20 Most Recent Acer Extensa 368D PC Notebook Questions & Answers
if you want to boot a computer from the usb you will have to go into the bios and set the boot media ( HD, CD, USB) so that the computer knows where to search for the os.
Acer Extensa... | Answered on Jul 19, 2015
There are more than one possibility for this scenario (settings, cable, lamp):
•The display is not set as the primary or active display (such as is the case when set to view in projector-only display mode). Many laptops have either a Function key (such as F4) or a hotkey expressly set aside for presentations (usually at the top right with two other hotkeys). Newer operating Windows systems allow for changing the display mode through holding a Windows key down while pressing the [P] key.
•The monitor data cable is damaged. Sometimes, this can be tested by changing the vertical angle of the display to see if the display shows. (In this case, replace the display data cable.)
•The lamp inside/behind/above/below the display could be going out. (In this case, replace the display lamp.)
The easiest way to test & to give a temporary workaround would be to hook an external monitor to the laptop & to turn on both devices to ascertain if the video output shows on it.
If all else fails, then take it to a technician because the system board could be bad.
Acer Extensa... | Answered on Feb 25, 2015
Check the hard drive might be defect or loose from the hard drive connector. If the hard drive is detected in BIOS probably the hard drive is out of order
Acer Extensa... | Answered on Jan 04, 2015
Right Click on the desktop then goto property then setting, then screen resolution in the lower corner of dialog box, just holt left key of mouse and drag according for resolution setting.
Acer Extensa... | Answered on Sep 30, 2014
In front of your dvd is a little pin hole place a diaper pin in it and push the case should open .On your computer you can also go to My Computer look under dvd right click on the icon ,when the drop down menu show click eject.
Acer Extensa... | Answered on Sep 22, 2014
if it is blocked using bios then goto bios setting during bootup and enable usb :)
Acer Extensa... | Answered on Aug 02, 2014
does the drive work in other systems.
what is the error is it windows error driver
or is it a error from the drive .
many drives are fake , manyyyyy drives
it will have a brand name on it an might be real. if no name its bogus.
Acer Extensa... | Answered on Jul 10, 2014
LOOK FOR A NEW BATTERY ON AMAZON...
http://www.amazon.com/Notebook-5420-5038-5430-5720-5620-6830-5630EZ-421G25N/dp/B0080PK0AM/ref=sr_1_1/176-3083281-1420007?ie=UTF8&qid=1400346399&sr=8-1&keywords=acer+extensa+laptop+battery
Acer Extensa... | Answered on May 17, 2014
You can use the built-in Disk Defragmenter to Defragment your system.
To defragment your hard disk
  1. Open Disk Defragmenter by clicking the Start button. In the search box, type Disk Defragmenter, and then, in the list of results, click Disk Defragmenter.
  2. Under Current status, select the disk you want to defragment.
  3. To determine if the disk needs to be defragmented or not, click Analyze disk. If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
Once Windows has finished analyzing the disk, you can check the percentage of fragmentation on the disk in the Last Run column. If the number is above 10%, you should defragment the disk.
4. Click Defragment disk. If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
GuruAid
Acer Extensa... | Answered on May 06, 2014
Acer Extensa 368D PC Notebook Logo
1 questions posted
Lee Hodgson
Lee Hodgson
Gustavo Ortiz
Gustavo Ortiz
Michael Thomas
Michael Thomas
View Most Popular
Extensa Acer
  • Extensa Acer
Most Popular Question
common acer5630 screen going blank hard
  • Computers & Internet
