20 Most Recent KitchenAid KGCC566RBL - 5 Burners Gas-on-Glass Surface Gas 36"Width Questions & Answers
Had a spill on my kitchenaid KGCC566RBL gas glass cooktop. some dripped in the knobs and under the glass top. How do I access that to clean?
I found this...... https://www.doityourself.com/stry/how-to-replace-a-glass-cooktop-on-kitchenaid-ranges I read it and it's on replacing but the top comes out. Gloves are a good idea too. Cut power at the breaker. unless easy access to the wiring/plug. Hope this helps you. Have a good evening.
2/2/2018 1:01:01 AM • KitchenAid... • Answered on Feb 02, 2018
My Kitchen aid cooktop model number KECC667BBL won't turn on
Mis-wired or the new control panel is faulty. Call them back, it is under repair warranty. The parts aren't cheap! https://www.searspartsdirect.com/model/41v4g0ja62-000593/kitchenaid-kecc667bbl01-electric-cooktop-parts ..
2/9/2022 7:12:27 PM • KitchenAid... • Answered on Feb 09, 2022
2answers
My intermittent ignition device on kitchen aid stove is not clicking.
igniter failed
2/1/2022 2:58:28 PM • KitchenAid... • Answered on Feb 01, 2022
Kitchenaid Electric cooktop KECCD805HBL3 Left front 8" eye only cycles at high heat no matter what the setting. Do I need a new eye or switch or both?
Almost certainly the switch, not the element, Had the same problem on a different stove - went to 10 no matter what the knob was set to. Here is a parts list, you should be able to get the part from a local appliance part seller. I used ReliableParts in my town. https://www.partselect.com/ModelSections.aspx?ModelID=815598&ModelNum=KECD805HBL3&mfgModelNum=&ManufactureID=3&Selected=ZPGZLZRB&Position=2&mfg=Whirlpool&Type=Cooktop&Mark=2
10/31/2019 9:34:41 PM • KitchenAid... • Answered on Oct 31, 2019
I'm installing a kitchen aid cooktop. How do you attatch brackets on cooktop installation?
They go under the counter and they are screwed in place
2/7/2017 12:14:50 AM • KitchenAid... • Answered on Feb 07, 2017
After we had a tech to fix the glass top and one burner, the f1:e1 code came out and kept beeping. I was told it could be the control board problem. Could it be loosen wiring problem too?
Hi, Need model number of your range to answer this question. Is this gas or electric? Is this a freestanding range or cooktop because I only can find information on ranges with this fault code given. All should EEPROM communication error which is a communication error on start up. when the top was damaged was the unit being used? Was water or liquid a factor when this damage happened? A loose wire would be a different error code or fault code like a F2 - E1 or E2, not your code given. I hope this helps, need more information. Thanks I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
4/19/2016 12:17:22 PM • KitchenAid... • Answered on Apr 19, 2016
After we had a tech replacing a new glass cooktop and one burner, the f1:e1 came out and kept beeping. could it be loosen wire or the problem of the control board?
Call the repair company to come back. It's possible he didn't hook something up right. ...
4/17/2016 6:02:40 PM • KitchenAid... • Answered on Apr 17, 2016
This is not the oven it is the cook top. After it was accidently turned all off and locked I can not get it to turn back on.
To Unlock Cooktop: Touch and hold the CONTROL LOCK/ ALL OFF keypad for 5 seconds.
12/6/2015 11:04:12 PM • KitchenAid... • Answered on Dec 06, 2015
Change ignition control module
changing everything on this kitchenaid cooktop video
6/27/2015 11:33:48 PM • KitchenAid... • Answered on Jun 27, 2015
Kitchenaidstove top ignition problem
Everything about It.. Thanks for watching
3/21/2015 11:33:05 PM • KitchenAid... • Answered on Mar 21, 2015
Gas cooktop keeps locking and clicking
How I fix this problem! Thanks For Your time!
3/21/2015 11:30:25 PM • KitchenAid... • Answered on Mar 21, 2015
Electric shock
Get yourself a $5 electric socket tester at a place like Lowes or Home Depot and check all of your electric plugs it will tell you if all three wires in the socket are correct, wire wrong or if one is open,
2/20/2015 5:10:22 AM • KitchenAid... • Answered on Feb 20, 2015
2answers
Constant clicking from electric pilot
Hi nancypp,
The ignition switches probably got wet.
Please follow my below Tip on how to fix it:
GAS STOVE CLICKING PROBLEM...
Kind Regards
JEDEMEYER1
* If this solution helped you, please accept it
11/26/2014 1:06:26 AM • KitchenAid... • Answered on Nov 26, 2014
KitchenAid KGCC566RBL - 5 Burners Gas-on-Glass Surface Gas 36"Width Logo
3 questions posted
Top KitchenAid Cooktops Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a KitchenAid Cooktop Expert? Answer questions, earn points and help others
View Most Popular
KitchenAid Cooktops
  • KitchenAid Cooktops
Most Popular Question
spill kitchenaid kgcc566rbl gas glass
  • Cooktops
