20 Most Recent Bosch TDA4622GB Sensixx B3 Steam Iron Blue berry Questions & Answers
My iron has stopped heating up although lights still flashing and stop to tell me it's heated but still cold
Soak the base in vinegar and water for two hours, shake it and see the junk come out. Repeat with fresh vinegar and water. Leave the iron in the airing cupboard overnight to dry out internal condensation. Next day half fill iron with vinegar and water leave two hours, empty. Plug in it will likely heat up again so put water in the iron and heat it up then unplug use the calc clean and shake it over the sink
6/20/2019 11:41:23 AM • Bosch TDA4622GB... • Answered on Jun 20, 2019
0answers
Disassemble
Be the first to answer 12/10/2014 2:02:15 PM • Bosch TDA4622GB... • Posted on Dec 10, 2014Be the first to answer
0answers
How to fix a Bosch Sensixx B7 faulty Spray function.
Thanks for that Tim, very useful indeed. Siri did well, but there were two typos which I fixed 'price', to 'prise' and 'stripey' to 'stripy'. These videos may have been helpful for Sensixx and may have been the ones you watched. Thanks again, much appreciated. .. https://www.youtube.com/watch?v=9kTFaHDxkG4
7/29/2023 4:35:10 PM • Bosch Irons • Answered on Jul 29, 2023
The temperature control dial of my Bosch Sensixx x DA30 iron has become very stiff to rotate. How to make it easier to turn?
If the temperature control dial of your Bosch Sensixx x DA30 iron has become stiff, you can try the following steps to make it easier to turn:
  1. Unplug the iron and let it cool down completely.
  2. Using a soft cloth or sponge, clean the dial and the surrounding area to remove any dust or debris.
  3. Apply a small amount of WD-40 or silicone spray lubricant to the temperature control dial.
  4. Slowly turn the dial back and forth a few times to distribute the lubricant and loosen up any dirt or debris that may have been causing the stiffness.
  5. Wipe away any excess lubricant with a clean, dry cloth.
  6. Plug in the iron and turn it on to make sure the temperature control dial is turning smoothly.
If the stiffness persists or the temperature control dial is still not turning smoothly, you may need to take your iron to a professional for repair or replacement of the dial.
2/25/2023 6:01:00 PM • Bosch Irons • Answered on Feb 25, 2023
I have a bosch vario comfort series 8 iron and steam release button pushed up inside it and it broke - can this be repaired
It would be more cheaper and easier just to buy a new clothing iron than to try and fix the steam release button on your iron.
6/14/2022 3:11:21 AM • Bosch Irons • Answered on Jun 14, 2022
Hi my Bosch steam iron is tripping my electric when I turn it on its brand-new anyone no what problem is ?
dead short in the iron or lead brand new , take it back for a new item under warranty
9/19/2019 7:09:39 PM • Bosch Irons • Answered on Sep 19, 2019
My bosch steam iron sensixx b25l keeps letting steam out continuosly without the steam switch being pushed, product is just 3 years old
Do you drain the vinegar before turning on the iron and steaming through?
2/4/2019 9:11:22 AM • Bosch Irons • Answered on Feb 04, 2019
Bosch TDA4622GB Sensixx B3 Steam Iron Blue berry Logo
Popular Tags
18 questions posted
Top Bosch Irons Experts
john h
ADMIN Andrew
ADMIN Andrew
Aron
Are you a Bosch Iron Expert? Answer questions, earn points and help others
View Most Popular
Bosch Irons
  • Bosch Irons
Most Popular Question
iron stopped heating up although lights
  • Irons
