20 Most Recent
Bosch Evolution 500 HGS5053UC 30" Freestanding Gas Range with 5 Sealed Burners, 5 cu. ft. Convection Oven, Self Cleaning and Wide View Oven Window Questions & Answers
Bosch gas range error code F11
Disconnect the ribbon from the control panel and clean it using pencil eraser. then carefully reconnect it. If the F11 is still there most likely it's the control panel.God bless you
The temperature control dial of my Bosch Sensixx x DA30 iron has become very stiff to rotate. How to make it easier to turn?
If the temperature control dial of your Bosch Sensixx x DA30 iron has become stiff, you can try the following steps to make it easier to turn:
- Unplug the iron and let it cool down completely.
- Using a soft cloth or sponge, clean the dial and the surrounding area to remove any dust or debris.
- Apply a small amount of WD-40 or silicone spray lubricant to the temperature control dial.
- Slowly turn the dial back and forth a few times to distribute the lubricant and loosen up any dirt or debris that may have been causing the stiffness.
- Wipe away any excess lubricant with a clean, dry cloth.
- Plug in the iron and turn it on to make sure the temperature control dial is turning smoothly.
If the stiffness persists or the temperature control dial is still not turning smoothly, you may need to take your iron to a professional for repair or replacement of the dial.
2/25/2023 6:01:00 PM •
Bosch Irons
Answered
on Feb 25, 2023
I have an bosch sensixx b5 iron and the calc clean
Here you have how to solve this issue. It has been obtained from the device's manual.
2. calc'n clean
The "calc'n clean" function helps to remove scale particles
from the steam dispenser. The iron includes a system to
warn when the dispenser needs periodically cleaning. When
the "calc 'n clean" symbol lights up on the navigation display
the dispenser needs cleaning.
Fill the water tank. Plug in the iron and select the temperature
setting .
After the necessary warm-up period, unplug the iron and
hold it over a sink.
Position the steam regulator to the "calc'n clean" position
and keep it in this position.
Gently shake the iron. Boiling water and steam will come out,
removing any scale or deposits that might be there.
When the iron stops dripping, position the regulator to
the position.
For improved descaling, heat up the iron again fully and
press the steam button several times in quick succession.
Then wait until the remaining water has evaporated from
the soleplate of the iron.
Once it has been cleaned, the cleaning warning must be
cancelled on the navigation display. To do this, simply press
and hold the on/set navigation key for more than 5 seconds,
with the iron plugged in. If you do not do this, the cleaning
icon will remain lit.
3. anti-calc
The "anti-calc" cartridge has been designed to reduce the
build-up of scale produced during steam ironing, helping
to extend the useful life of your iron. Nevertheless the
"anti-calc" cartridge cannot remove all of the scale that is
produced naturally over time.
7/8/2017 6:59:42 PM •
Bosch Irons
Answered
on Jul 08, 2017
