20 Most Recent
Honeywell Triangle Tube Prestige Solo 110 Ng Wall Boiler Ps110 Ng Questions & Answers
4A Slow Blow Fuse keeps blowing in my Prestige Triangle Tube 110 Solo LP with U125
Jack,
I just got mine fixed, so can for sure try to help you.
Something on the low voltage side is misbehaving. I can walk you through narrowing it down if necessary, but it's most likely the blower motor.
Here is how you can confirm. Unplug the wiring harness or harnesses at the top of the blower motor. The plastic can be brittle, so be gently. This will remove the blower from the equation. Then, start up the boiler. Did a new fuse blow? If not, it's the blower motor.
If there is a tube attached to the blower intake, remove it. Then stick a screwdriver into the small hole where the air sucks in. Try to rotate the fan. Is it stuck? Does it spin freely? You might be able to free it and get heat for a while, but you will probably need a new blower kit if it's noisy or stuck.
Post back if you need more help.
- Paul
2/23/2015 6:44:54 PM •
Honeywell...
Answered
on Feb 23, 2015
Prestige 110 boiler won't ignite
Is there gas cause most of the time it won't ignite cause there is no gas. What you can do is light it your self and if it lights that is good and if it stays light than there is has sometime you have to light it your self
2/20/2014 5:12:21 PM •
Honeywell...
Answered
on Feb 20, 2014
Boiler ignition failer
Try adjusting the gas to air mixture and flow rate. I don't work well in very cold weather, either. I think that's fairly typical. Even a diesel engine is difficult to start in cold cold weather. Perhaps heating the room where the boiler is would help or at lest insulate the room well. Including stopping any drafts that may be causing a windy condition in or around the combustion chamber.
2/8/2014 3:02:21 PM •
Honeywell...
Answered
on Feb 08, 2014
