20 Most Recent Electrolux EWFLS70JSS - Front Load Washer with Wave-Touch Controls Fea Questions & Answers
2answers
Electrolux W455H error 021 I/O communication(no contact with I/O: 01 )
My friend's aunt makes $92 hourly on the laptop. She has been out of a job for 10 months but last month her pay was $15,000 just working on the laptop for a few hours. go to this web site and read morego to this site home tab for more detail I work through this link, go to tech tab for work detail......GOOD LUCK...www.cash.hiring9.com
3/19/2023 3:48:43 PM • Electrolux... • Answered 3 days ago
How to enter diagnostic mode on Electrolux ewmgd70jppo
Please follow these procedures to activate the diagnostic mode on an Electrolux EWMGD70JPP0 dryer: Ensure that the dryer is unplugged from the power source and turned off. The "CANCEL" and "START" buttons should be pressed and held simultaneously. Reconnect the dryer's power while continuing to hold down the "CANCEL" and "START" buttons. Holding the "CANCEL" and "START" buttons together will start the diagnostic test. That should only take a few seconds. Once the diagnostic test has begun, let go of the "CANCEL" and "START" buttons. Now that you should be in diagnostic mode, you can go through the various tests using the display. The "CYCLE SELECT" knob and the "OPTIONS" button should be used to cycle through the tests, respectively. The diagnostic mode should only be used by those who are qualified to work on appliances, as it is designed for service technicians. It is advised that you get in touch with a reputable appliance repair provider if you are unfamiliar with the diagnostic mode or are unclear on how to proceed.
3/7/2023 6:24:59 PM • Electrolux... • Answered on Mar 07, 2023
Electrolux washer model EIFLS6OLSSO only works on fast cycle?
first thing, try this.....Unplug the unit for 7 minutes and the plug it back in and it will be reset
3/2/2023 11:00:50 PM • Electrolux... • Answered on Mar 02, 2023
2answers
Electrolux EFLW427UIW1 front loader washer not dispensing fabric softener?
Question edited for clarity. Did you remove the drawer and remove the top off the fabric softener siphon? Most just pull off. Or turn it over and force hot water in from underneath. Scrub the hole in the upper part of the drawer with a pot brush. Or the motorized diverter in the top of the machine is faulty if it has one? The diagram isn't clear. https://www.google.com/search?q=electrolux+eflw427uiw1+parts+diagram ..
3/2/2023 10:44:49 PM • Electrolux... • Answered on Mar 02, 2023
Electrolux Ecovalve EWF1087 wont progress past wash
If the machine is not progressing past the wash cycle and is stopping at the end of it, there could be a few possible reasons for this. Here are some troubleshooting steps you can try:
  1. Check the water inlet valve: If the water inlet valve is faulty or clogged, it can prevent the machine from progressing to the rinse cycle. Check to ensure that the water inlet valve is clean and functioning properly.
  2. Check the drain pump: If the drain pump is faulty or clogged, it can cause the machine to stop at the end of the wash cycle. Check to ensure that the drain pump is clean and functioning properly.
  3. Check the door latch: If the door latch is not engaging properly, it can prevent the machine from progressing to the rinse cycle. Check to ensure that the door latch is clean and functioning properly.
  4. Check the pressure switch: The pressure switch detects the water level in the machine and signals when to advance to the next cycle. If the pressure switch is faulty, it can cause the machine to stop at the end of the wash cycle. Check to ensure that the pressure switch is clean and functioning properly.
If none of these troubleshooting steps work, it may be best to contact a qualified technician to diagnose and repair the issue.
2/26/2023 7:24:42 AM • Electrolux... • Answered on Feb 26, 2023
Electrolux front-load washer EIFLS55IIW0 won't spin. Belt-drive motor turns a few revolutions as drain pump starts, then stops while pump continues running.
Based on the information you provided, it is possible that the issue with your Electrolux front-load washer is related to the motor or the belt that drives it. Here are some steps you can take to troubleshoot the problem:
1. Check the belt: If the belt that drives the motor is loose or damaged, it could cause the motor to stop spinning. To check the belt, first unplug the washer from the power source. Then, remove the back panel of the washer and locate the belt. Check for signs of wear, fraying, or stretching. If the belt is damaged, it will need to be replaced.
2. Check the motor: If the belt appears to be in good condition, the issue may be with the motor itself. Check the motor for any signs of damage or wear. You may need to remove the motor from the washer to do this. If the motor is damaged, it may need to be replaced.
3. Check the control board: If neither the belt nor the motor appears to be the problem, the issue may be with the control board. A faulty control board can cause the washer to stop spinning. To check the control board, you may need to consult a professional technician.
4. Check the pump: The drain pump may also be a culprit as it's continuing to run. A clogged drain pump filter can cause the washer to not spin. Check the filter and clear any debris that may be clogging it. You may also want to check the drain hose for any kinks or clogs that could be preventing proper drainage.
