Hot Water.
Question edited for clarity. Question moved from Kitchen Ranges. Sounds like the temperature sensor is failing. https://www.google.com/search?q=rinnai+e110cn+set+back+temperature ..
11/27/2022 7:49:22 PM • Rinnai Water... • Answered on Nov 27, 2022
Our hot water will stop coming through the tap until we reset it on the rinnai wall control and then it works again?
trouble shooting section will help https://sahotwater.com.au/specifications/Rinnai/Service%20manual/smV1616W_V2018W_V2020W.pdf
7/19/2022 2:22:44 PM • Rinnai Water... • Answered on Jul 19, 2022
R85 tankless water heater running cold.
possible bad power transformer or unit is overheating
3/27/2022 4:57:16 AM • Rinnai Water... • Answered on Mar 27, 2022
I have a Rinnai energy saver 431F
if unit is igniting check to see if gas valve opens if yes check burner tubes for cob webs
1/20/2022 3:28:13 AM • Rinnai Water... • Answered on Jan 20, 2022
Please help, water not hot in shower
If it is hot in the kitchen, then once the water has reached the shower it should be hot. The leads me to believe that the issue is with your shower mixer unit. Nearly all are thermostatically controlled. Or, if the heater is downstairs and the bathroom is upstairs, you don't have enough hot water pressure. You need a good plumber with a pressure tester (called a manometer).
8/6/2021 3:55:35 AM • Rinnai Water... • Answered on Aug 06, 2021
Model rl75. What does code 10 indicate?
A Rinnai fault code 10 is an indication of either an issue with the air intake or a blocked flue. Your first step should always be turning your system on and off to see if the Rinnaifault code 10 has disappeared. If it hasn't, check the vent system for blockages and other issues that could prevent airflow.
12/26/2020 9:10:30 AM • Rinnai Water... • Answered on Dec 26, 2020
Are Kruger tankless water heaters good?
One thing they don't tell you about tankless heaters is that when they turn on, they may cause the lights in the house to flicker. Make sure that you have a good breaker panel (one that is relatively new with plenty of capacity) and run a circuit specifically for the tankless heater.
4/27/2020 4:31:57 AM • Rinnai Water... • Answered on Apr 27, 2020
Cant get power to my rinnai...went to turn on and it has no power to it,,checked all electical and fuses but still wont turn on
Push breaker(s) fully off and then back on. ... then open the tankless and carefully test across the terminals where wires connect to heater... Tape tester leads to wood sticks to keep hands away from power Following link has wiring for tankless electric http://waterheatertimer.org/How-to-wire-Tankless-electric-water-heater-new.html
10/28/2019 5:28:58 AM • Rinnai Water... • Answered on Oct 28, 2019
4answers
Runs out of hot water
I wonder if you have this problem below caused by a drop in water pressure from someone flushing a toilet or a washing machine. I would call the company to remedy this issue.
17. What is a cold water sandwich effect? The term “cold water sandwich effect” is a term that is used to describe the introduction of cold water into the hot water supply line during frequent on/off operation of an instantaneous water heater. The cold water sandwich effect, when present, appears as a momentary drop in hot water temperature as it is discharged from a hot water supply outlet (i.e. shower, tub, or faucet). This phenomenon is present in the operation of all instantaneous, tankless style, water heaters, but is minimized with the high tech design of Rinnai water heaters.
The technology built into the Rinnai water heaters is designed to minimize the cold water sandwich effect. Rinnai water heaters are microprocessor controlled and when water flow through them ceases, they remain in a “ready to fire state” for approximately 1 minute. If water flow through a Rinnai water heater begins within the first minute following water flow stoppage, the water heater will fire back up within 1 to 2 seconds. This minimizes the cold water sandwich effect that would otherwise be experienced with a low tech tankless water heater. It should be noted that the cold water sandwich effect cannot be removed completely from tankless style water heaters. The safety standards developed to insure the safe operation of water heaters require a delay in the ignition sequence of all gas water heaters.
While the cold water sandwich effect cannot be completely eliminated from standard plumbing systems, it can be eliminated from plumbing systems that have a supply and return hot water circulating system. Rinnai has developed 2 methods to eliminate the cold water sandwich effect in residential hot water circulating systems.
The first (and preferred) method to remove the cold water sandwich from circulating systems utilizes a small electric tank water heater (powered up) that is used with a dual purpose. The small water heater acts as a mixing tank to eliminate the cold water sandwich effect from the Rinnai water heater and it uses its electric heating element to offset the heat losses from the hot water circulating system.
The second method to remove the cold water sandwich from circulating systems utilizes a small 2 to 6 gallon storage tank installed on the hot water outlet of the Rinnai water heater. This tank acts as a mixing tank to blend the cold water sandwich with hot water and eliminating its effect at fixtures.
7/12/2019 1:36:46 AM • Rinnai Water... • Answered on Jul 12, 2019
Rinnai water heater V65 keeps beeping
Unplug it and plug it back in it should work
4/4/2019 10:44:25 PM • Rinnai Water... • Answered on Apr 04, 2019
Rinnai RL94i Tankless Water Heater Logo
9 questions posted
Top Rinnai Water Heaters Experts
vince
Paul Carew
Are you a Rinnai Water Heater Expert? Answer questions, earn points and help others
View Most Popular
  • Rinnai Water Heaters
Most Popular Question
rinnai rl94i produces hot water 3
  • Water Heaters
