Why won't our BOSCH TWK8633 stay switched on?
You don't say how old your kettle is, but if it is less than 1 month, I would go back to the retailer where you purchased. Make sure you have your guarantee or proof of purchase.... Otherwise, going by past experience, kettles that won't stay switched on usually need de-scaling. Even if you can't see any lime scale in the kettle, there are sediments in the water that will build up over time & that can cause the element to overheat. This makes the kettle switch off prematurely or not switch on at all. In the UK, regardless of where you live, you should de scale your kettle at least once a month. If this doesn't work, you should still go back to the retailer, but if it's found that the malfunction uis diue to lack of de-sclaing, this isn't usually covered by the warranty....good luck!