2/22/2023 1:03:33 AM • Electrolux... • Answered on Feb 22, 2023
I have an Electrolux model EFLW427UIW1 that when I was washing clothes it made a loud noise and then smoke came from the tub
This sounds like a serious problem with your washing machine. Smoke coming from the tub can indicate an electrical or mechanical failure, which can pose a potential fire hazard. It's important to unplug the machine and stop using it immediately. You should not attempt to repair the machine yourself, as this can be dangerous and may void any warranties or insurance coverage. Instead, you should contact a qualified service technician to diagnose and repair the issue. Additionally, you should also contact the manufacturer to report the problem and see if there are any known issues with the model, or if there have been any product recalls.
2/12/2023 1:27:34 PM • Electrolux... • Answered on Feb 12, 2023
Hello Community, my Electrolux washing machine has a flashing key symbol, door that won't open, and no cycle will work. I would be very grateful if you could tell me how to solve ?
Hello and welcome to the Fixya Community. Your Child Lock is activated. When the child lock is activated, there will be a key symbol in the display and all the washing machine buttons will be disabled. To deactivate the child lock, press and hold the start button for three to five seconds. After this time you will hear an audible beep and the key symbol will disappear.
Key symbol appears in the display of your washing machine
2/4/2023 3:12:47 AM • Electrolux... • Answered on Feb 04, 2023
2answers
The Electrolux dryer has been burning my clothes and I have to hang dry inorganic and delicate clothing or they will be ruined! Now my kids are doing their own wash Can they fix it?
The problem is lack of airflow. The inside is full of fluff and the exit hose from the machine, the hose itself and the outside vent are blocked. Pull it out, disconnect the hose, check the back and run it with no hose to test my theory. Or, the thermostat is faulty. Dryer fires and the number one cause of house fires!
1/28/2023 9:48:57 PM • Electrolux... • Answered on Jan 28, 2023
Electrolux washing machine soap dispenser front panel - I took off to clean and even though all lines up with actual soap dispenser tray - I can't get front panel to stay attached! Barbara
Hi, Please recheck the documentation that came with the washer to ensure that you're attempting to place it in the manner intended by the manufacturer . Also, you can check the floor near the washer to ensure that no pieces have accidentally broken off from the front panel or dispenser as this would most likely stop you from making the attachment. If this issue persists, please schedule an appointment with your local Home Depot to fix to help overcome the issue at home. Thank you.
12/28/2022 2:19:36 AM • Electrolux... • Answered on Dec 28, 2022
2answers
My Electrolux washing machine recently started having CRAZY amount of suds despite using our regular tide HE pods (only 1)
Hi, your exit valves might be a bit clogged. Please add 7 to 10 inches of tooth paste into a short wash and allow your machines pipes to be cleaned of it's potential debris that are clogging it's exit pipes. After this, please perform another wash. Thank you.
11/20/2022 7:26:28 PM • Electrolux... • Answered on Nov 20, 2022
Need to remove drawer from the pedestal, Electrolux EPWD257UTT. How can this be done?
Hi, Please check the back and/or top of the object for any screws that you be remove before pulling out the drawer in the front. You can reference the user manual of the device to help guide you in the removal process. Thank you.
10/12/2022 1:59:55 AM • Electrolux... • Answered on Oct 12, 2022
I have an Electrolux washing machine in which it writes E anytime I switch it on and doesn't work at all
When you turn it on it should give you the 'E' and then a number. This number will show what the problem is likely to be. Comment below with the code and I'll try to help you more.
9/19/2022 3:57:42 PM • Electrolux... • Answered on Sep 19, 2022
I have Electrolux front load wahser Model EIFLW55HIW0 that is about 6 years old, Has worked without a problem for many years. recently started giving E35 error codes. the water doesn't ap
Hello friend, thank you very much for your inquiry!
After reviewing the information you have provided regarding your Electrolux front load washer EIFLW55HIW0 having an E35 error code, I have found E35 is an indication of a water over fill problem. If the water fills above 4.5 inches please follow the below trouble shooting steps I have provided for you. If the water is not above 4.5 inches you may need to change the pressure sensor switch.
If the water enters continuously please unplug the washer to see if the water stops. If the water does not stop your issue may be the water valve assembly. If the water does stop the wiring to the water valve assembly needs to be checked. If the wiring is good the control board may need to be replaced.
I do suggest you seek a professional technician to look into this issue further to avoid any unnecessary part purchases. - T
8/11/2022 3:13:38 PM • Electrolux... • Answered on Aug 11, 2022
Reset Electrolux EWF10831
Hi. How to solve my washing machine front loader its always show error while im wash my clothes if i wash around 2 hours it will be stuck at 1hours 20 minutes. I have no idea why it happens like that.
6/25/2022 11:56:35 PM • Electrolux... • Answered on Jun 25, 2022
Electrolux EWFLS70JSS - Front Load Washer with Wave-Touch Controls Fea Logo
1 questions posted
Top Electrolux Washing Machines Experts
nu267
tina gallow
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Electrolux Washing Machines
Most Popular Question
electrolux front load washer eifls55iiw0
  • Washing Machines
