20 Most Recent Wells F67 Dual Countertop Electric Fryer Questions & Answers
Check the power rating of the fryer against the relay wattage , the relay wattage has to be higher than fryer. If that checks out ok one of the heater elements must be shorted out. with the power off, check for shorts with a ohms meter.
Wells F67 Dual... | Answered on Nov 14, 2014
It is not economical nor even possible to convert electric fryer to gas fryer since the tank construction and parts are very different.
Wells Kitchen... | Answered on May 20, 2015
Wells Fryer manuals can be downloaded free at www.wells-bloomfield.com
Any competent service technician could cobble something like this together, but I'd challenge the insurance company, as this fryer is UL approved. Such a modification would be expensive and void the warranty and NSF and UL approveals.
Wells Kitchen... | Answered on Sep 23, 2014
Hi there! If hi limit wont reset when button is pushed, there might be a mechanical problem inside the part which prevents t from resetting, you have to replace the part.
Visit www.middleby.com and select wells to find the nearest authorized parts dealer near your area.
Regards.
Wells Kitchen... | Answered on Jan 28, 2013
check your program for the basket lift, also check the mechanisms.
Wells Kitchen... | Answered on Mar 31, 2011
Running the fryer with no oil will over heat the coil very quickly...this caused the element to burn out...
That element will be replaceable...
If you call these guys you should be able to purchase a new element from them...
http://www.fryerworld.com/wells-f49.html
heatman101
Wells Kitchen... | Answered on Nov 23, 2010
By purchasing a natural to propane conversion kit & it also might require the burner orfices to be changed out too. By contacting [email protected] 888-492-2782 with your model & serial # in front of you, they will be able to give you the part #s needed. If they will not sell you the parts then you can probably purchase them from Stove Parts Supply in Ft. Worth Texas
Wells Kitchen... | Answered on Jul 25, 2009
Wells F67 Dual Countertop Electric Fryer Logo
2 questions posted
Top Wells Kitchen Appliances - Others Experts
Dennis Boxerman
ray gallant
Stan Ford
Are you a Wells Kitchen Appliances - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Wells Kitchen Appliances - Others
Most Popular Question
one year old fryer melted solenoid
  • Kitchen Appliances - Others
