20 Most Recent Electrolux 4.2 Cu. Ft. Front Load Washer with IQ-Touch Controls featuring Perfect Steam Questions & Answers
2answers
Electrolux Perfect steam washer has a faded lcd screen. Very hard to read at this point, can someone tell me how to order and replace it Please?
Thank you for your post, Glen Wagner! In order to get proper replacement parts for your Electrolux washer you would need to have the model number available. I would recommend reaching out to the manufacturer, to guarantee the parts are correct. If you need assistance with installing the parts you may want to consult a professional for proper installation of replacement components. I hope this information has been beneficial. -Matt
12/26/2018 9:34:18 PM • Electrolux 4.2... • Answered on Dec 26, 2018
My lcd screen is faded and hard to read on my perfect steam Electrolux washer. Would like to fix this my self if some one can tell me how? Thanks
Thanks for your post, friend! I interpret that you would like to change out LCD screen on your Frigidaire washer. Typically, this is not a simple DIY job. I would recommend consulting with a professional technician for proper replacement of such electrical components to avoid any future issues. If you would like to order the part you should reach out to the manufacturer for the proper part number and price. Hopefully this has been helpful. -Matt
10/16/2014 2:12:40 PM • Electrolux 4.2... • Answered on Oct 16, 2014
Hello Community, my Electrolux washing machine has a flashing key symbol, door that won't open, and no cycle will work. I would be very grateful if you could tell me how to solve ?
Hello and welcome to the Fixya Community. Your Child Lock is activated. When the child lock is activated, there will be a key symbol in the display and all the washing machine buttons will be disabled. To deactivate the child lock, press and hold the start button for three to five seconds. After this time you will hear an audible beep and the key symbol will disappear.
Key symbol appears in the display of your washing machine
2/4/2023 3:12:47 AM • Electrolux... • Answered 3 days ago
2answers
The Electrolux dryer has been burning my clothes and I have to hang dry inorganic and delicate clothing or they will be ruined! Now my kids are doing their own wash Can they fix it?
The problem is lack of airflow. The inside is full of fluff and the exit hose from the machine, the hose itself and the outside vent are blocked. Pull it out, disconnect the hose, check the back and run it with no hose to test my theory. Or, the thermostat is faulty. Dryer fires and the number one cause of house fires!
1/28/2023 9:48:57 PM • Electrolux... • Answered on Jan 28, 2023
Electrolux washing machine soap dispenser front panel - I took off to clean and even though all lines up with actual soap dispenser tray - I can't get front panel to stay attached! Barbara
Hi, Please recheck the documentation that came with the washer to ensure that you're attempting to place it in the manner intended by the manufacturer . Also, you can check the floor near the washer to ensure that no pieces have accidentally broken off from the front panel or dispenser as this would most likely stop you from making the attachment. If this issue persists, please schedule an appointment with your local Home Depot to fix to help overcome the issue at home. Thank you.
12/28/2022 2:19:36 AM • Electrolux... • Answered on Dec 28, 2022
2answers
My Electrolux washing machine recently started having CRAZY amount of suds despite using our regular tide HE pods (only 1)
Hi, your exit valves might be a bit clogged. Please add 7 to 10 inches of tooth paste into a short wash and allow your machines pipes to be cleaned of it's potential debris that are clogging it's exit pipes. After this, please perform another wash. Thank you.
11/20/2022 7:26:28 PM • Electrolux... • Answered on Nov 20, 2022
Need to remove drawer from the pedestal, Electrolux EPWD257UTT. How can this be done?
Hi, Please check the back and/or top of the object for any screws that you be remove before pulling out the drawer in the front. You can reference the user manual of the device to help guide you in the removal process. Thank you.
10/12/2022 1:59:55 AM • Electrolux... • Answered on Oct 12, 2022
I have an Electrolux washing machine in which it writes E anytime I switch it on and doesn't work at all
When you turn it on it should give you the 'E' and then a number. This number will show what the problem is likely to be. Comment below with the code and I'll try to help you more.
9/19/2022 3:57:42 PM • Electrolux... • Answered on Sep 19, 2022
I have Electrolux front load wahser Model EIFLW55HIW0 that is about 6 years old, Has worked without a problem for many years. recently started giving E35 error codes. the water doesn't ap
Hello friend, thank you very much for your inquiry!
After reviewing the information you have provided regarding your Electrolux front load washer EIFLW55HIW0 having an E35 error code, I have found E35 is an indication of a water over fill problem. If the water fills above 4.5 inches please follow the below trouble shooting steps I have provided for you. If the water is not above 4.5 inches you may need to change the pressure sensor switch.
If the water enters continuously please unplug the washer to see if the water stops. If the water does not stop your issue may be the water valve assembly. If the water does stop the wiring to the water valve assembly needs to be checked. If the wiring is good the control board may need to be replaced.
I do suggest you seek a professional technician to look into this issue further to avoid any unnecessary part purchases. - T
8/11/2022 3:13:38 PM • Electrolux... • Answered on Aug 11, 2022
Reset Electrolux EWF10831
Hi. How to solve my washing machine front loader its always show error while im wash my clothes if i wash around 2 hours it will be stuck at 1hours 20 minutes. I have no idea why it happens like that.
6/25/2022 11:56:35 PM • Electrolux... • Answered on Jun 25, 2022
Electrolux washer always steams, even on cold setting
Try disconnecting it from the mains supply overnight to reset. If it still does it, you need a service call. It is likely to be the Control Board and they are expensive so need correct diagnosis.
6/12/2022 10:05:36 PM • Electrolux... • Answered on Jun 12, 2022
I replaced my latch on my Electrolux washer did one load then after that washer won't go past sensing mode
The senor on your washing machine could be broken now and needs to be replaced.
6/8/2022 4:31:13 AM • Electrolux... • Answered on Jun 08, 2022
How to get my Electrolux model EIFLS55IIW0 out of Demo Mode
go to reset
5/19/2022 4:50:40 AM • Electrolux... • Answered on May 19, 2022
Electrolux 4.2 Cu. Ft. Front Load Washer with IQ-Touch Controls featuring Perfect Steam Logo
2 questions posted
Top Electrolux Washing Machines Experts
nu267
tina gallow
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Electrolux Washing Machines
Most Popular Question
electrolux perfect steam washer faded
  • Washing Machines
