20 Most Recent Acer Extensa 710TE Notebook Questions & Answers
most likely:
1. backlight is dead (search for replacement displays).
2. backlight power-inverter is dead (check ebay for your model +inverter to see if there is even one in your model)
3. (very unlikely) wires which power the backlight may be worn from bending over time.
for the time-being, connect an external monitor, if possible, so you can access your system. connect it, power-on, and it should work by default -if not, hold the Fn key and press F8 (usually this key) to enable external display output.
and.. good luck!
Acer Extensa... | Answered on Aug 31, 2009
The computer screen will not come on but the hdd light is active. Accer 4420/4120 extensa series/ just clicked on a computer because mine is not on the list
Acer Extensa... | Answered on Apr 01, 2009
AutoCAD 2007 is not for Vista?
Acer Extensa... | Answered on Dec 24, 2008
Yes, you do have to take it apart. How do you know the cmos battery is bad? Is the time wrong all of the time??Does the BIOS default all the time??
Acer Extensa... | Answered on Sep 21, 2008
Try opening the 'computer' icon - normally shows as an icon on your desktop or in start menu then you will hopefully see the flash drive listed along with C Drive, CD Drive etc. Double click or right click and open - this should let you see and open individual files on the flash.
Acer Extensa... | Answered on Feb 14, 2008
if you want to boot a computer from the usb you will have to go into the bios and set the boot media ( HD, CD, USB) so that the computer knows where to search for the os.
Acer Extensa... | Answered on Jul 19, 2015
There are more than one possibility for this scenario (settings, cable, lamp):
•The display is not set as the primary or active display (such as is the case when set to view in projector-only display mode). Many laptops have either a Function key (such as F4) or a hotkey expressly set aside for presentations (usually at the top right with two other hotkeys). Newer operating Windows systems allow for changing the display mode through holding a Windows key down while pressing the [P] key.
•The monitor data cable is damaged. Sometimes, this can be tested by changing the vertical angle of the display to see if the display shows. (In this case, replace the display data cable.)
•The lamp inside/behind/above/below the display could be going out. (In this case, replace the display lamp.)
The easiest way to test & to give a temporary workaround would be to hook an external monitor to the laptop & to turn on both devices to ascertain if the video output shows on it.
If all else fails, then take it to a technician because the system board could be bad.
Acer Extensa... | Answered on Feb 25, 2015
Check the hard drive might be defect or loose from the hard drive connector. If the hard drive is detected in BIOS probably the hard drive is out of order
Acer Extensa... | Answered on Jan 04, 2015
Right Click on the desktop then goto property then setting, then screen resolution in the lower corner of dialog box, just holt left key of mouse and drag according for resolution setting.
Acer Extensa... | Answered on Sep 30, 2014
In front of your dvd is a little pin hole place a diaper pin in it and push the case should open .On your computer you can also go to My Computer look under dvd right click on the icon ,when the drop down menu show click eject.
Acer Extensa... | Answered on Sep 22, 2014
if it is blocked using bios then goto bios setting during bootup and enable usb :)
Acer Extensa... | Answered on Aug 02, 2014
does the drive work in other systems.
what is the error is it windows error driver
or is it a error from the drive .
many drives are fake , manyyyyy drives
it will have a brand name on it an might be real. if no name its bogus.
Acer Extensa... | Answered on Jul 10, 2014
Acer Extensa 710TE Notebook Logo
Popular Tags
8 questions posted
Lee Hodgson
Lee Hodgson
Gustavo Ortiz
Gustavo Ortiz
Michael Thomas
Michael Thomas
View Most Popular
Extensa Acer
  • Extensa Acer
Most Popular Question
cmos acer extens e610cdt
  • Computers & Internet
