20 Most Recent Reliance 50 Gal. Electric Water Heater 6-50-DORS Questions & Answers
Should I have power at both elements all the time?
Push circuit breaker fully off and then fully ON Test for 240 volt across top twp screws on upper thermostat. If tank was not full of water when breaker was turned on, then upper element burned out. http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#new Yes both elements will test for 120 volt to ground at all times... but it takes 240 volt to heat element http://waterheatertimer.org/Element-tests-for-120-Volts.html Gene Water Heater Timers Save Money If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
3/15/2015 6:43:51 AM • Reliance 50 Gal.... • Answered on Mar 15, 2015
Why don't I have hot water when I have replaced both elements and thermostats?
Yellow Pages Contact a Plumber
3/14/2015 12:45:27 PM • Reliance 50 Gal.... • Answered on Mar 14, 2015
2answers
Are all 25VS FV sensors equivalent?
I personally wouldn't replace a safety device (placed there by lawyers, lawsuits and the all knowing government) with anything other than OEM. While it's very likely that one manufacturers flammable vapor sensor may interchange on another brand of tank, I think it's highly unlikely that EVERY manufacturers sensor will work on every other brand of tank
10/15/2022 9:09:47 PM • Reliance Water... • Answered on Oct 15, 2022
How do I drain my hot water tank that has no drain valve?
Shut off water open lowest drian/ tap off water will run off there .It will take the pressure off
11/14/2021 10:39:53 PM • Reliance Water... • Answered on Nov 14, 2021
I have a Reliance water heater that pilot won't light. Model6-30-nomt 400 Need some troubleshooting ideas
check gas flow of tube if ok replace pilot generator
12/19/2020 7:29:46 AM • Reliance Water... • Answered on Dec 19, 2020
A.O. Smith Water Heater. What does error code of 991 indicate?
Here you are Dorothy AO Smith code 991 Solution for error code 991 Check the gas type of the water heater. Inspect the environment around the water heater. ... Check if there is grease and/or dirt in the burner (Part #101) and the fan motor (Part #103), especially if the water heater has been installed in a contaminated area.
Error code '991' for type ATI-110C-N by AO Smith. Cause and ...
More help here, but you probably need a service call, especially if it is a gas water heater. https://www.google.com/search?q=error+code+of+991 ..
11/30/2020 8:35:13 PM • Reliance Water... • Answered on Nov 30, 2020
Reliance 40 gal elec water heater will not drain to allow me to change bottom element??? What's up?
The heater could be clogged with sediment.
11/30/2020 5:39:09 PM • Reliance Water... • Answered on Nov 30, 2020
Reliance propane water heater. Water too hot, even at lowest setting. Reliance sent new thermostat, same thing! Now they tell me it's because we don't use enough hot water! Is it possible?
The thermostat controls the water temp regardless of how much you use . Not using hot water the heater will cut in just to keep temp up to setting .
10/28/2020 2:59:59 PM • Reliance Water... • Answered on Oct 28, 2020
DOES THE RELIANCE 606 WATER HEATER USE THE SAME UPPER AND LOWER ELEMENTS?
nope the 606 is gas and dont use elements
9/8/2019 2:03:02 PM • Reliance Water... • Answered on Sep 08, 2019
Reliance 606 gas hot water heater went out did what directions said wont light , what do i do
Thermocouple is the issue most likely page 17 in link. if your heater has a fame arrestor it may be dirty and restriction air into combustion chamber http://www.reliancewaterheaters.com/media/72552/100264285-RELIANCE-N3-GAS-ULN.pdf
5/28/2019 2:55:15 AM • Reliance Water... • Answered on May 28, 2019
2016 reliance gas water heater won't do rapaid heat
Please call for service.
3/28/2019 11:00:49 PM • Reliance Water... • Answered on Mar 28, 2019
Why won't the main water supply knob turn to allow water to the water heater
Shut off unit then turn off water to house at water main out side. Drain water heater remove old valve install new
1/24/2019 6:15:16 AM • Reliance Water... • Answered on Jan 24, 2019
MY RELIANCE WATER HEATER SHUTS OFF AND I HAVE TO KEEP PUSHING THE RESET BUTTON. HOW CAN I FIX THIS?
Why Does My Electric Water Heater Reset Button Keep Tripping? So the red reset button on your electric water heater keeps popping out and needing to be reset. Here's the most likely problem: The water in your water heater is getting too hot. When the water temperature in your water heater exceeds 180°, the red reset button (also known as the high-limit switch) trips. This tripping protects you from getting scalded or burned when using hot water in your home. OK, but then what's causing the water in your water heater to get so hot? The most likely cause is a bad thermostat. How a bad thermostat causes your water heater reset button to trip Electric water heaters have a lower and upper thermostat-one for each heating element. The thermostats are responsible for controlling the heating elements. When the water has cooled off, the thermostats kick on the heating elements to heat the water. And once the water has reached your desired temperature, the thermostats shut off the heating element. (This is very similar to the way your heating and air conditioning thermostat controls your home HVAC system.) But these thermostats can go bad. When they do, they sometimes get stuck in the "on" position. This means that that the heating element continues to heat your water, eventually causing the high-limit switch to trip. The fix: The bad thermostat needs to be replaced. A plumber can use a multimeter to test the thermostats and find out which one is bad. Other problems that can cause your high-limit switch to trip While a bad thermostat is the most common reason your water heater's reset button may trip, it's not the only one. Other common causes include:
  • A shorted heating element-It may be that the thermostat is working just fine and shutting off the heating element. But a short in the element is causing it to continue to heat your water.
  • Loose wiring-A loose wire in the water heater can generate heat that can cause the high-limit switch to trip.
  • Bad high-limit switch-The switch itself may be malfunctioning and tripping when it shouldn't be.
Get a professional plumber's help
Do you live in the Minneapolis-St. Paul area and need a reliable plumber to help you troubleshoot your water heater problem? Contact MSP Plumbing. We can usually fix the problem the same day.
11/7/2018 1:32:11 PM • Reliance Water... • Answered on Nov 07, 2018
Reliance 50 Gal. Electric Water Heater 6-50-DORS Logo
2 questions posted
Top Reliance Water Heaters Experts
john h
Paul Carew
Are you a Reliance Water Heater Expert? Answer questions, earn points and help others
View Most Popular
  • Reliance Water Heaters
Most Popular Question
power both elements all time
  • Water Heaters
